ticking noise
Old Jan 1, 2007 | 04:50 AM
okay's Avatar
ticking noise
hey, i was driving my car today and noticed a ticking noise coming from the car. it sounds a lot like a spark plug not firing correctly, but the odd thing is that the noise only happens in 1st,2nd, and 3rd gears; the noise goes away in 4th and 5th. and the noise only happens when i'm stepping on the gas, if i leave it in gear and let go of the gas while in gear there is no sound. when i rev it in neutral there is no sound.
could this be a transmission problem?
Old Jan 1, 2007 | 06:51 AM
2001BLKSE's Avatar
is it like a low tick or a loud clunk? a loud clunk could be the tranny...but i have a tick and it was my #5 coil. in the rear(on the driverside) so it was noticable and i had a loss of power...
are you throwing any codes?
Old Jan 1, 2007 | 11:34 AM
okay's Avatar
its a high pitched tick
Old Jan 1, 2007 | 04:32 PM
2001BLKSE's Avatar
are u throwing any codes? does it sound like a a drum? i wouldnt think its the tranny...get to auto zone and get the codes pulled sometimes there in there and u dont know it. also u can get the coils checked they have a tool for it.
Old Jan 1, 2007 | 04:36 PM
shift_2kmaxima's Avatar
what kind of gas are you using?
Old Jan 1, 2007 | 06:34 PM
okay's Avatar
yea i have my own obdii scanner and it didn't show any codes. it sounds like a rapid ticking from like a cowbell, i can't figure it out cause it only happens in 1st, 2nd, and 3rd gears, 4th and 5th have no sounds.
i'm using 91, so i don't think its knocking
Old Jan 1, 2007 | 09:47 PM
97SE_TN's Avatar
Are you using 89 Octane gas?
Old Jan 1, 2007 | 09:59 PM
ICEMAN76's Avatar
someone isn't paying attention.
Old Jan 2, 2007 | 04:25 AM
brio_max's Avatar
Learning English...
Same here.
I would become the happiest man in the world if i'll fix that stupid rattling...
Old Jan 3, 2007 | 05:14 PM
imchaiwala's Avatar
what year is your car (then i can figure out the transmission based on the # of gears you mentioned).
Old Jan 3, 2007 | 07:58 PM
okay's Avatar
its a 01 max se 5 speed
Old Jan 3, 2007 | 08:48 PM
mist max2000's Avatar
i know exactly what noise your talking about,.. does it increase speed with increased rpm? tick..tick... ticktickticktick .. i hated that noise,.. mine randomly went away,.. bad tank of gas? try going to another station next time,... sorry i couldnt be more of a help... also def could be due to coils
Old Jan 10, 2007 | 08:29 PM
okay's Avatar
could low transmission fluid level cause a ticking noise? i'm pretty sure this noise is coming from the transmission becuase it only happens while in gear.
Old Jan 10, 2007 | 09:33 PM
Progress's Avatar
It's business time.
The injectors make a ticking sound. Maybe it's that.
Old Jan 11, 2007 | 12:09 AM
okay's Avatar
how would i find out if thats the sound?
Old Jan 11, 2007 | 05:45 AM
MaximaGT-R's Avatar
I'm a Happy Man!
i would say take it to a local trusted mechanic to check it out.
Old Feb 1, 2007 | 05:57 PM
beakersloco's Avatar
sounds like what happens to mine if I dont let it warm up first.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
