how do you tell if ur rotors are warped?
Old Jul 4, 2001 | 11:16 AM
ToYLeT902's Avatar
JET Speed Lab
mine have goldish streaks on them. my car is about 3-4 weeks old with 1080 miles on it. how do you tell if they are warped or not? it happened to my friends max in about a year of buying it. by the way, anyone notice i wasn't on the forum for a while? didn't think so.. anyway i was upstate in a buddist camp. met a bunch of nice people and when i got back washed my max cause the roads up there are rocky and DIRTY! anyone miss me? hehe
Old Jul 4, 2001 | 11:38 AM
UMD_MaxSE's Avatar
Got Bent?
One major sign of warped rotors is a vibration felt in the steering wheel when you apply the brakes at highway speeds. It is quite noriceable and may even be present at lower speeds. I doubt your rotors would be warped with only 1k miles.....
Old Jul 4, 2001 | 12:19 PM
DeaZaL's Avatar
wow... i think mine are warped?? i have 10 k.. and I feel a vibration.. not sure though.. I only feel a vibration if i am speeding and then brake abruptly.. like 90 to 60.. are they warped???
Old Jul 4, 2001 | 12:46 PM
fatboyp's Avatar
yep sounds like they're warped. There's a TSB to get it fixed. Check in the sticky area.
Old Jul 4, 2001 | 01:00 PM
punkdork's Avatar
smart@ss answer to the question...
If you have a 5th gen max. then your rotors are warped.
Old Jul 4, 2001 | 01:06 PM
Ludacris's Avatar
if we take it into the dealer to get the brakes fixed under the TSB should we print the TSB out and show it to them, or just mention the brake rotor warp TSB?
Old Jul 4, 2001 | 01:13 PM
UMD_MaxSE's Avatar
Got Bent?
try and just mentiont it first to see if they will take care of it without any hassles. If they give you trouble, then show it to them. My dealer just did it without the TSB.
Old Jul 4, 2001 | 04:23 PM
TimW's Avatar
The silent but deadly Moderator
or....
its pretty dangerous to do without a lift, but with the car in neutral, sometimes you can simply spin the tire and hear it grind alittle more when it passes the warped part of the rotor. By grind, I mean that the pads usually close enough to the rotor that you will feel or hear it rub unevenly.
I would say tho, that once you are this far out of spec, that its easily reproduced on the road.
For me, I have a freakin Toyo slightly out of round. so my vibe is from that.
Old Jul 4, 2001 | 04:31 PM
irvine78's Avatar
just get after market(Brembo/PowerStop) rotors...they cost about the same as the replacement OEC rotors but they don't warp as much as the stockers...the stockers are sooo prone to warping..one quick spay of water at car wash...and bam! you have warped rotors...
Old Jul 4, 2001 | 05:11 PM
Paul6speed's Avatar
My 2nd set of rotors are going already. Why didn't Nissan use larger rotors on the 5th gen? They are thicker, but not bigger.
Old Jul 4, 2001 | 05:13 PM
UMD_MaxSE's Avatar
Got Bent?
are you going to take it back to the dealer? You think Gaithersburg Nissan will take care of you this time around? They are under new management, so I don't know
Old Jul 4, 2001 | 05:38 PM
Paul6speed's Avatar
Supposedly that brake TSB is good for 36,000 miles. I may wait a while and wait until it's more obvious. It's definitely happening, but I don't want any doubt in the situation. I have 20,000 miles right now. If they don't take care of me, I'll raise hell. (Yeah right, I'm such a wimp.)
Old Jul 4, 2001 | 07:13 PM
DieselFX82's Avatar
I heard this from a brake specialist! I thaught what a bunch of B.S!! But here it is! he said " Your brakes are warped because your car is set on a 60/40 brake offset. 60% in the front and 40% in the back." He also said "try this when your car is parked put your emergency brake on! This will use up your rear brakes{only atx}." I was like wtf? are we using our brakes too hard?
Old Jul 4, 2001 | 07:22 PM
LoveSick's Avatar
Hey guys, my steering vibrates so much that it freaked me out the other day. even when going from 30-0. What is the cause of wrap? I mean, I never slam on my brakes, but I just use them reguarly. My dad would kill me if he knows I wrecked his car. What can I do?
I am currently short of cash.
Old Jul 4, 2001 | 07:30 PM
DieselFX82's Avatar
warranty brother send it to nissan! Don't tell your dad
Old Jul 4, 2001 | 09:04 PM
Max_5gen's Avatar
Bring it to your dealer ASAP. This vibration is not good for your front bearings. Don't take any BS regarding your "hard brake use" - there is TSB and they HAVE TO fix it under warranty. In my case though, it was cheaper to DIY than to fight with dealers .
Old Jul 5, 2001 | 03:18 PM
augie's Avatar
When I took my car to service, they said it was 18" rims and because I lowered my car about an inch with my eibach springs. He said to put back everything back stock and if I the problem occurs again, he would honor my warranty. That is funked up.
Old Jul 5, 2001 | 05:38 PM
UMD_MaxSE's Avatar
Got Bent?
Thats BS....lowering should not affect brakes. New wheels should not either if they are torqued to the right spec.
Old Jul 5, 2001 | 06:58 PM
augie's Avatar
Yeah...thats what I think to. Lowering should not have any effect, plus I have my wheels torqued to the specs. I should take my TSB bulletin and tell him to beat it.
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
