Does Cattman Y-pipe have a distinctive sound
Old Feb 12, 2007 | 02:38 PM
steelymatt's Avatar
Hi,
I'm considering getting a Cattman y-pipe to replace my precat. If I leave everything else in the exhaust stock, will the sound change at all?
Thanks.
Old Feb 12, 2007 | 02:39 PM
SoonerFan's Avatar
Cletus
Originally Posted by steelymatt
Hi,
Thanks.
yes...you will have a deeper growl under acceleration. check the exhaust sticky for sound clips.
Old Feb 12, 2007 | 03:32 PM
steelymatt's Avatar
I couldn't find just a y-pipe sound in the sticky. There were too many combos.
Old Feb 12, 2007 | 04:20 PM
SoonerFan's Avatar
Cletus
i cant find the clip of my 00 with just a y-pipe but is was loud (in a good way). nice subtle deep sound while cruising and a deep growl under WOT
Old Feb 12, 2007 | 04:47 PM
Pri63's Avatar
I'll get one for you...give me a day or two
Old Feb 12, 2007 | 05:29 PM
xxbeats's Avatar
it will be louder. i like it!
Old Feb 12, 2007 | 05:53 PM
Pri63's Avatar
Just ran down and recorded a quick clip...check it.
http://picasaweb.google.com/Pritesh....27782480386402
Old Feb 12, 2007 | 06:02 PM
SoonerFan's Avatar
Cletus
the good sound really comes under load
Old Feb 12, 2007 | 06:12 PM
Snolife's Avatar
What we have here is a failure to communicate
FYI, Once I get my headers, I will have one available to sale.
Old Feb 12, 2007 | 06:13 PM
SoonerFan's Avatar
Cletus
wont work on his car
Old Feb 12, 2007 | 07:28 PM
Snolife's Avatar
Yeah, I over looked that, thanks.
Old Feb 12, 2007 | 09:03 PM
Puppetmaster's Avatar
Hi,
Thanks.
It will change slightly, as already noted by others.
Btw, which pre-cat is bad? Your 2001 should be Cali spec and only the rear precat is in the y-pipe. The front precat is between the front exhaust manifold and the y-pipe, so replacing the y-pipe won't do anything to help that.
See diagram below:
Old Feb 12, 2007 | 09:53 PM
steelymatt's Avatar
See diagram below:
I don't know. This is exactly where I need your expertise. I'm pulling the P0420 code. I thought this pointed to the precat (the one towards the front of the car). So I figured rather than buying a new precat for $460 I could just buy the y-pipe for $350, which I thought replaces the precat. Do I have this right? I wish someone could clarify this for me. Thanks.
Old Feb 13, 2007 | 04:05 AM
You should be fine then. The code P0420 is for Bank 1, which is the rear bank. The Bank 1 precat is the one on the y-pipe, so a replacement y-pipe should solve your problem.
Old Feb 13, 2007 | 04:36 AM
steelymatt's Avatar
Thanks for the clip!!
Mahmuth
Aug 16, 2024 08:23 PM
AaronL
Aug 8, 2020 10:31 AM
Quickywd01
Sep 21, 2016 09:36 PM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
