SE speedo cluster swap Q
I've got an 01 AT GXE (black) speedo with chrome rings and 68k miles and I found a pretty cheap SE cluster that's 01 AT, no TCS and 38k. Questions are:
1. Direct swap and if unsure, how I could determine?
2. Bad idea because the miles will now be off without setting to my current?
3. Can I bring in the cluster the dealer and pay the 35 to adjust?
Thanks much
Thanks much
I would also like to know the answer for this one the sticky on how to replace the cluster is not working.
I read that the mileage is in the actual cluster but can anyone confirm that.
If necessary to take to the dealer to adjust the mileage what the best thing to do bring in the cluster and let them swap it or i should put on myself.
Any help would be greatly appreciated.
i did the SE cluster swap on my 01 GXE......yes the mileage is stored in the cluster itself, luckily for me i found a cluster that was only about 3,000 miles off from my actualy mileage, so i cant really answer your questions on the dealer doing anything. you're best bet is to try and find a cluster with similar mileage (easier said then done i kno, but i did it, took me about a month or 2 to find one.) it is a very easy direct swap, whole thing took me about 10 minutes to complete. well worth it in my opinion, gauges white up white with a blue ring around the outside at night, doesnt look cheesey like those indiglos. just make sure if you dont have tcs now that you get a cluster that doesnt have tcs, otherwise the slip light will be on.....
Odo just shows the ECU mileage? That would be cool, but it seems contrary to what everyone else is sayin. I suppose I'll have the dealer set it so that at least I'm legit, feels better knowing I've earned those miles.
GT
GT
GT
GT
I wouldn't put the cluster w/ 38K in the car if you have any plans on selling it. Unless the dealer can roll ahead the mileage to your current mileage, the carfax will come back as odometer fraud, unless you can drive 40K miles before the car is next inspected. If its what you really want go for it, but your resale value will drop significantly if you try and sell the car. Try and find a cluster w/ mileage near 65-75K. Im sure theres some out there.
Originally Posted by soonerfan
the mileage is stored in the ECU
the mileage will be fine...the odometer is simply a display of the number stored in the ECU.
Originally Posted by MIXXMAX
The actual mileage is stored in the cluster itself. There's a chip inside the circiutry that retains the mileage. The ECU has no bearing on the mileage. If you swap out one cluster and put in another, whatever mileage is stored within the cluster, that number will appear.
there have been many threads regarding this topic...every person that actually swapped their cluster says that the correct mileage was displayed after the swap.
IN IRAQ MAXIMA.ORG-ING :)
.... my mileage doesn't change on mine due to my tranny swap... but if ur planning on doing a cluster swap i would look into the i35 cluster with the electroluminescent gauge... they are very very nice!
So does anyone know where you can get an 01 SE white face gauge cluster? I tried ebay and googled and could not find anything....I want to replace my boring 01 GLE cluster....Like soonerfan said the mileage is definetly stored in the ECU...I know several people who have replaced the cluster and like myself I put gauge rings and bezel on my display last year and the mileage "pops" back up because it is stored in the ECU...Respect sooners opinion because he knows what he is talking about....
Ok guys i received the cluster but the seller sent me the wrong one so now i have to send it back so i could get the right one.
When i get the cluster sometime next week i will take pictures of the gxe cluster install and the SE before and after the install to see what happens.
Could i do this to my 2k?
mileage is stored in the cluster!!!!!!! not the ecu........at least on 2k1's like mine.........whatever cluster you put in there the mileage on the new cluster will show up, your ecu has nothing to do with this
i'm trying to find the thread about adjusting the mileage on the odometer. i have a 5th gen cluster and want to raise the mileage up to my 4th gen..my search option on the org is having problems..help would be appreciated. thanks
I swapped my 2k GLE cluster (build date 12/99) out with a 2001 SL cluster (build date was circa 12/00). When I first got the SE cluster I plugged it in to see what mileage was on there as the seller wasn't quite sure...just knew that it had more than what was on my car. It showed up as different than my stock GLE cluster. Herego....the mileage is stored in the cluster on both 2000 and 2001 models. 2k2 and 2k3 models could be different, but I am not sure.
Yes..you can have a dealer or Dave B. re-adjust, calibrate the mileage. If you swap a cluster out and don't do this and your mileage is very different you could end up with issues when you sell the car. I forget the specific item they call it from the DMV, but it is something about correctional mileage, etc. That pretty much puts the car at a salvage title.
releasedtruth you should check with Dave B and see if you can send him the SE cluster to get adjusted.
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
HerpDerp1919
09-29-2015 02:02 PM
