Dash / running lights out, fuse keeps blowing
Old Dec 16, 2006 | 11:36 AM
Progress's Avatar
It's business time.
I was driving last night and all of a sudden my dash lights went out. Gauges work but not lit. Clearance lights, side markers and tails don't work. Brake, signals, heads all work.
I checked all fuses under hood and the only one blown is the 10 amp one for tail lights. I threw a 15A one in, since it was all I had, and that blew once I turn the lights on.
Only electrical mod is a Helios HID kit that I've had for a while now.
Any ideas?
Old Dec 18, 2006 | 07:20 AM
Progress's Avatar
It's business time.
Any ideas (bump)?
Old Dec 18, 2006 | 09:06 AM
wngan9447's Avatar
Chicken Feet Croo!
Same problem here. I have the foglight rewire also.
It happened when I put LEDs in my corners, but it doesn't make sense. Aren't LEDs suppose to consume less power? I took out the LEDs and put in the regular 194 bulbs and it fixed the problem. So I have LEDs in the front corners and 194 bulbs in the rear.
Old Dec 18, 2006 | 09:37 AM
00MaxSE's Avatar
Pointy Elbows
Sam, maybe try putting in a new 10A fuse?
Old Dec 18, 2006 | 10:27 AM
Progress's Avatar
It's business time.
I have LEDs with clears as well. I'll give that a shot next time I look for the fix.
If it blew a 15A wouldn't it naturally blow a 10A?
Old Dec 18, 2006 | 01:36 PM
jvienneau's Avatar
Take all the affected external bulbs out and put in a new fuse. If it doesn't blow, replace them one-by-one until you find the shorted one. If it still blows without the bulbs you have a bigger problem.
Old Dec 18, 2006 | 01:39 PM
00MaxSE's Avatar
Pointy Elbows
One would think...but you never know.
Old Dec 18, 2006 | 04:10 PM
808MAX-SPEC's Avatar
Wow. Lot of people have blown fuses. Yesterday I also blew a 15 amp fuse now I need to get a few more just in case.
Old Dec 18, 2006 | 05:59 PM
00MaxSE's Avatar
Pointy Elbows
Keep us updated, Sam.
Old Dec 18, 2006 | 07:07 PM
Progress's Avatar
It's business time.
I won't see my car until the 24th.
For now I'm driving the Bimmah.
I'll let you know after I take a look Thanks, Jason.
Old Dec 19, 2006 | 02:33 AM
lalaMAX's Avatar
LED need a resister!!! other u will blow yr fuse....
it comsume very small amount of amp, but it has almost 0 resistance,imagine u connecting your "+" and "-" together....
for the HID, did u have hi/low like mine? i mean the halo bulb and a hid bulb...
coz i had the same issue, i found out the wire on my halo bulb is loosen and it was touching together... it even melted the wires...>< go check all the positive and negative
Old Dec 19, 2006 | 02:37 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Just drive during the day. Fixed! Seriously though, I hope you get some time to try and get it resolved.
Old Dec 19, 2006 | 04:39 AM
00MaxSE's Avatar
Pointy Elbows
Oh yeah? What yr/model Bimmer? M6 FTW?
Old Dec 19, 2006 | 12:40 PM
pikers's Avatar
No, now you need to find out what's blowing the fuse. Replacing or upping the amperage is nothing more than a bandaid or worse.
Old Dec 19, 2006 | 12:49 PM
Progress's Avatar
It's business time.
Dude, thanks for the advice. I've been meaning to paint my stock sides black and replacing my clears with them. That way I can put back the regular bulbs.
I will check both during break.
My car is now parked at my parents' house (45 mins from school), while I'm driving my dad's spare care. Thanks, I'll let you guys know how it turns out.
It's only the wimpiest Bimmer ever. It's a '93 318is. It's a coupe with a five speed so it's fun to drive. That's all I ask for.
Old Dec 19, 2006 | 02:54 PM
ChromeSE5's Avatar
Had the same problem. I also have the foglight rewire. Turned out to be a loose wire under the passenger side fuse/relay box. Now it is fine. Hope this helps.
Old Dec 19, 2006 | 04:18 PM
Actually I was testing my retrofitted projectors. It didn't work and I blew the fuse in the process. I need check the wiring and fix the problem so it doesn't happen again.
Old Dec 22, 2006 | 07:20 PM
j-nicke1's Avatar
I have some what the same problem except only half of my dash goes out for 25 -30 min and then goes back on if it feels like it. Its the left side of my dash with the fuel gauge and speedometer but the tricky thing is the my miles are still lit up I checked all my fuses and none of them are blown. kinda weird help
Old Dec 23, 2006 | 06:17 PM
Stewpid's Avatar
do you have an aftermarket stereo. I've seen a car with the radio harness cut, and the parking light input not used, or taped off. it grounded out on the dash carrier and the parking light fuse blew whenever the lights were turned on.
If you have an aftermarket system, maybe pull it out and check the harness.
Old Dec 23, 2006 | 07:11 PM
PAREDLINE's Avatar
Did you fix the problem? If not,
check your trunk. The circuit to the parking lights and interior lights start at the same fuse under the hood. Then under the dash they split into interior lights and parking lights.
Chances are the fuse under the hood is blown. If it keeps blowing then you have a short between the battery and the fuse panel under the hood.
If the fuse under the dash keeps blowing, chances are there's a cut wire under your trunk lid. Its pretty common. If you take off the cover panel you may find a wire thats rubbing against bare metal with its insulation worn off.
Usually you'll put in a new fuse and then drive over a bump and pow. The fuse blows.
Old Dec 26, 2006 | 10:51 AM
Progress's Avatar
It's business time.
Thanks for the advice, guys. I checked the fog rewire, the HIDs, the LEDs, the tails. Nothing seems to work. The only thing I could possibly think is that perhaps the dimmer switch is the problem. Before this happened, my dimmer switch was not working. I should have mentioned that. I'm going to take it to a local, trusted shop and see what they can find.
Thanks again.
Old Dec 26, 2006 | 11:09 AM
PAREDLINE's Avatar
Thanks again.
pull the dimmer out and smell it. Does it smell burnt? If not, thats probably not the problem
Old Dec 27, 2006 | 04:32 AM
00MaxSE's Avatar
Pointy Elbows
Good luck Sam.
Old Dec 27, 2006 | 09:28 AM
Progress's Avatar
It's business time.
Ugh! This is such a PITA. It's not the sides, not the fogs (rewire), not the HIDs, not the dimmer, not the tails. All external bulbs have been taken out and it still blew the fuse.
Old Dec 27, 2006 | 09:39 AM
Greeny's Avatar
¯\(°_o)/¯
Ugh,electrical gremlins are the worst..
Since all the bulbs were out and it still blew the fuse,maybe the switch is bad?
Old Dec 27, 2006 | 09:46 AM
Progress's Avatar
It's business time.
You mean the stalk? I should check that, thanks.
Old Dec 27, 2006 | 10:06 AM
Greeny's Avatar
¯\(°_o)/¯
Yeah,the main combination switch..
Old Dec 27, 2006 | 07:22 PM
Progress's Avatar
It's business time.
Thanks. I'll give that a shot.
Any other ideas if it's not the switch?!
Old Dec 28, 2006 | 01:36 PM
Forevermax13's Avatar
Check incoming power at fuse ,lights and dash.
Old Dec 29, 2006 | 04:07 PM
Kevlo911's Avatar
Kevlo for President
Did you ever check the dimmer switch?
Old Dec 30, 2006 | 10:01 AM
Progress's Avatar
It's business time.
I fixed it. I tried everything. Then I pulled the radio out and noticed my Pioneer XM tuner along with it's wiring was under the HU. I pulled it out, threw a fuse in and it worked.
Old Dec 30, 2006 | 01:24 PM
00MaxSE's Avatar
Pointy Elbows
Nice job Sam!
Glad you figured it out yourself.
Old Dec 30, 2006 | 04:45 PM
Greeny's Avatar
¯\(°_o)/¯
Glad you found the problem without having to take the entire car apart..
tsi6001
Oct 3, 2022 10:23 PM
homeyclaus
Sep 3, 2015 06:15 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
doobadoo
Aug 15, 2015 06:43 PM
