Berk Installed - NICE
Old Apr 25, 2007 | 08:37 AM
  #41
MaxBoost925's Avatar
Drug Money
Originally Posted by soonerfan
i custom made mine
I got one with my JWT popcharger
Old Apr 25, 2007 | 08:40 AM
  #42
shurik's Avatar
Originally Posted by CRBWS6
i have a question for those who posted engine bay pics....how come the support bracket at the base of the filter? the berk kit didn't come with this and when i called about it, they said it wasnt necessary. just curious...
hmmm when I bought mine like 6 month ago, (the exact same combo) it came with the support bracket.
Old Apr 25, 2007 | 09:04 AM
  #43
CRBWS6's Avatar
i custom made mine
I guess my question is why? Is it really necessary? The Berk people seem to think not......
Old Apr 25, 2007 | 09:06 AM
  #44
SoonerFan's Avatar
Cletus
the intake isnt going to fall off without it...it doesnt really move at all. i used a bracket as a safety measure to reduce MAF vibration. it probably doesnt do anything...but i wanted to be on the safe side
Old Apr 25, 2007 | 09:12 AM
  #45
nismopc's Avatar
Since my mid-pipe and intake set-up is custom and I am still using the OEM accordian coupling, I had to make a bracket. No other choice for me. There is not enough strength in that coupling to support the piping, MAF, and filter.
Old Apr 25, 2007 | 01:46 PM
  #46
Trurida18's Avatar
what type of bracket did u use?, what size, and where did you get it from?
if you doing mind me asking
Old Apr 25, 2007 | 01:53 PM
  #47
Puppetmaster's Avatar
I bought my Berk over two years ago and it came with one...
Old Apr 25, 2007 | 04:12 PM
  #48
Trurida18's Avatar
which bracket do you speak of?
Old Apr 25, 2007 | 07:00 PM
  #49
CRBWS6's Avatar
probably a good idea. actually i think the intake does move some...upon opening the hood after my initial run, the actual filter popped off!!! i had it aligned too low and i think it was hitting the fender well....and it also may not have been tight enough.
Old Apr 25, 2007 | 07:21 PM
  #50
foxbat's Avatar
has anyone ever done a dyno test on what HP/TQ these intakes are really adding??
Old Apr 25, 2007 | 07:29 PM
  #51
SoonerFan's Avatar
Cletus
a newbie...how cute
an intake (ANY intake) by itself has very minimal gains (1/2 - 2 whp).
Old Apr 25, 2007 | 07:31 PM
  #52
NmexMAX's Avatar
dot dot dot ...
Myself and 2 other members dynod the gab intake and gained 9 whp by itself
  #53
SoonerFan's Avatar
Cletus
LIAR!!!!!!!!
no proof, no care
Old Apr 25, 2007 | 07:41 PM
  #54
NmexMAX's Avatar
dot dot dot ...
Check the dyno forum please
Old Apr 25, 2007 | 07:42 PM
  #55
SoonerFan's Avatar
Cletus
then my berk gives 10+
Old Apr 25, 2007 | 07:45 PM
  #56
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread.php?t=376123
Old Apr 25, 2007 | 08:05 PM
  #57
mike9900's Avatar
might be a dumb question but I just got an I35 and was wondering if anyone knows if the berk will fit on it since my car is pretty close to your car. Would the variable intake cause any problems with a high flow filter/fitting of the tubing? I sent a question to berk just waiting for a response.
BTW cars look nice
appreciate the help
Old Apr 25, 2007 | 08:08 PM
  #58
NmexMAX's Avatar
dot dot dot ...
The drivetrain is identical to all A33B AT Maximas, so yes, it will fit perfectly. The intake would have no ill effect on the VIAS. Not sure where you got that from.
Let me know if Bryan over there gets back to you. He was doing ok at getting back to me in the past, but now, after 3 emails over the same amount of weeks, I haven't herd from him
Old Apr 26, 2007 | 02:23 AM
  #59
Ceasars Chariot's Avatar
Old Maxima Legend
nice work, 3.5 liter sounds great aye !
Old Apr 26, 2007 | 06:46 PM
  #60
MyownNismo's Avatar
Future Camaro SS owner
I made my own intake. Apex-i filter custom made filter to maf adapter. 3inch piping with a 3.00 to 2.75 reducer. I'll post a pic later.
Old Apr 26, 2007 | 06:53 PM
  #61
NmexMAX's Avatar
dot dot dot ...
Reducers are FTL.
Old Apr 26, 2007 | 07:16 PM
  #62
SoonerFan's Avatar
Cletus
why would you reduce the air flow
Old Apr 27, 2007 | 09:48 AM
  #63
Nissanx54's Avatar
Originally Posted by Trurida18
whats AFR attention, or AF conditioning?
+1 i dont know if its me or not but i believe i have lost a little bit of gas mileage when i installed my pop charger.
Old Apr 27, 2007 | 10:53 AM
  #64
andy2248's Avatar
I drilled 3 big wholes in front of my air box instead of doing the ghetto air box in the how to part of the forum. How would a berk sound compaired to that non of the audio files i have listened to do ne juistice.
Old Apr 27, 2007 | 11:30 AM
  #65
nismopc's Avatar
Similiar in sound but louder
Old Apr 27, 2007 | 11:32 AM
  #66
nismopc's Avatar
You should be seeing better gas mileage.
It's because your probably mashing the pedal more to hear it than you were before.
Old Apr 27, 2007 | 12:04 PM
  #67
Nissanx54's Avatar
before i was getting about 24 miles to the gallon and now its about 25 miles to the gallon. i dont mash the pedal down any more then i did before. there is a tornado in the that was there before and i didnt take it out. you think that could be causing the problem?
Old Apr 27, 2007 | 01:58 PM
  #68
MyownNismo's Avatar
Reducers are FTL.
It's to connect the 3 pipe to the smaller TB. It's just a coupler.
Old Apr 27, 2007 | 02:43 PM
  #69
nismopc's Avatar
Take it out!
http://forums.maxima.org/showthread....58751&t=270321
Old Apr 28, 2007 | 05:44 PM
  #70
Trurida18's Avatar
Hey quick question, im going to install my intake in the morning, and need to know....DO I HAVE TO RESET THE ECU? is there really a big deal with doing it?, also if i DONT what is the consequence?
thanks
Old Apr 28, 2007 | 05:57 PM
  #71
SoonerFan's Avatar
Cletus
thanks
you dont need to reset it...it wont hurt anything.
if you want, you can disconnect the battery overnight so that the ECU "learns" the new mod when you drive again...but you dont have to. it will learn eventually anyway.
Old Apr 28, 2007 | 06:05 PM
  #72
NmexMAX's Avatar
dot dot dot ...
All terms in ID now, mmk?
So, you have your MAF, 2.75", pipe, supposed 3", and TB 2.5"
Old Apr 28, 2007 | 06:21 PM
  #73
Trurida18's Avatar
thanks man i appreciate the information. So basically it only speeds up the learning process.
Old Apr 29, 2007 | 08:12 PM
  #74
Trurida18's Avatar
OK..Installed the Intake this morning...THE MAF rubber coupling was a B!t*h to get on..I had to heat it up, and stretch it out. I cleaned my MAF heavily with that CRC MAF cleaner...and Know my car seems to pull better than it did before. THE SOUND IS AWESOME...
Here is a pic...i would have made it larger..But didnt wanna kill the LITTLE bandwidth this site has
Old Apr 29, 2007 | 08:22 PM
  #75
CRBWS6's Avatar
congrats....your next tank will not give you as many miles as you are used to
Old Apr 29, 2007 | 08:29 PM
  #76
irish44j's Avatar
retired moderator
ugh....you shoudn't have cleaned the MAF at the same time. now you will never know if the better pull is because of the intake or because of the cleaned MAF.
PR intake > all others, by the way
Old Apr 29, 2007 | 08:54 PM
  #77
Trurida18's Avatar
lol...yea so ive noticed....... i think the effect has worn off though
Old Apr 29, 2007 | 08:56 PM
  #78
Trurida18's Avatar
DAMN, eh well it doesnt really matter to me now...It sounds better and it slightly pulls better.....well i know where the sound came from, and im guessing the better pull has only LITTLE TO DO WITH THE INTAKE
BUT THANKS TO ALL FOR THE INFO
Old Apr 30, 2007 | 08:51 AM
  #79
Trurida18's Avatar
hey....last question about intakes........is it true for it hiss a little bit around 1800-1900 RPM's?.....when at low speeds
I've check and double checked all clamps as well as the bolts around the MAF and MAF adapter
Old Apr 30, 2007 | 01:04 PM
  #80
CRBWS6's Avatar
I hear a hissing when i tap lightly on the throttle; and I have heard others mention this too. Sounds cool.
