6spd trans mount ?
Old Feb 12, 2007 | 02:57 PM
MAXSE5SPD's Avatar
6spd trans mount ?
im having trouble figuring out my mount situation. does anyone know if the housings for the 02-03 and 04+ 6spds are the same? because the nissan fast doesnt show the mount that bolts to the frame, but it does for the 04+, so i was wondering if i could use an 04+ mount setup on an 03 housing.
Old Feb 12, 2007 | 03:06 PM
MAXSE5SPD's Avatar
A34 11220m is what i need
A33b
Old Feb 12, 2007 | 06:16 PM
MAXSE5SPD's Avatar
bump........
Old Feb 13, 2007 | 05:12 AM
Derrick2k2SE's Avatar
The trannys are the same and can be swapped back and forth with no modification. The mount will work with the tranny as long as it bolts up in the car the same way. I put the 04 tranny in my 02 without changing anything. I used the 02 mount.
Old Feb 13, 2007 | 09:05 AM
MAXSE5SPD's Avatar
did you use the 02 mount that bolts to the trans? can you snap a pic of your mount setup for me? i would greatly appreciate it.
Old Feb 13, 2007 | 06:32 PM
Hope these help.
Old Feb 17, 2007 | 05:10 PM
MAXSE5SPD's Avatar
NEW PROBLEM: the a33b trans bracket that sits on the trans (11253n) is back ordered and they do not have an arrival date. so im wondering if i can mix and match mounts. can a a33b trans insulator work with an a34 trans bracket?
Old Feb 17, 2007 | 05:48 PM
maxspeed96CT's Avatar
The original VQ...
MAXSE5SPD , i like your car , looks exactly like mine .....
but its a 4th gen ......
soooo nice !
Old Feb 17, 2007 | 08:30 PM
The brackets are the same. When the salvage yard pulled the 04 tranny they cut the hydrolic line to the slave and spilled fluid all over the bracket. By the time I got it it was all rusted so I used the one from my 02. If I had kept it I'd let you have it but I put it on the old tranny and sold it to a rebuild shop. It just needed to be cleaned up a bit.
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Oct 7, 2015 10:47 PM
ef9
Oct 4, 2015 08:43 AM
