Help Identifying Problem
Old Mar 14, 2007 | 12:56 PM
cefiro80's Avatar
I have a 2000 maxima. While I know our cars are notorious for wheel bearing going out I want to make sure I have a good idea of what is going on.
When I am making a sharp left handed turn my car makes a horrorible noise coming from the passanger side. It is a clicking/popping noise. If I take it really slow and dont turn the wheel to much it doesnt happen. However, if I give it gas in the turn and turn the wheel more sharply the sound really escalates. Also, I think it might be important to note the sound **does not** occur when I go over speed bumps etc. I was wondering is this perhaps a cv axle or joint problem? What are some indicators or things to look for if I take the car apart?
Old Mar 14, 2007 | 02:06 PM
2000SEBlack's Avatar
see if the CV boot is torn. if that is the case, you may have gotten a lot of grit and dirt in to the joint which makes a nasty noise when you're turning (clicking..etc). you can replace the cv axle fairly easily.
Old Mar 14, 2007 | 03:21 PM
a_prince1's Avatar
your cv axle sounds like the problem. Use his ^^ advice.
Old Mar 15, 2007 | 01:44 PM
cefiro80's Avatar
How hard is a cv axle removal/install?
Old Mar 15, 2007 | 03:25 PM
BMWHIGH1's Avatar
You Should Find Out If They Have Any Recalls For That Because I Know They Had To Replace The Control Arm For Some Of The 02-03 Maxima
Old Mar 15, 2007 | 10:42 PM
Derrick2k2SE's Avatar
That's the CV joint. Not too hard to replace. Just follow the directions in the shop manual. It does require a big socket for the shaft that goes through the hub. Larger than most people have in their tool sets. I don't remember the size but someone here may know. You can find it anywhere that sells tools.
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Noela
Sep 26, 2015 08:22 AM
