2001 - Wheel Alignment Specs ??
Old Apr 12, 2007 | 04:09 PM
max2k1SE's Avatar
Hey folks ......
My '01 SE (with the 17" stock wheels, 225/50 stock spec tires) seems to be having a steering pull (and also an off-center steering) ever since I changed tires (bought a new set of 4).
The tire shop says that wheel balancing is correct.
Could it be an alignment issue ??
If so, could someone post the alignment specs for this car (from the service manual ??)
Any ideas what else it could be ??
Thanks !
Old Apr 12, 2007 | 07:43 PM
dizmax96's Avatar
18* total toe in the front (left and right combined) no other adjustments unless you have a camber plates for camber of course. no rear adjustments
Old Apr 12, 2007 | 07:54 PM
DOHCtorJT's Avatar
Having incorrect toe will cause the off-center steering.
Old Apr 14, 2007 | 05:18 PM
max2k1SE's Avatar
Thanks dizmax96 and DOHCtorJT - very helpful.
I will get my alignment checked asap with these specs.
What else could cause an off-center steering ??? (which happened right around when I replaced my 4 tires)
Also DOHCtorJT ==> Was this page from the FSM ?? Know where I can get the PDF of it ?
matts95max
Apr 23, 2025 10:44 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
dcam0326
Sep 8, 2015 11:02 PM
mikebla
Sep 3, 2015 05:37 PM
