HELP... really screw up my car... really really need your help!!
Old Dec 24, 2006 | 06:36 PM
lalaMAX's Avatar
k, i finished making the LED for my door light, so i installed them...
they worked for a day and worked perfect...
It was still working this morning, then all the suddent, those led went out, and auto door lock, remote key lock, trunk light, rear defog, went out all together...
so i remove those LEDs, and find out that one of the wire was short on my LED... so i am pretty sure i blown my fuse.
i checked all fuse under my steering wheel, and the one on the right side of my hood, all i can find is a blown 10A "room light" fuse. so i replace it... still no luck... seems light i blown some other thing...
yah and the car wun make that "ding ding" warrning sound when u left your key and left the door open...
sigh... help... what should i do? is there any other fuse box in the car? or did i blown a ECU or anything like that? the car drives fine...
thanx alot, and marry christmas!
Old Dec 24, 2006 | 07:12 PM
KBADPAT's Avatar
Did the check engine light came on or anything like that. I know what it's a warning for something mechanical, although you never know. Did you check all of the fuses inside & under the hood?
Andrei
Old Dec 24, 2006 | 07:29 PM
lalaMAX's Avatar
yes i did check all the fuses that i can see... which is the one under the steering and on the left front side of the hood...
i unplug each and check and plug it back... but no luck...
is it possible to burn the relay? like those big blue thing?
no Engine light...
Old Dec 24, 2006 | 09:10 PM
MacGarnicle's Avatar
how did you check if the fuse was blown? I wouldn/t worry about the ECU being shot -thats what the fuses are for.
Old Dec 25, 2006 | 12:17 AM
lalaMAX's Avatar
yes i did check the fuse all i can find is one 10 A fuse and i replaced it already...
Old Dec 25, 2006 | 12:55 AM
PoLo's Avatar
2-Wheelin it...
i'd double check the fuses underneath the steering wheel. if you can't find anything dead, then i think you blew the master switch, which is the actual driver side module. that cost me over $100 to replace. sucked, but i had to accept it.
Old Dec 25, 2006 | 04:23 AM
MaximaGT-R's Avatar
I'm a Happy Man!
Dont worry about your ecu. my guess would be the driver side module that POLO spoke about.
Old Dec 25, 2006 | 06:33 PM
lalaMAX's Avatar
figered it out... found another blown fuse everything looked fine now thanx
doctorpullit
Mar 29, 2016 11:08 AM
sliptap
Sep 30, 2015 05:57 AM
jchronis2552
Sep 23, 2015 04:57 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
thenewguyy
Sep 12, 2015 11:12 AM
