Stereo Removal - Running into problems...
So, I need to take out my stereo... I have search extensively and found some great How To's... BUT...
Step 1 in all of them is take OFF the top VENT. They all say JUST put your fingers in and PULL... I have BIG fingers at 6'3" 265lbs, I am a big guy.
I tried it anyway and broke something or pulled it out of place more than likely, when I jammed my thick fingers in... Any ideas, tips or tricks...
I would usually not create a thread for this, but already sort of broke something and do not want to break anything more...
Yeah, it makes a hell of a breaking-plastic sound, but it will come out. Use two thin flat-blade drivers - with a cloth around the end if you can fit it - and carefully work them into the gap between the stereo and the vent. Lift up on the vent as you insert the drivers and once you have the gap opened up sufficiently (say 1/4 inch or so), you can start pulling it out towards you. I find it easiest to open the vents up and stick my fingers into the lowest vent and hook them behind the plastic part where the roatary ***** are and pull hard.
What you are overcoming is two plastic tabs along the top that catch behind a plastic shelf on the upper dash, two more plastic tabs on each side that also hook behind a plastic section of dash running down each side, and two larger metal tabs on the bottom that hook behind the metal frame holding the stereo/HVAC controls. It's these bottom ones that can really hold well, so that's why the screwdriver lift is kind of needed before you pull it out toward you.
When replacing it, it inserts with almost no effort (the tabs have long, angled lead-ins to facilitate installation).
Hope this helps you a bit. It is easily the most difficult part of opening up the centre console. Removing the facia around the shifter is much easier and the stereo/HVAC just bolts into the metal frame (two bolts above and two bolts below).
Originally Posted by criddle20
But now I have my kenwood head unit in (got rid of the crappy - cut out all the time - BOSE) and my Sirius is installed and looks very professional. I might have to post a pic or something. I'm proud of my work.
This is what I did with mine, the ashtray holds it in very nicely:
Originally Posted by Dust N Bones
I'd like to see how your Sirius install looks if you have pics. What Sirius unit do you have?
and a closer shot...
what are you guys using for your front and rear stages? aftermarket speakers? are you using external amps also? just curious to see how you got around the bose integrated amp and eq setup? Sorry, I used to be a 3rd gener just purchased a 5th gen 2000k SE
I'm running the stock speaker/amp setup... and to do that I'm using a part from Crutchfield (http://www.crutchfield.com/S-llHe6vV...03&i=142C4NN03) that allows you to wire the aftermarket stereo to the factory Bose setup. There are other threads on here that discuss why it is that an aftermarket HU won't wire direct to the Bose speakers/amp, but it was mostly technical stuff that I disregarded. Anyhow just get that part and go to town wiring your aftermarket unit in. It's pretty simple, just make sure you get the blue wires right (power antenna and remote/amp power)because they aren't very clearly marked and the instructions are a little wishy washy. If you switch them like I did, your speakers will only work when you are listening to the radio tuner.
The B**** part of it is getting the screws out of the side of the Bose head unit... I had to put all my weight into the thing and went thru like 3 screwdriver heads before i finally got all 8 screws out of the thing. But now I have my kenwood head unit in (got rid of the crappy - cut out all the time - BOSE) and my Sirius is installed and looks very professional. I might have to post a pic or something. I'm proud of my work.
Originally Posted by burnurass
some people actually TIGHTEN IT DOWN more to break it loose...THEN it comes off SUPER easy.
I chose to install mine in a spare center vent so the base would sit flush.
You can see more details here: http://www.siriusbackstage.com/forum...ad.php?t=96182
Wargoose
Wargoose
"I'm running the stock speaker/amp setup... and to do that I'm using a part from Crutchfield (http://www.crutchfield.com/S-llHe6vV...03&i=142C4NN03) that allows you to wire the aftermarket stereo to the factory Bose setup. There are other threads on here that discuss why it is that an aftermarket HU won't wire direct to the Bose speakers/amp, but it was mostly technical stuff that I disregarded. Anyhow just get that part and go to town wiring your aftermarket unit in. It's pretty simple, just make sure you get the blue wires right (power antenna and remote/amp power)because they aren't very clearly marked and the instructions are a little wishy washy. If you switch them like I did, your speakers will only work when you are listening to the radio tuner."
Damn those screws!
I installed my pioneer head unit this weekend and only managed to get one screw out by "regular" means.
I could only get one screw out with the pneumatic impact wrench and I had to drill out the other six screws - using 2 bits to do it. I broke one screwdriver bit and twisted two others.
All in all it took about 3 hours to get the buggers out.
The Frye
Sep 2, 2021 11:03 AM
no problems with sound quality after the install?
