remote start question
Old Jan 5, 2007 | 07:07 AM
cwb23's Avatar
I just had a remote start along with the immobilizer bypass installed in my 2003 max. Well after we got everything wire and the car starting with the remote i noticed that when using the remote start the fan motor is not coming on. Which basically defeats the purpose for the thing. Anyone run into this problem or have a fix for me.
Old Jan 5, 2007 | 08:21 AM
lowincash's Avatar
No More Maxipad
what fan motor? if your car's not hot then the fan won't come on...i thought the fan was to turn on if the engine is too hot and to cool it off. so if in the morning when you're warming up the car with the remote start the fan won't come on since the engine is not hot yet. that's what i'm guessing.
Old Jan 5, 2007 | 11:10 AM
cwb23's Avatar
I'm sorry,,,,,,,,, i meant the fan motor that blows out hot and cold air out of the vents. When the car is started with the remote and the climate control previously set to heat up the inside of the car i get no air circulating. Everything is lit up and set on high. Must be a wire.
Old Jan 18, 2008 | 06:45 AM
Bborges's Avatar
Has anyone solved this thing?
I am not sure if the OP explained correctly, but what happens is: when remotely starting the car, and WITH the climate control on "AUTO", the fan won't run till you get inside the car and place the key in the ignition. It has nothing to do with the motor not being warmed up enough, I tested every possible way.
Is that an accessory wire that was connected wrongly or just the way the maximas climate control behaves with the remote starts?
TIA !
Old Jan 18, 2008 | 07:24 AM
Iceman420's Avatar
(insert witty one liner)
I have a remote car starter and I just leave the car set to ECON.
No problems with the car not heating up or the fans not turning on.
I have never tried on AUTO, so I can't speak to that.
Old Jan 18, 2008 | 08:21 AM
Bborges's Avatar
hmm... weird that you never tried it in the auto mode... maybe u dont have a harsh winter? I ask that, because i had the impression the ECON was an energy-saver mode for the summer time... and it is useless in the winter.
Anyhow, I can't tell i tried the ECON mode, but I doubt it will make a difference because in the AUTO mode, the lighting in the temperature controls all lit regularly, even the fan speed is shown, but there is no fan running... till I insert the key in the ignition... really weird...
Old Jan 18, 2008 | 08:48 AM
Deckdout2's Avatar
Play with my balls
I think that's just how it acts. Mine did the same thing. Must be a relay switch tied in the the ignition somewhere and has to physically be turned to a specific position.
Old Jan 18, 2008 | 08:51 AM
jeff5347's Avatar
i have no problem with mine. We get bad winters and freezing below zero temps. I leave the HVAc on 90 degress with 3 fans blades of speed and have it set to defrost and the floor. the minute i hit the remote start car turns on and thre fan gets going. By the time i get in to go the car is toasty warm and the windows are free from ice. Ive used it in the summer with AC and works perfect then too.
Old Jan 18, 2008 | 08:58 AM
Iceman420's Avatar
Not quite. The ECON mode doesn't use the AC compressor, but does still use the heater.
So, IMO it's better in the winter as you don't need the compressor running to heat your car.
I live in Canada and see -20 deg C temps on a very regular basis and as cold as -35 once or twice a year.
I have always used ECON to heat my car and have never had a problem.
Old Jan 18, 2008 | 09:06 AM
Deckdout2's Avatar
Play with my balls
I'm assuming you have it set on Manual, correct? I think the relation was in reference to leaving it in the "AUTO" position. I would figure any HVAC setting would have the same outcome though (to work) if the circuitry is tied to perform the same. Stupid Nissan....
Old Jan 18, 2008 | 09:26 AM
ICEMAN76's Avatar
+1. The manual says something about don't turn Econ to a temp lower than the outside temp, or something to that effect. Mainly to be used in cold temp so that you don't have to turn on compressor like iceman 420 said.
Also if you have it set to heat it usually takes a while b/c the engine does need to warm up b4 it will kick out any heat. I did it last night. 19 degrees took almost 5 mins b4 2 fan blades showed up.
jeff5347's Avatar
ahhh my bad... no i never tried it in Econ or Auto. I should try that to see if it works...
Old Jan 18, 2008 | 10:35 AM
nsnrider's Avatar
go back and recheck your wiring, you forgot to power the second accessory wire. I installed a remote strarter myself on my car and did just that, notices fan was not working, went back that night and added a jumper from accessory one to accessory two and now everything works perfect.
Old Jan 18, 2008 | 02:09 PM
loeborg's Avatar
Heater
I have 2 2k2's and both of them act the same way when set to auto. Fan does not come on until the engine has sufficiently warmed up to put out warm air. Thought both cars had bad auto electronics but seems to me that Nissan did the right thing.
Old Jan 18, 2008 | 05:16 PM
nsnrider's Avatar
if you're talking about the auto fan settings, then yes, the car has to warm up at least a bit for the fan to kick into 1st setting, and as it progresses to warm up, it increases the fan settings. But I thing the OP was talking about his fan not turning on period when the car was running in remote start mode, in that case, refer to my earlier post.
Old Jan 18, 2008 | 05:40 PM
meccanoble's Avatar
Sports Button FTW
which alarm is this?
I have a clifford pager remote installed by Pearl96max and have never had issues with it. I get heat and everything. I believe it works on auto too, never seen a situation that it didnt blow air....
when cold my air automatically comes on so i'm not sure what some of u may be referring to. I haven an 01 though....
Old Jan 18, 2008 | 08:47 PM
zhiqui86's Avatar
A remote starter would be pretty nice in my maxima considering Maine weather ...how much does it cost roughly to get it installed? is it easy to install yourself?
Old Jan 19, 2008 | 07:07 AM
nismowolfe's Avatar
Thats how mine works I just figured its like the above comment. There is no use for your car to blow out cold air. When the engine reaches a certain temp then it will blow out the hot air. I like this feature.
Old Jan 19, 2008 | 08:26 PM
Jcali2121's Avatar
hmmmmm...
Old Jan 21, 2008 | 09:42 AM
Bborges's Avatar
I brought the issue to the installer (another org member) and he said it must be the accessory wire, like you pointed out. Now, I dunno about the jumpers, i'll forward your post to him.
thanks!
Old Jan 21, 2008 | 09:47 AM
nsnrider's Avatar
some cars have one accessory wire, other more, our maximas have two, he might have forgoten to hook it up or might be a bad/loose connection. good luck.
Old Dec 5, 2012 | 01:33 PM
SkyGeek's Avatar
Modules Needed?
So I'm finding conflicting reports in my searching over the last few days. I'm looking at the Crimestopper RS4-G3r remote start system. I like it because it's small, inexpensive and simple. I just need remote start nothing fancy.
So I cannot find a definitive answer of do I need an imobilizer bypass or not? Some of the wiring diagrams don't show one some do, some people list them with their purchases some don't. Would like to install this before it gets cold.
Thanks everyone!!
Old Dec 6, 2012 | 02:42 PM
cjandura's Avatar
Thanks everyone!!
Yes get the idatalink for nis/infin
Sent from AznRyan's Cat Farm
Old Feb 4, 2013 | 04:28 PM
alcaponed's Avatar
Sorry for the bump and everything, but I was poking around the owner manual for my 2001 I30 and it said that the Auto climate control doesn't start immediately to reduce drag on the alternator. It sits with the fan off for a minute or so, then SLOWLY starts to blow air out. I only notice the delay with a cold engine though. If I start the car on a hot-ish day, the AC works almost immediately.
Old Feb 4, 2013 | 06:11 PM
foodmanry's Avatar
Da Roller Coaster!
Normal. The climate control understand you don't want to blow colder air from the outside into the cabin which is warmer if you are trying to warm up the cabin. It is a smart car...I'm sure you find, one the car is warm the fan starts immediately, right?
Old Feb 4, 2013 | 06:31 PM
mau108's Avatar
yup the climate control is auto. On my 5th gen even if I start with the key in the ignition (or remote start) if the motor is cold it won't blow anything until the coolant reaches a certain temp.
I have mine on ECON or manual with windshield defrost and foot mode.
Old Feb 8, 2013 | 02:07 PM
alcaponed's Avatar
lol my point was that the car isn't really that smart. It's just trying to save the alternator by waiting to turn the heater on until it eventually warms up. Even when the fans first start going, the air isn't always warm (if the outside temperature is really low).
Old Feb 8, 2013 | 02:30 PM
cjandura's Avatar
You can use the timed trigger output on a viper alarm to set it to turn on the heater 5 minutes after starting i have a complete set of wiring diagrams for maximas if needed and btw our cars have 3 acc lines and they all need bypass modules either xk 05 or idatalink
Old Feb 9, 2013 | 07:28 PM
quick-e's Avatar
Hey fellaz, how hard is it to install? I did one on my bike and familiar with wiring but never installed a car alarm. Cjandura how much you looking for wiring diagrams? I am very interested.
Old Nov 16, 2014 | 08:13 PM
cdoublejj's Avatar
is it possible to have a remote start with 1 key fob and not compromise the security/Immobilizer?
Old Nov 17, 2014 | 04:15 AM
The_Fixer's Avatar
Yes 1 fob and a bypass module like that guy cjandura talks about
Old Nov 18, 2014 | 01:59 PM
cdoublejj's Avatar
and the by pass module doesn't make it any easier to seal the car or hack the security system with those new radio signal scanners they have these days? how expensive is such a kit?
rbuswell
Nov 17, 2016 04:54 AM
ah2002
Mar 9, 2016 01:42 PM
doobadoo
Aug 15, 2015 06:43 PM
maximaham
Aug 7, 2015 01:11 PM
Jcof88
Aug 3, 2015 10:43 PM
