vafc-II
Old Feb 12, 2007 | 10:35 AM
absoundlab
vafc-II
I need some help installing a vafc-II on a 2000 maxima 3.0l
Old Feb 12, 2007 | 10:37 AM
VQ'ed's Avatar
check the v-afc2 in a 99es thread, it may help you throughout the whole process.
Old Feb 12, 2007 | 12:48 PM
NmexMAX's Avatar
dot dot dot ...
What kind of info?
All you need is a wiring diagram for your car, and the VAFC diagram.
It should be a walk in the park after that. The diagrams have already been shown to you.
Old Feb 12, 2007 | 01:46 PM
absoundlab
I cant find a wiring diagram for a 2000 nissan maxima 5 speed 3.0L
Old Feb 12, 2007 | 02:57 PM
NmexMAX's Avatar
dot dot dot ...
Get/DL the FSM
Old Feb 12, 2007 | 03:05 PM
absoundlab
whats d/l?.....
Old Feb 12, 2007 | 05:48 PM
Mad-MAX_SE's Avatar
Still kickin'
download
Old Feb 12, 2007 | 06:24 PM
absoundlab
i have a 2000 fsm
Old Feb 12, 2007 | 06:26 PM
Puppetmaster's Avatar
How many times do you have to start a thread for this? Esp when information has already been posted for you in the past.
http://forums.maxima.org/showthread.php?t=505457
http://forums.maxima.org/showthread.php?t=505842
Old Feb 12, 2007 | 07:53 PM
absoundlab
I keep posting because I still have not got a clear answer.
Old Feb 12, 2007 | 08:38 PM
2k1maxgle's Avatar
......Why would you want a VAFC II for a Maxima?? I thought the VAFC was for Hondas with VTEC (hence the name VAFC) used as a VTEC controller...Isnt the SAFC II what you would want in a Maxima??? I could be wrong, maybe someone has discovered a new use for these in our cars??
Old Feb 12, 2007 | 08:44 PM
Not to be smart, but I think its because you have failed to give us clear question. Honestly, your first post in this thread is not informative at all:
Trust me, everything you need for the install is in the two threads above.
Old Feb 12, 2007 | 08:46 PM
The VAFC-II can be used on Maximas. It can be set up to have more tuning points than the SAFC-II, which is one of the main reasons it is preferred to the SAFC-II.
Some info here:
http://forums.maxima.org/showthread.php?t=463936
http://forums.maxima.org/showthread.php?t=461576
http://forums.maxima.org/showthread.php?t=466165
Old Feb 12, 2007 | 09:01 PM
2k1maxgle's Avatar
Some info here:
Cool man...I just didnt know. Thats new info to me!!
Old Feb 13, 2007 | 06:27 AM
NmexMAX's Avatar
dot dot dot ...
VAFC wire color codes: s0ber
http://forums.maxima.org/showpost.ph...68&postcount=2
How to splice a wire: Jime
http://forums.maxima.org/showpost.ph...1&postcount=11
Good advice: SR20DEN
http://forums.maxima.org/showpost.ph...33&postcount=3
Where all this wonderful information came from:
http://forums.maxima.org/showthread.php?t=446558
Old Feb 13, 2007 | 11:43 AM
Cutler's Avatar
This doesn't need to be in All-Motor, it's going to 5th gen forum.
Old Feb 13, 2007 | 11:51 AM
ShIft_uR FacE's Avatar
Is this any good on a relatively stock car? Or wait till mods....i/h/e/udp/..etc.
Old Feb 13, 2007 | 12:00 PM
SoonerFan's Avatar
Cletus
and a new thread will change that?
you want us to solve a problem for you...but have yet to tell us what the problem is.
Old Feb 13, 2007 | 12:25 PM
Depends on your AF... it can help both stock or modded cars....
Old Feb 13, 2007 | 07:49 PM
vinny's Avatar
i am not trying to be messy but i have to say this absoundlab i know what you mean and sympathize. i posted two seperate threads on needing help hooking up an 02 simulator. people did not realize my car is a little different than the other maximas so those instructions were not all the way correct for me. I posted picturesand i even tried to pm and for the most part criticism is what i recieved. i know people here have the information that is needed for peoples problem but for there own selfish reasons attempt to make it difficult. everybody should realize that they were a newbie at some point and i do not consider myself a newbie.
Old Feb 13, 2007 | 08:16 PM
The Law's Avatar
I R The Law
First of all, absoundlab made about 4 other threads asking the same damn question with out specifying what he wanted. How the hell are we going to help somebody who keeps reposting the same thing 4 or 5 other times? Also I bet you didn't do your own research and that is why you created 2 seperate thread in which case they critized you.
I was a newbie at one point and I did all the search myself until I really needed help in which case I took it all to PMs asking a certain few people who I knew would know the answers. I didn't make repeated threads with stupid questions that are
repeated.
Puppet or any other mod. Please lock this thread.
Old Feb 13, 2007 | 09:20 PM
absoundlab
ok I have a 2000 nissan maxima 5spd 3.0l and I have an apexi vafc2 I'm looking for a 2000 wiring diagram.8 looked on apexi website and I don't understand it. also all the wiring diagrams I found here on the forum they aren't for my car they are for the 5.5 gen maximas . its not that I don't want to do research, I've done so much already and havebt found anythibg good. so I'm asking fellow orgers for help I know people know how to do this bcuz I've seen it on other 5 th gens thank you
Old Feb 13, 2007 | 11:22 PM
Mass_Media's Avatar
Mass_Media™
EDIT:
Dude there is more than enough information in this thread....Nmex got it for you....
Old Feb 14, 2007 | 12:13 AM
absoundlab
all the infor is for a 5.5gen
Old Feb 14, 2007 | 03:20 AM
The wires to tap for a 5.5 will be the same for a 5th Gen, just the pins have a different number on the ECM.
1. Take 5.5 Gen VAFC-II install diagram
2. Find corresponding ECM pinout for 2000 using FSM, also given to you by NMexmax in one of his links: http://forums.maxima.org/showpost.ph...2&postcount=12
3. Use two guides above to install VAFC-II
4. ???
5. Profit
skweaky
Oct 21, 2013 06:52 PM
seanwn
Aug 1, 2012 10:53 AM
SR20DEN
May 19, 2011 11:55 PM
Unklejoe
Jul 12, 2010 12:08 AM
absoundlab
Jan 16, 2007 12:45 AM
