Rattling Noise From Hood
Apr 18, 2007 | 11:33 AM
I got my headlights stolen a while back. So after they fixed the hood, it rattles while I am driving. From what I see and feel, it is not sitting snug in the hood latch after I close it. Is there anyway to fix this, so it does't bounce around???
Apr 18, 2007 | 12:55 PM
you may need to replace the hood latch. also check to see if the ring is broken that the latch locks into when you shut the hood.
Apr 18, 2007 | 01:09 PM
There are rubber bump stops that are on the radiator support that you can adjust. If that won't help, lower the latch.
Apr 19, 2007 | 06:56 AM
Quote: There are rubber bump stops that are on the radiator support that you can adjust. If that won't help, lower the latch.
I am having the same exact problem it is very annoying and have a large gap on the front of my hood...i had my grille out and everything last week examining my latch... i couldn't figure out how to lower it, i doesn't look adjustable, i wonder if its worth the 31 bucks to buy a new one????
Apr 21, 2007 | 06:22 AM
there is a TSB for the hood rattle. It requires a bumpstop right by the latch and also their is a peice of rubber i guess that goes over each of the headlights. It is suppose to stop the hood from shaking at highway speeds. Also one other thing to look for is the hood has supports that are "welded" to it but after age those "welds" break and you have to re"weld" them. If you do a search for hood vibration then it should come up w/ the TSB
Apr 21, 2007 | 02:42 PM
I have the exact same problem and I called nissan about the tsb and they said since I am out of warranty to go to a body shop and they can adjust it.
Apr 21, 2007 | 02:57 PM
Quote: I am having the same exact problem it is very annoying and have a large gap on the front of my hood...i had my grille out and everything last week examining my latch... i couldn't figure out how to lower it, i doesn't look adjustable, i wonder if its worth the 31 bucks to buy a new one????
There is a bolt or 2 on the latch that you loosen and you can raise and lower the latch.
Apr 21, 2007 | 03:10 PM
Quote: There is a bolt or 2 on the latch that you loosen and you can raise and lower the latch.
Do that and adjust those two black rubber bump stops and the rattling will stop.
Apr 21, 2007 | 07:19 PM
any posibillities of a pic if that's possible. thanks in advance
Apr 21, 2007 | 07:51 PM
Quote: any posibillities of a pic if that's possible. thanks in advance
http://forums.maxima.org/showthread....ood+bump+stops
The last post in this thread had informative pictures. It shows how to adjust the latch, and the little flat spots on the edge of the hood pictured is where the bump stops rest, so you can figure out where they are. They're little black rubber pieces just above the headlight that turn to adjust higher or lower.
Also, here's the TSB:
http://maxima.theowensfamily.com/tsb/NTB02-005.pdf
Apr 21, 2007 | 08:00 PM
FYI,
02/03 doesnt have the weather striping above the headlights. all 00/01 i have seen had it.
my hood didnt make a sound (rattle) but i could see it vibrating at higher speeds. i put weather striping on the headlights to prevent air from getting under the corners and it eliminated the problem.
Apr 23, 2007 | 08:19 AM
I will try that but when i looked at it before it didn't appear that the bolts had any room for adjustment, but I'll check again
Apr 23, 2007 | 08:20 AM
thanks for the info
