cattman catback clunking
Old Feb 21, 2007 | 08:01 PM
knight_yyz's Avatar
Toolie
Hey guys, anyone have a picture of the b-pipe installed properly? My catback is banging on the little crossmember at the rear "axle" and Brian suggested the resonator section might be upside down. With no instructions how are we to know which is right side up? I'm wondering if it might even be backwards end to end? Any photos would be appreciated. I've searched for photos and found people have had the same problem, I don't want to pay an exhaust guy to install this two or 3 more times. Trial and error method doesn't cut it for me. Thanks in advance
Old Feb 21, 2007 | 10:45 PM
reeloop's Avatar
you may just need new exhaust hangers
Old Feb 21, 2007 | 10:49 PM
NmexMAX's Avatar
dot dot dot ...
Instead of new hangars, why not get under there and use hose clamps to tighten up the existing connections.
I had the same clunk, got some hose clamps, problem fixed.
Old Feb 22, 2007 | 06:51 AM
upstatemax's Avatar
It is an easy fix.
Old Feb 22, 2007 | 07:31 AM
knight_yyz's Avatar
Toolie
because if it is on upside down or backwards I'd rather have it on the right way.
Old Feb 22, 2007 | 08:13 AM
RLW001's Avatar
Just remove it. I have the full Cattman system and there was no-way to make it fit w/o it hitting. The stock system had huge reliefs to clear the cross members.
Old Feb 22, 2007 | 08:34 AM
Snolife's Avatar
What we have here is a failure to communicate
I had the same problem. I took it to a shop and they bent it back a little and it seemed to work. Mine was coming from this area, not sure if yours is or not. Sorry for such a big pic.
Old Feb 22, 2007 | 09:01 AM
00MaxSE's Avatar
Pointy Elbows
I used to have the clunkig noise, but I have the Budget Bpipe w/ the Cattman rear. I changed the hangers and it seemed to go away.
What is this hose clamp fix you speak of? My exhaust tips are hitting the right side of my Stillen rear valence and I was going to take off the valance and readjust it in the spring. Could hose clamps fix that problem?
Old Feb 22, 2007 | 11:28 AM
knight_yyz's Avatar
Toolie
Don;t tell Brian that. "It fits perfectly if its installed correctly"
Old Feb 22, 2007 | 11:30 AM
knight_yyz's Avatar
Toolie
That is exactly my problem. Brian says the instruction manual tells you how to orient the resonator correctly. I have no idea if it does or not since I didn't get any instructions. Now I have to put it back on a hoist to see if it is on right or not.
Old Feb 22, 2007 | 06:08 PM
inspiredbykev's Avatar
You should thank my D***
I bought the nismo bushings, expensive but a lot stiffer. Sometime when I do a burnout you hear the clunk. I tried tightening it more with hose clamps but no matter what once in a while you will hear the clunk. Let me know what you end up doing and if it solves the problem.
Old Feb 22, 2007 | 06:43 PM
nissan5788's Avatar
I removed that crossmember 40k mi. ago..couldn't be bothered to tighten things up (car's too low to get under w/o ramps). Don't waste money on the Nismo hangers..can achieve the same result w/hose clamps.
Old Feb 23, 2007 | 02:39 PM
knight_yyz's Avatar
Toolie
I found out the fix. There is a very small pea sized weld bead at the front of the resonator about 2 inches behind the flange. If you go under the car and can see the little dot, you resonator is upside down. The dot faces up. Did that today and the clunking is gone, and lines up a lot better.
Old Feb 23, 2007 | 02:44 PM
nice I got to check mine out this weekend
Old Feb 23, 2007 | 02:57 PM
knight_yyz's Avatar
Toolie
bty, sorry for the huge pic, I thought it would have been much smaller
Unclejunebug
Apr 2, 2016 05:42 AM
Justin Kroll
Oct 1, 2015 07:03 PM
Chaka
Sep 17, 2015 09:53 AM
