Custom Cali Downpipe - the precat
Old Jul 11, 2001 | 06:24 PM
Pmp-n8a's Avatar
I was thinking would the homongous piping on the NLEV Manifold hurt performance with a custom downpipe?(the precat removed)
Im thinking about doing it this upcoming week but Im worried about lost backpressure since the NLEV Manifold since to be alot bigger
Desert Pearl- How big was the opening of the manifold? 3"??
Old Jul 11, 2001 | 06:28 PM
UMD_MaxSE's Avatar
Got Bent?
Two people, Desert Pearl and sleepermax, have replaced the front cali spec manifold with a fed spec manifold that does not have the pre-cat. They also put in a fed spec Stillen y-pipe. The results showed that gains were minimal. That shows that the front pre-cat in the cali- spec manifold is not very restrictive. So, unless you feel like doing the conversion, it won't gain you a lot of power...
Old Jul 11, 2001 | 07:37 PM
Pmp-n8a's Avatar
im not talking about a conversion...im talking about removing that big ole precat from the manifold itself and bolting up a downpipe TO the NLEV manifold
Old Jul 12, 2001 | 04:43 AM
UMD_MaxSE's Avatar
Got Bent?
Which manifold? The front manifold has a pre-cat built in to it if you have a Cali spec maxima. The rear pre-cat is built into the stock down pipe itself. When you get an aftermarket cali spec y-pipe the rear pre-cat is removed and the front pre-cat stays since it is built in.
Old Jul 15, 2001 | 08:02 PM
Pmp-n8a's Avatar
isnt the front precat BOLTED to the manifold???...i always thought it could be removed...just a tedious job
Old Jul 15, 2001 | 08:53 PM
y2kse's Avatar
Fuggedaboudit !!!
Even if you could accomplish what you're suggesting, the net result would be either no increase in performance or a loss in performance. In addition, you'll probably generate a MIL light if you don't move your O2 sensors behind the main cat.
Old Jul 16, 2001 | 07:07 PM
sleepermax's Avatar
Pmpin' - it's a lot of work and performance gains are minimal, but driveability is noticeably improved compared to just having the y-pipe/single precat. You have to replace the front manifold - there's no way around this without getting negative results. It's a LOT or work - I would not recommend messing with the front manifold/precat unless you really miss and want to restore driveability to stock form, and you really, really like working under your car!
Apr 16, 2020 05:15 AM
carid
Sep 17, 2015 05:00 AM
QueensMAX
Sep 15, 2015 04:14 AM
