Low Pressure in Window Washer Fluid Nossle
Old Jan 29, 2007 | 11:29 AM
Nismo98's Avatar
Did anyone have any experience with window washer fluid being sprayed with low pressure. I am thinking that the motor might be going out, or my line could be clogged somewhere. Anybody has any other ideas in regard to this matter?
Andrei
Old Jan 29, 2007 | 11:57 AM
djfrestyl's Avatar
Suspension Yoda
I'd attribute it more towards debris in the line than the motor going.
Old Jan 29, 2007 | 12:01 PM
Nismo98's Avatar
What would be the best way to pressure purge the line, any ideas?
Andrei
Old Jan 29, 2007 | 12:16 PM
tsk808's Avatar
can't you just look under the hood, find where the tubes run, see if there's a way to disconnect it from the reservoir and suck?
Old Jan 29, 2007 | 12:40 PM
SoonerFan's Avatar
Cletus
you probably have something stuck in the nozzle. your owners manual will tell you to poke it with a pin.
Old Jan 29, 2007 | 01:24 PM
Nismo98's Avatar
The problem is that both of the nozzles (4 holes) are giving out spay under low pressure. The only good thing a pin or needle will be good for, is adjusting the position where the nozzle will spay the fluid onto the windshield.
Andrei
Old Jan 29, 2007 | 06:47 PM
djfrestyl's Avatar
Suspension Yoda
Andrei
It's not under much pressure at all, and it's just wiper fluid anyway. There should be a T or Y in the tube near the firewall. Disconnect it there.
Old Jan 30, 2007 | 08:57 AM
wngan9447's Avatar
Chicken Feet Croo!
shot in the dark... is your fluid frozen?
Old Jan 30, 2007 | 09:26 AM
Nismo98's Avatar
I did see the split on the passenger side of the car, will have to put the compressor to good use.
It's been pretty cold in Chicago, but not that cold. Plus the fluid didn't look thick when is was on the hood, because that's as far as it wood spay.
Andrei
markevans999
Sep 10, 2015 04:29 PM
ag90fox
Sep 9, 2015 12:22 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
