P0507 solved yet again
Old Feb 1, 2007 | 05:43 PM
maximaownsyou's Avatar
i had the dreaded p0507 high idle rpm as many people have had on here.
i know there has been fixes, i just wanted to add insight as to what solved mine. as you all very well know the code is caused because the throttle body sensed a foreign substance entered it. thus throwing a code that cannot be erased by the steps in the sticky. i talked to a local dealer and let him know the situation and how much i thought it was a rip for us to have to pay because of something nissan caused in the first place, i think the conversation actually helped. he only charged me $49 for a consult ecu reset + consult idle air relearn procedure and 30 minutes later my idle was perfect... 750-800 and the car runs so much nicer. just thought i would let you guys know that the consult yet again fixed the p0507
Old Feb 2, 2007 | 06:11 AM
Jason_03_Max's Avatar
Glad you got your issue fixed....
Did you notice that your transmission had a downshifting surge that many of us have had after getting this code? If so, did that problem go after after the consult ecu reset? I got the code to go way and the idle back to normal but still experience the engine surging while I slow down to a stop.
Old Feb 2, 2007 | 06:48 PM
yeah it went away it dosent "surge" when i stop at a light anymore and it did when i had that code
Old Feb 3, 2007 | 02:50 AM
artin64's Avatar
ya i have the same issue i got rid of the code but still got that surge when i slow down.
Old Feb 3, 2007 | 05:40 AM
yep, almost seemed like the car bucked back a little before it stopped completely? thats what i had regarding that issue. i tell you what though i swear by this... i bet you we lost 5-8 mpg because of that code... im getting really good gas mileage again like i use to... 360-400 miles per tank... when i had that code i was only getting like 250-300 miles per tank
Old Feb 3, 2007 | 06:01 AM
artin64's Avatar
thanx for the info man big help, ill try it with the consult II see if i can get rid of that surging.
James92SE
142
Jan 2, 2024 09:23 AM
AnsonJ
Jun 2, 2017 01:35 PM
97_GXE
20
Sep 17, 2015 08:12 PM
terrell137
May 7, 2001 04:53 PM
