MAF dead?
Old Mar 17, 2007 | 01:18 PM
chillin014's Avatar
MAF dead?
my friends 2002 maxima (just z33 plenum swapped) was driving and he says he floors it to pass someone and all the sudden the car lost all power, rpms dropped and he pulled over. We thought a vacuum hose popped off but couldnt find any loose. When he tried to start the car it would die out almost immediately after idling really hard. I unplugged the MAF and it idled perfectly fine, so we drove it back (doesnt go above 2500 of coarse).
He was running the car without a filter for about a week and there was like...a hair on the sensor when we pulled the MAF out and some pollen. I cleaned it the best i could but it didnt make a difference.
So the question is, is the MAF fried or what...and what could have caused it?
thanks...
Old Mar 17, 2007 | 01:34 PM
kenshi's Avatar
Running without a filter wasn't too bright. No CEL?
Old Mar 17, 2007 | 01:38 PM
chillin014's Avatar
It was a temporary thing because the neck pushes the tb so far into the side of the bay there wasn't room for a filter.
But that's really besides the point, I am trying to decide if I need to buy a new maf for him right now or if there's another solution.
The cel has been on due to the vias disconnected so we don't know if a new one is in there and haven't tried to limp it down to the auto store to get it checked.
Old Mar 17, 2007 | 01:46 PM
kenshi's Avatar
I don't know what to say except you can't treat these engines like you're running a lawnmower. Get the codes and go from there.
Old Mar 17, 2007 | 02:05 PM
chillin014's Avatar
Ok thanks...I guess.
Don't think the motor was harmed however, just asking about the maf.
Old Mar 17, 2007 | 02:14 PM
kenshi's Avatar
I'm sure mechanically the engine is fine. It's the damn technology that bites you in the butt.
Old Mar 17, 2007 | 02:16 PM
NmexMAX's Avatar
dot dot dot ...
Spec it (V)
Old Mar 17, 2007 | 02:23 PM
chillin014's Avatar
Do what now??????
Old Mar 17, 2007 | 02:25 PM
NmexMAX's Avatar
dot dot dot ...
check the voltage and make sure it's in range as per the FSM.
Old Mar 17, 2007 | 03:06 PM
chillin014's Avatar
Everything looked okay on the connector harness, but the car doesn't idle so we can't check anything while the car is running ...
Old Mar 17, 2007 | 05:00 PM
NmexMAX's Avatar
dot dot dot ...
If it doesn't idle, you have an air leak somewhere.
Old Mar 17, 2007 | 05:53 PM
chillin014's Avatar
It idled fine before the maf blew out.
I'm about to just buy a new maf I can't think of anything else it could be. Maybe the hair connected those piece of metal in there and cause some kind of witchcraft act.
TallTom
57
Oct 14, 2025 05:16 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 10, 2015 09:35 PM
markevans999
Sep 10, 2015 04:29 PM
dcardello
Sep 3, 2015 11:44 PM
