Strut Bar question.
Old Mar 27, 2007 | 06:29 PM
babyboyws6's Avatar
Strut Bar question.
Yeah i got a strut bar for my birthday from my brother.. 2003 maxima by the way. when i installed the bar it kind sits on part of the intake manifold... did i do sumthing wrong, is that normal, or is it just that thing sucks... becuz it says maxima 2000 - 2005... i dunno, you can kinda hear it rattling inside tha car 2. not alot, only if u listen for it.
Old Mar 27, 2007 | 06:41 PM
BLUEMAX01SE's Avatar
Did you make sure it was tight? Double check the ends to make sure they are tight also! It may be adjustable with an allen wrench!
Old Mar 27, 2007 | 06:51 PM
Maxgig's Avatar
I don't know what brand you have but the instructions that came with my Stillen said that I would need to "grind off the excess aluminum on top of the bosses." Which in laymens terms is the intake manifold. I didn't have to because it looked like it had already been done, but if Stillen calls for it I'm sure others will as well.
Old Mar 27, 2007 | 06:56 PM
babyboyws6's Avatar
there were no instructions with it.. but ima re-check the bolts to see if it's tight all the way.... if not then i will have to end up grinding down. I wanted Stillen but their products are expensive.. anything recommended for the grinding?
Old Mar 27, 2007 | 07:00 PM
I actually got my strut bar from CustomMaxima.com when they were around before! I have plenty of clearance between the manifold and strut bar, no problems whatsoever! My cousin has a Courtesy strut bar (from Courtesy Nissan) on his 01 Max and no problems at all and plenty of clearance as well! good luck!
Old Mar 27, 2007 | 07:04 PM
n3985's Avatar
大陆弟弟
The 02-03 need more clearance than a 00-01, quickest fix is to go to hardware store and buy some washers.
Old Mar 27, 2007 | 07:12 PM
babyboyws6's Avatar
i was thinking bout that while i was driving... i should said sumthin bout that 2. I mean eventho i know it's touching... i still feel the difference in my turns so getting rid of it def out of the question. I know i have tons of washers in my hosue so ima try that before grinding. go0d call
Old Mar 27, 2007 | 07:15 PM
Maxgig's Avatar
Yeah stillen was kinda pricey, ($143 shipped) even with the military discount, but I just sold my 97 and I wanted to get the 03 up to speed sooner than later for the upcoming club meet season. If the washers don't work I'm sure you can get a local garage to grind off about 1/8th of an inch of metal at a decent price.
Stillen also comes with a nice little window decal.
Old Mar 27, 2007 | 07:19 PM
babyboyws6's Avatar
Some how i think the washers will work... if not then yeah i will crack open the toold shed and bust out a grinding device my pops got for pipes. i like 2 save money haha. I dont know why stillen is so much tho... does the same job... i dunno i aint tryna make this into a stillen bashing thread tho
Old Mar 28, 2007 | 09:02 PM
babyboyws6's Avatar
yeah so i tried the washers... still not enough clearance... my boy got the strut bar from here: http://aspecproducts.com/images.asp?theid=716
Like i said the clearance is really bad, part of the intake manifold dug into the bar... not alot, but deep scratch... deep haha. Im not grinding anything when i can just get one that has plenty of clearance ya know.
any one got some suggestions for a 2003 maxima SE??
Old Mar 29, 2007 | 05:24 AM
Tippy Toes's Avatar
I am getting my Stillen in this week, will let you know. Worst comes tro worse do the washers.
Cheers
Old Mar 29, 2007 | 02:28 PM
huffdaddy2008's Avatar
ya since they all do the same thing spend 30$ for one on ebay.
Edit: i have the same one from aspec off of ebay but i dont get it. I have a good inch between the intake manifold and strut bar.
Old Mar 29, 2007 | 03:55 PM
nismopc's Avatar
I have a SPW Strut Bar. It's the typical eBay style one and it sits about 1" away from the intake collector as well. No clearance issues, but it does slightly rub the hood insulator.
Old Mar 29, 2007 | 04:03 PM
Ya so does mine. I painted mine so theres a few tiny marks on the bar that have rubbed off from the insulation. No biggie though. You have to get real close to see them. Id much rather have that than rub and grind on the IM.
Babyboy can u post pics of urs?
Old Oct 30, 2007 | 10:01 AM
ZIPPIN's Avatar
Mauja He Mauja
Do the 2000 bars fit on 2002 and 2003 as well?
Old Oct 30, 2007 | 10:07 AM
SoonerFan's Avatar
Cletus
you are a donating member...does it
Old Oct 30, 2007 | 12:24 PM
NmexMAX's Avatar
dot dot dot ...
I thought this thread looked familiar.
Thread Created: 03-27-2007, 07:29 PM
Old Oct 30, 2007 | 12:40 PM
The Law's Avatar
I R The Law
WTF......this thread is damn old.....
Old Oct 30, 2007 | 07:11 PM
SoonerFan's Avatar
Cletus
the point of searching is to search for the ANSWER!!
not search for a related topic then bump it by asking a question
doctorpullit
Mar 29, 2016 11:08 AM
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
