Installing Fog Light on GXE Nissan Maxima
Old 03-09-2007 | 01:21 PM
andy2248's Avatar
I have a GXE Nissan Maxima without fog lights. I would like to install some but that means I would have to do some wiring. The installation section does not say how to wire the fog lights in. How would you go about wiring fog lights in? Any suggestions would be greatly appreciated.
Old 03-09-2007 | 01:34 PM
djbonsu's Avatar
im pretty sure all you have to do is install the relay for the fog lamps if its not there and change out your turn signal switch. if you buy the foglamps from courtesy nissan, i think they come witht he harness, turn signal switch, relay, and lamps. its honeslty pretty simple.
hers where you can find them: http://www.courtesyparts.com/Merchan...de=B61E0-00001
Old 03-09-2007 | 01:45 PM
SoonerFan's Avatar
Cletus
install direction http://www.courtesyparts.com/instruc...ghtkit_01.html
the car is prewired.
the kit has everything you need
Old 03-09-2007 | 02:00 PM
djbonsu's Avatar
i guess you might need that as well.... g' luck
Old 03-10-2007 | 10:16 AM
GOLD00GXE5SPD's Avatar
RELAYS! thats it, when i installed the fogs all i needed was to put in a new (?) relay and re-wire due to rotting through all of the wires. pita imo, hopefully you'll have wires that aren't completely destroyed...best of luck !
Old 03-14-2007 | 07:39 PM
Professor's Avatar
I love you ppl, The link was perfect, I printed it for future reference, Any idea what these kits go for from a deal ? or am i better locating a nicer aftermarket direct fit set on ebay ? And what switch am i looking for in the colum to replace ?
Old 03-15-2007 | 06:23 AM
AcidJake75's Avatar
the switch box will be labeled - should be top right corner (of the relay box on left side of the car) - CANT miss it(its on the instructions as well I think) . as for the ebay question - thats up to you. one last thing - get the FSM for your car. that and this site have been a life saver for me.
Old 03-15-2007 | 07:02 AM
Professor's Avatar
Iam sorry but i dont know what a FSM is
Old 03-15-2007 | 07:10 AM
AcidJake75's Avatar
Factory Service Manual - do some homework and you will find it for free on the internet - or you can get one from a stealership (dont know how much they run these days though)
nice sig btw - kept watching it over and over..
Old 03-15-2007 | 07:28 AM
Professor's Avatar
Ahh, shoulda known , I found A Replacement switch with fog lights where i work for about $68, that should save me alot from what a dealer wants.
Old 03-15-2007 | 07:40 AM
d40sithui's Avatar
I actually had to install some fog lights myself. Mine is also a GXE maxima. I didnt have the relay, or the turn signal switch. I found that out AFTER buyign the a universal fog light kit ($40) from pep boys which included the relay, fuse, and their switch. Wiring is pretty simple, the hardest part was mounting the damn thing since its not direct fit. Then I had to drill a hole from under the car to run the wire to the switch that came with it...And then the resistor from the light was dead, which i found out the hard way and kinda fried the lights in the process. SO Ordering a new direct fit at the moment. It was a good and fun learning experience nonetheless. Good luck
-khanh
Old 03-15-2007 | 08:52 AM
PoLo's Avatar
2-Wheelin it...
as an fyi, it's easier to install the lights from above than from below. if you remove your headlights, you're exposed to the underside of the bumper, which is where the fogs get mounted. IMO, it's easier than lieing on your back and removing the shield, etc... takes 2 screws for the headlight to pop out.
Old 03-15-2007 | 09:03 AM
Professor's Avatar
Great Idea, ive had the lights out before and i noticed its alot easier to do it that way.
Old 03-15-2007 | 03:24 PM
WeeZyFellA's Avatar
Someone sold one of those new factory oem foglights same as those in the link on ebay and it only went for $60. I missed it by matter of minutes, else i would of got them. Still looking for factory fogs but not the price that courtesy is selling them for.
Old 03-15-2007 | 04:12 PM
SoonerFan's Avatar
Cletus
thats the way i do it and everyone else disagrees that its easier. you are the first that agrees.
Old 03-15-2007 | 08:07 PM
Imax00's Avatar
If you have just the foglamps by themselves is there a way to do it without the relay? and w/o the extra light switch that you have to purchase for a gxe.
Old 03-15-2007 | 08:49 PM
PoLo's Avatar
2-Wheelin it...
they're all fuking morons then. who enjoys being on the floor under the car. not I said the pirate.
Old 03-24-2007 | 12:50 AM
aja656's Avatar
I have the same question. i have a gxe and would like to add fog lights as well....what do you guys think about these ones on ebay?
http://cgi.ebay.com/ebaymotors/00-01...92587578QQrdZ1
Old 03-24-2007 | 07:42 AM
SoonerFan's Avatar
Cletus
those look nice but i wonder what the light output would be.
Old 03-24-2007 | 05:13 PM
aja656's Avatar
yah and i wonder if you would be able to change out the lights in them to HID...in the pictures of the lights on the ebay auction it shows the back of the housing....does anyone know if the ebay ones look like the stock ones? do you think these could be exchanged with hid's?
Old 03-24-2007 | 05:15 PM
SoonerFan's Avatar
Cletus
i was meaning that the reflective surface being smoked will affect the light output no matter what bulbs you use.
Old 03-24-2007 | 05:19 PM
aja656's Avatar
o ok i got you now...ya i had tinted front head lights in my last car and you couldnt see shiat...are there any black fog lights that have clear glass and a black interior?
Old 03-28-2007 | 11:02 PM
amnautic's Avatar
You can probably find some better looking lights on ebay for a lot cheaper...
Old 03-29-2007 | 05:12 AM
djfrestyl's Avatar
Suspension Yoda
You're going to need a relay either way. Might as well make it the OEM one that plugs right in. Same thing with the stalk - why give yourself the trouble when Nissan did all the work for you? MUCH cleaner and easier install. Just buy the parts.
EuroDriver
09-14-2015 06:08 PM
Greenmaxspeed
08-08-2015 12:39 PM
MikesChevelle
08-06-2015 11:36 AM
julian888
08-06-2015 04:39 AM
kjm900r
08-05-2015 07:14 AM
Quick Reply: Installing Fog Light on GXE Nissan Maxima
