Of all the things to break.......
Old Apr 23, 2007 | 06:12 PM
GMANAZ's Avatar
This Meridian Ed 02' only had 33K miles when I bought it 2 months ago. This past weekend this damn ON/OFF button broke off. Of all the buttons to break off it would have to be this one. Now we can't turn the heat a/c system off anymore. I'm really surprised how cheap this little button was attached on the back.
Old Apr 23, 2007 | 06:13 PM
upstatemax's Avatar
Epoxy it...
Old Apr 23, 2007 | 06:20 PM
GMANAZ's Avatar
No go.... It's not push directly straight on type switch or I would of fiqured that out already, believe me. If you see those two white spots on the bottom pic, those were the button broke off at. So when you hit the button those white plastic pieces must move upwards somewhat and make contact. I'm thinking about making some mini metal strips about 2mm x 5mm and sliding them under the white pieces and see if moving them up will shut the system down, if so, then I need to fiqure out a way to get the strip into the OFF Button.
Either that.....or there had to be something that fell out of that hole under the rectangular box(light) and when you pushed the OFF button it pushed a small rod or shaft in that hole and shut the system down. I did not find anything on the floor of the car.
Old Apr 23, 2007 | 07:15 PM
The Law's Avatar
I R The Law
Take it back to the dealership. You car should be under warranty. Have them replace the beish.
Old Apr 23, 2007 | 07:28 PM
GMANAZ's Avatar
3yr/30K Electrical
5yr/50K Power train
SOL
A new refurbished unit is $3000 at the dealer. I was there today.
Old Apr 23, 2007 | 07:30 PM
upstatemax's Avatar
Originally Posted by GMANAZ
3yr/30K Electrical
5yr/50K Power train
SOL
Junk yard?
Old Apr 23, 2007 | 07:33 PM
PandaXpress's Avatar
WOW...now that is retarded. Take the unit out...open it up..and try fabricating some sort of clip or trigger mechanism. Maybe wire it to a switch and just epoxy the button back on there..and control on/off through a switch?? GL with that.
Old Apr 23, 2007 | 07:48 PM
Epacy's Avatar
Unsuccesful STL Coordinator
I thought Powertrain warranty was 60k?
Old Apr 23, 2007 | 08:03 PM
SoonerFan's Avatar
Cletus
it is...still wont cover this
Old Apr 23, 2007 | 08:43 PM
SilverGLE's Avatar
I'm watching you, boy...
You can try haggling with your dealer for some sort of cheap/free fix... GL, though. Once you buy a used car and it leaves the lot, they want you to cover EVERYTHING... My damn dealer had a 50/50 warranty for 30 days on my Max, and tried to pay only half of a valve body replacement BEFORE taxes...
Old Apr 24, 2007 | 04:53 AM
Epacy's Avatar
I know, just clarifying.
Old Apr 24, 2007 | 07:11 AM
Go over here and just smack the guy who sold it to you in the damn mouth. If he doesnt fix it, hes a scam artist...I guess threaten to call the BBB?
Old Apr 30, 2007 | 10:09 PM
GMANAZ's Avatar
Well I ended up fixing it myself. I guess all the industial arts classes paid off in school. The piece that goes in the small hole under the light fell inside the unit and was not retreivable(sp). So I made a new piece, 5mm long by 1/32 dia and used that as the rod that the OFF button pushes in to hit the switch inside. Then I layed a seam of Locktite flexable heat proof glue along the top leadng edge of the back of the OFF button which acts like a hinge. After drying 24hrs....everything works like new and the whole fix cost $4.
Old Apr 30, 2007 | 10:13 PM
did you end up smacking him?
D Mason
Jun 21, 2016 04:43 AM
doctorpullit
Mar 29, 2016 11:08 AM
bigfrank
Oct 1, 2015 12:51 PM
09maxshawn11
Sep 30, 2015 10:28 AM
