a few questions.
Old Mar 20, 2007 | 09:47 AM
Nissanx54's Avatar
a few questions.
I have a few questions. when i got my maxima it had the 350z wheels already installed on the car. i am not sure if they have spacers on the car. i also seem to notice that the car does not have much body roll compared to my friends 2002 maxima se. i have also found that his gauges are white where as mine are a titianium(sp?) color. so here are the questions;
What do the factory 2002 maxima se gauges look like?
how do i figure out if my car has spacers on it?
how much body roll does the 02 se have from the factory?
Old Mar 20, 2007 | 09:53 AM
LA02MAX's Avatar
1What do the factory 2002 maxima se gauges look like?
2how do i figure out if my car has spacers on it?
3how much body roll does the 02 se have from the factory?
1.) They are the titanium faced gauges. White is aftermarket. These are the stock gauges (minus the rings):
2.) You can see the spacers in between the wheel and the hub. Post pictures. The Z wheels have a lower offset than your stock wheels which means they will be pushed out toward the fender (good)
3.) You can't really qualitatively describe it, but they do have a decent amount. Look at your springs or measure your ride height to see if they're the same as your friend's car.
Old Mar 20, 2007 | 10:03 AM
Nissanx54's Avatar
ahhh i see. next time he is in town i will have to check his out. i know that from driving my car it doesnt have a whole lot of body roll. my wifes sentra has more body roll then my maxima does. i mean i have heard people who say that before doing suspension stuff that they couldnt take most ramps off/onto the highway at 60 mph. i can take a ramp on or off the highway for the most part at about 80 with no problems.
Old Mar 20, 2007 | 10:05 AM
SoonerFan's Avatar
Cletus
you dont have spacers. i have the same Z wheels and they stick out further than my stock wheels.
honestly...how are we supposed to answer that?
is there an RSB on the car? thats the main thing that could effect body roll
Old Mar 20, 2007 | 10:39 AM
Nissanx54's Avatar
i honestly dont know never really looked to see. do you know how much those wheels weigh?
Old Mar 20, 2007 | 11:28 AM
NmexMAX's Avatar
dot dot dot ...
Yes I do. ............http://www.wheelspecs.com/specs/wheelmodels/1749
Old Mar 20, 2007 | 11:34 AM
LA02MAX's Avatar
They're 23 lbs for the fronts and 24 lbs for the rears.
Old Mar 20, 2007 | 11:39 AM
Nissanx54's Avatar
those are completely different wheels from what i have.
Old Mar 20, 2007 | 11:40 AM
NmexMAX's Avatar
dot dot dot ...
Well, you didn't specify the model from which your wheels came from.. Sorry.
Old Mar 20, 2007 | 11:41 AM
Nissanx54's Avatar
i do not know which model they came from since they were on the car when i got it. these are the wheels i have.....
Old Mar 20, 2007 | 11:42 AM
LA02MAX's Avatar
check his sig.
The weights I gave are correct.
Old Mar 20, 2007 | 11:43 AM
NmexMAX's Avatar
dot dot dot ...
I know, I saw his sig pic now, and the answer is in LA02MAX's post. kthxbye
Old Mar 20, 2007 | 12:31 PM
Nissanx54's Avatar
ok thanks for answering my questions.
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Socalstillen
Sep 20, 2015 11:46 PM
pears
Sep 18, 2015 05:25 AM
