Interesting problem:
Old Jan 21, 2007 | 09:38 PM
MaxBoost925's Avatar
Drug Money
I replaced my tranny and installed headers on my car.
My car is cali-spec so I supposedly have 4 o2 sensors: 2 primary and 2 secondary.
Apparently I plugged in a secondary sensor into the header and disconnected the primary. My car runs, but it has a 2750rpm fuel cut. It acts normal up to that RPM.
What I did was I replugged all the o2 sensors back in (but the secondary is still in the header) the primary is chillin' outside on top of my engine cover and the other secondary is chillin' on top of my cover as well.
My question is: Is the car able to run without o2 sensors? If so why is my car not running correctly? I don't see any smoke coming out of my exhaust meaning that it is running approximately stoich.
I can get it to rev over 2750 and drive normally when I either stall out the car or shut it off and start it again.
It's strange
Any input?
Old Jan 22, 2007 | 07:22 AM
Drug Money
nobody?
10 char
Old Jan 22, 2007 | 08:16 AM
SoonerFan's Avatar
Cletus
you need both sensors.
the car has retarded itself to reduce emissions since the ECU isnt getting the correct signals it need to regulate the air/fuel mixture.
Old Jan 23, 2007 | 06:19 PM
Drug Money
It ended up being the EGR lol. Car cannot run correctly without the EGR sensor module.
FYI for all of Maxima.org
Old Jan 23, 2007 | 06:51 PM
carsarecool's Avatar
haha nice, now for us 3.0 guys some 00-early 01 models had egr and some didnt right? but all later 01's did?
Old Jan 23, 2007 | 07:32 PM
NmexMAX's Avatar
dot dot dot ...
Even though you already figured it out...
I have been running my secondaries plugged into my headers (in place of primaries) and my primary sensors are sitting under my bed for 2 years now w/o nothing but a CEL. Still the same mileage and plenty power.
Old Jan 23, 2007 | 10:55 PM
A33 VQ30DEK's Avatar
2k1s don't have an egr.
Old Jan 24, 2007 | 06:57 AM
platinum03SE
wouldn't you want to keep your primary's and loose the secondaries?
and it still runs fine and good fuel mileage?
Old Jan 24, 2007 | 07:01 AM
amomaxima's Avatar
try the the throttle relearn prodcedure. had the same problem when i removed my ECU. dont know but you can try it it helped me out
Old Jan 24, 2007 | 07:14 AM
Drug Money
um. i just posted that it was a simple EGR sensor.
Old Jan 24, 2007 | 07:17 AM
NmexMAX's Avatar
dot dot dot ...
Explain
I get the same mileage as I did before. Aside from the MIL, it's the same.
Old Jan 24, 2007 | 07:19 AM
platinum03SE
Explain
no i dont know i was asking you for some advice
Old Jan 24, 2007 | 11:06 AM
vq356sp's Avatar
El Mas Noob Del Org.
Thats funny Im the other way around, I have my primaries but my secondaries are in my garage somewhere
Before you posted this I had no idea it could be done that way
SES FTW
Turbonut
46
Oct 21, 2015 08:28 PM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
ToTheMax305
Sep 23, 2015 09:11 PM
dcam0326
Sep 18, 2015 04:52 PM
