Berk Installed - NICE
Old Apr 30, 2007 | 01:31 PM
  #81
NmexMAX's Avatar
dot dot dot ...
My set-up 'hisses' even with the stock airbox
Old Apr 30, 2007 | 01:37 PM
  #82
Trurida18's Avatar
Originally Posted by CRBWS6
I hear a hissing when i tap lightly on the throttle; and I have heard others mention this too. Sounds cool.
thats just what i hear!...THANKS MAN!
Old May 5, 2007 | 06:02 PM
  #83
shurik's Avatar
CRBWS6 I did that little test 50-80 mph on a perfect flat road, and I ended up at 5.8 seconds. I tried it only once, maybe I can get a little better time, but seems like I got it perfect from the first time.
Old May 5, 2007 | 07:10 PM
  #84
knight_yyz's Avatar
Toolie
I noticed that everyone seems to keep the ugly MAF wire connector where you can see it. I rotated mine 180 degrees so it is hidden. So my stupid question is, does it matter except for looks?
Old May 5, 2007 | 07:19 PM
  #85
nismopc's Avatar
I thought about that for a bit when I was installing my custom set-up and came to the conclusion it was that way to keep potential moisture out of the sensor unit itself. I have no clue if this is a correct statement, but I'd rather see the connector/wires then have to replace it due to moisture messing with the sensor.
Old May 6, 2007 | 08:35 AM
  #86
NmexMAX's Avatar
dot dot dot ...
Whenever I clock my MAF differently (as little as 15*) it affects AFR quite some.
Old May 6, 2007 | 10:41 AM
  #87
knight_yyz's Avatar
Toolie
so pointing the connector straight up is better?
Old May 6, 2007 | 10:43 AM
  #88
NmexMAX's Avatar
dot dot dot ...
Depends. See what works for you.
Old May 6, 2007 | 10:48 AM
  #89
knight_yyz's Avatar
Toolie
unfortunately I dont have anything to read afr. I'll look into seeing if there is something I can do with autoenginuity software.
BTY I put the larger diameter 3" x 7" long berk style intake, identical to the one I made for you along with the accordian piece. Seems to have made a difference. Feels like more torque. When I get the greddy blue installed and get on the dyno I will try to base run twice with the different tubes to see what happens.
Old May 6, 2007 | 10:52 AM
  #90
NmexMAX's Avatar
dot dot dot ...
AE only gives raw o2 sensor V. And that is as usable as a meatless hamburger.
  #91
knight_yyz's Avatar
Toolie
that's what i thought
Old May 9, 2007 | 04:41 PM
  #92
Bufflomike's Avatar
Sexier Than Simpson
Berk nstalled
What an easy install this was. The hardest part was getting the 2" adaptor onto the Apexi adapter. That is like getting 10 pounds of **** into a 5 pound bag. It sounds awesome at WOT and I really hear no difference at normal throttle. Butt dyno...not sure whether there is a difference or it seems faster because it sounds so cool. First mod I have done, waiting for my SFC's to get here, probably Friday or Monday. Mods are like tattoos I imagine, can't just get one.
Old May 9, 2007 | 07:57 PM
  #93
SoonerFan's Avatar
Cletus
well now we all finally know...berk makes an intake for our car and it sounds nice
Old May 10, 2007 | 04:23 AM
  #94
Trurida18's Avatar
i was surprised at how easy the install was myself....the hardest part for me was getting the rubber around the damn MAF, i had to microwave the ruber it to soften it up
Old May 10, 2007 | 04:44 AM
  #95
Bufflomike's Avatar
Sexier Than Simpson
My MAF and ECU along with my coils are fine
Old May 10, 2007 | 05:19 AM
  #96
TDotMax's Avatar
After experimenting with various intakes. The butt dyno (and dyno's a posts) told me stick with stock accordian and resonator with just a MAF adaptor and filter.
Old May 10, 2007 | 06:21 AM
  #97
NmexMAX's Avatar
dot dot dot ...
DEK dynos? ?
Old May 10, 2007 | 06:24 AM
  #98
nismopc's Avatar
Old May 10, 2007 | 06:29 AM
  #99
NmexMAX's Avatar
dot dot dot ...
So are sooners, I'm sure it's just kneejerk common dealership reaction. Common "we dont' know is wrong with your car so we will replace everything related until it works again"
Old May 10, 2007 | 06:50 AM
  #100
TDotMax's Avatar
Originally Posted by NmexMAX
DEK dynos? ?
Nope saw 35DE and 30DE dyno's. It just feels more responsive. When I dyno I'll pull 2 runs with and without the accordian and resonator.
Old May 10, 2007 | 07:00 AM
  #101
SoonerFan's Avatar
Cletus
my MAF is fine
my coils needed to be replaced anyway
the ECU does need to replaces but has nothing to do the my intake
Old May 10, 2007 | 07:03 AM
  #102
NmexMAX's Avatar
dot dot dot ...
Different IM design. A member of the 4th gen forum has done this for the VQ30, and I have done this for the VQ35. Be nice to see how the DEK responds to it.
Old May 15, 2007 | 09:07 PM
  #103
CRBWS6's Avatar
nice...i was really just doing the test for a before/after comparo since there are so many uncontrolled variables (driver reading the speedo, timer error, etc.). i might check it again now that the ecu has re-learned...only problem is that it is over 100 deg here now and my car will be the slowness
Old May 18, 2007 | 08:48 AM
  #104
JiggaD369's Avatar
Which setup would give the best low end response? I think I read a long time ago that stock setup is optimal?
I have an auto so I'm skeptical that it might be robbed by going with a CAI.
Old May 18, 2007 | 09:11 AM
  #105
NmexMAX's Avatar
dot dot dot ...
This mod also helps low end tremendously.
http://forums.maxima.org/showpost.ph...0&postcount=84
Old May 26, 2007 | 11:10 PM
  #106
playboi21617's Avatar
i installed mine and you can realy tell the difference in performance. but about 3 weeks later it seems like the car is slower than stock i dont what the problem is and i dont think its the intake.
Old Jul 13, 2007 | 06:49 AM
  #107
big h's Avatar
Hey guys, I need to replace the cone, anyone have any idea what the inlet/outlet diameter is for the berk intake system? Car is a 2001...I'd go measure mine, but the car is not here, its dead at a 24hr diner...hehe
9aj9
Apr 5, 2020 12:11 AM
MaxLife17
Jun 27, 2019 01:37 PM
lowpost99
Sep 8, 2015 05:06 AM
Johnny9595
Sep 3, 2015 05:18 AM
