Question about heater?
Old Apr 14, 2007 | 10:47 PM
andrew3616's Avatar
Ok the blower in my car works on every speed expect 2. I dont know why, where should i start?
Old Apr 14, 2007 | 10:56 PM
SilverGLE's Avatar
I'm watching you, boy...
Here's a simple fix... If you have soldering skills, look directly under the fan for a white connector that plugs into the air duct between 2 screws... Unplug this connector and take out the screws, then remove the "grounding resistor," or whatever the hell it's called. Once this is out, pop off the white plastic cover, then reheat the 3 large solder joints and add extra solder to them. Make sure it all flows; no more cold solder joints! This will probably fix your problem.
My fan started acting funny where it would work some of the time, and even then was depending on the mood and temperature. This worked for me... temporarily. It's acting up again and I may just order a new one from Dave B.
Old Apr 14, 2007 | 10:58 PM
andrew3616's Avatar
yeah but it works fine expect just doesnt work at all on 2. Is there a fuse somewhere for that specific speed?
Old Apr 15, 2007 | 07:37 AM
Dust N Bones's Avatar
There is not a fuse for each specific speed. It does sound like the blower resistor although usually I think you lose all speeds except high but it could just be starting to fail. The part is about $30 and is really easy to replace. I replaced it in my Mother in Law's 2000 Maxima and a friends 2000 Altima.
See this post for more information: http://forums.maxima.org/showpost.ph...2&postcount=31
Old May 2, 2007 | 10:09 AM
ssquire37's Avatar
My blower motor doesn't blow on any setting. I replaced blower motor and still doesn't blow. If setting 4 doesn't use the resistor than what else would be the problem? 2000 gle auto climate control
Old May 2, 2007 | 11:08 PM
SilverGLE's Avatar
Take the battery and directly connect it to the blower motor. if it works, then the blower's not the problem. If you have auto climate control, then you have a power module instead of a grounding resistor (about $85 instead of about $30).
howardis
Dec 11, 2019 06:10 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
