cold start....car almost stalls after putting in drive and hitting gas
Old Jan 2, 2007 | 04:59 PM
aw89maxSE's Avatar
I know it's not good when you start the car and drive off when it's been sitting cold for awhile, but sometimes when you have to get somewhere and don't have time to warm up the car, you got to go. Seems like when I start the car, put it into drive and before I hit the gas, the car almost stalls. I'm guessing it's a MAF issue but mines been replaced once
Old Jan 2, 2007 | 07:26 PM
P. Samson's Avatar
Did you replace the whole MAF assembly or just the sensor?
Old Jan 2, 2007 | 07:30 PM
brad1384's Avatar
Another cold stumbling Problem!
I also have a cold stumbling problem. I changed my intake manifold gaskets. Put in all new spark plugs. Put in all new coils. Put in a new MAF sensor (third one). Put in a new air filter. It did not help one bit. What do you guys think is the problem? It's a 00 se. It has 101k miles on it. Tell me what is wrong! Thanks!
Old Jan 2, 2007 | 07:46 PM
P. Samson's Avatar
Once again chaps it's important to have a matched MAF assembly and ECM. There was a TB to replace the MAF ASSEMBLY on some of these cars along with an ECM reprogram to cure some of these "stumpling" issues. I think there was a separate TB as well, applicable to some cars for an ECM reprogram as well. A dealer can tell you if the car is "current" re any TBs. IF it is a recent occurance, cleaning the TB in the area of the throttle plate and IACV port followed by an Idle Air Volume Learning may help.
Old Jan 2, 2007 | 08:54 PM
not0riouskid's Avatar
check for a vaccum leak or sumthing
Old Jan 2, 2007 | 09:13 PM
OC guy's Avatar
2002 maxima se
A+
Old Jan 3, 2007 | 05:39 AM
brad1384's Avatar
The MAF and the ECM are matched. When the intake manifold gaskets were replaced, they looked for vaccum leaks. I have not cleaned the throttle plate. Could that solve this problem????
Old Jan 3, 2007 | 01:54 PM
madisonmxma's Avatar
An IAC that is dirty or not adjusted right will cause the car to start and then die when cold, or it will stumble at an idle. A good way to see if it's the IACV is to see if the problem goes away while the throttle is open. If it does, then it would be your IAC, and start with cleaning it.
Old Jan 3, 2007 | 01:57 PM
ToneBoat923's Avatar
its the MAF i had the exact same problem
Old Jan 3, 2007 | 08:05 PM
brad1384's Avatar
It's not the MAF sensor. I've had 3 new ones. The latest during the stumbling problem..Same problem after change. And yes the ECM has been re-programed for the new MAF. How hard is it to clean the IACV ? Thanks.
seesole
Aug 26, 2015 11:22 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
sc10692
Aug 9, 2015 09:37 AM
kirkhilles
Aug 8, 2015 10:53 AM
Gsantos79
Aug 8, 2015 07:41 AM
