Loose Steering
Loose Steering
When I turn the steering wheel left-right quickly while the car is not moving I can feel (and hear) it has more play than it should. Also, when I go over bumps I can feel the same "looseness" in the steering wheel but not all the time. It's almost as if the steering wheel is not bolted on tight enough. I crawled under the car and tried to check to see if anything is loose but couldn't find anything out. I don't hear a clunk or anything like that while going over the bumps, I can only feel it in the steering wheel. The car does not pull or drift to either side and I did not notice any problems with steering.
Does anyone have any idea what I can do to diagnose this?
Thanks.
Thanks.
My max has done that for the longest! only thing I can think of is that the steering wheel gets more tight (like a toyger) as you pick up speed in the max! Good luck, but I have checked every nut and bolt in the front end and are all very tight!
Steering rack diagnosis:
http://www.aa1car.com/library/2003/bf20340.htm
To check tie rod ends:
http://forums.maxima.org/showthread.php?t=490711
Thanks.
Thanks.
I guess what I am getting at is - could this possibly be remedied by having an alignment done?
Also, how (un)safe is it to drive like this?
worldwiderecognized
09-30-2015 01:16 PM
DC_Juggernaut
09-28-2015 04:07 PM
