Programming the Keyless entry
Old Mar 18, 2007 | 06:10 PM
multiplexor's Avatar
Hey guys,
Does anyone know how to program the keyless entry "thingy" :-)
I have one from my previous 2003 maxima that I would like to try to setup to use on this 2003 maxima...
Old Mar 18, 2007 | 06:11 PM
SoonerFan's Avatar
Cletus
http://forums.maxima.org/showthread....program+remote
Old Mar 19, 2007 | 08:24 AM
kenshi's Avatar
In case you don't feel like following links:
REPROGRAM KEY FOB
Most Nissan Vehicles
To reprogram (enter new ID) key fob (keyless remote controller) follow the steps.
1. Close all doors and lock all doors
2. Insert and remove the key from the ignition key cylinder more than six times within 10 seconds.
(The hazard warning lamp will then flash.)
NOTE:
Key should be withdrawn from ignition key cylinder completely each time.
NOTE:
Do not rush the insertion/removal key cycling process. The side marker/tail/license lamps and interior illumination will flash twice when this step is accurately completed.
3. Insert key on ignition key cylinder and turn ignition key switch to "AAC" position. At this time, the new ID code is entered and original (previous) ID codes are erase.
4. Press any button on the new remote controller once. (The hazard warning lamp will then flash)
NOTE:
Do not press the button more than one time in the above step. If the button is pressed more than one time, the programming procedure will not be successful. The side marker/tail/license lamps and interior illumination will flash twice when this step is accurately completed and programming is successful.
If there is only one remote controller skip step 5.
5. Additional ID code entry
Release the door lock, then lock again with door lock/unlock switch (In power window main switch)
6. Remove key from ignition
7. Unlock driver side door, open driver side door and then close the door.
(END)
NOTE:
If you need to activate more than two additional new remote controllers, repeat the procedure on step 5 "Additional ID code entry" for each new remote controller.
or...
2. From the door switch unlock the trunk.
3. Insert and remove the key from the ignition key cylinder six times within 10 seconds.
NOTE:
NOTE:
NOTE:
At this time, the new ID code is entered and original (previous) ID codes are erased.
4. Manually unlock and lock the driver side door
5. Push any button on the new remote controller once.
If there is only one remote controller skip step 6.
6. Additional ID code entry. Repeat step 4 and 5
7. END.
Old Mar 19, 2007 | 09:51 AM
SoonerFan's Avatar
Cletus
nice spoon feed
Old Mar 20, 2007 | 01:24 PM
kenshi's Avatar
Originally Posted by soonerfan
nice spoon feed
True. You would think that someone who's posted almost 1500 times would search, but I feel if you're going to take the time to reply, it might as well b helpful.
Since you have over 9000 posts, perhaps it's hard for you to remember that that other folks, especially someone who is relatively new, don't have the history and knowledge you do, like who Dave B is and how to contact him, like that person in that other thread.
Old Mar 20, 2007 | 01:26 PM
SoonerFan's Avatar
Cletus
my post was helpful
so was my post in the other thread
http://forums.maxima.org/showpost.ph...26&postcount=3
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
flu2000
Sep 14, 2015 12:34 PM
videomano
Sep 8, 2015 03:28 PM
Hailstatejig
Sep 2, 2015 06:52 AM
