Thinking of replacing spark plugs...
Old Mar 19, 2007 | 11:41 AM
IloveVQ's Avatar
What is the benefit of changing the spark plugs other than a minor change in performance if your plugs are fouled etc. obviously it would run a little better and such, but im at 58k and thinking about getting the ngk platinum plugs which would cost me about 60 bucks give or take. then i started hearing about people who changed their own plugs, which i plan to do, saying their rear valve cover cracked and there was oil in the coil pack well or whatever. then they needed a new valve cover = time and more money. I already got a new pcv valve that i will put in, and a new fuel filter i will install when i get a chance and i am starting to wonder wheather i should even mess with the plugs as long as its running well and performing.
Any input or opinions would be appreciated
Old Mar 19, 2007 | 11:49 AM
kenshi's Avatar
I don't believe there's any reason to change your plugs unless:
They're due to be replaced
You have an ignition problem
You have made an engine mod that requires a different plug
You've got nothing better to do,
but you will get many opinions that have been posted many times before.
Old Mar 19, 2007 | 12:46 PM
IloveVQ's Avatar
I realize that this is a posted and reposted topic, but i was just wondering about the new (or new to me) information of the oil in the spark plug wells problem and the cracking of the valve cover. I am aware fully of the arguements for and against changing plugs early and the minimal to no performance gain plugs give.
Thank you for your response
Old Mar 19, 2007 | 12:51 PM
nismopc's Avatar
Fuel Filter = In tank = No replacement.
Don't replace it unless there is a known diagnosed issue related to it. Waste of money.
Old Mar 19, 2007 | 01:11 PM
michaelnyden's Avatar
you are almost at the recommended change interval for spark plugs anyway 60K miles...do it...you won't be sorry...
Old Mar 19, 2007 | 01:14 PM
kenshi's Avatar
I replaced my plugs with the recommended OEM replacements at almost 95k miles because that's about when they were due to be replaced. I have had no problems with the engine since the change. All the old plugs were worn as expected, but fine otherwise.
Since I don't plan on owning this car for another 100k miles, it's something that hopefully I will never have to think about again.
I don't doubt that you will get other responses that are 180 degrees in opposition to what I said, but I can only relate my own experience and opinion.
Old Mar 19, 2007 | 02:53 PM
IloveVQ's Avatar
Fuel Filter = In tank = I have the part and have seen many write ups on how to replace it.
Old Mar 19, 2007 | 04:17 PM
nismopc's Avatar
5.5 gen ==> 105,000 replacement interval
I'd return the fuel filter and use the money else where. IMHO
Old Mar 19, 2007 | 04:27 PM
NmexMAX's Avatar
dot dot dot ...
It's not that hard to do. It's cheap insurance. You get to see if you're leaking oil because of a faulty rear VC. So, why not take the time to do the plugs?
Old Mar 19, 2007 | 04:41 PM
P. Samson's Avatar
If you've got no issues, then.... "if it ain't broke don't fix it" should apply.
PH98I30
19
Jun 13, 2016 02:38 PM
Maxboy23
Aug 21, 2015 11:02 AM
Turbobink
Aug 15, 2015 07:20 AM
maxima297
Aug 3, 2015 12:50 PM
