3.5 aftermarket flywheels
Old May 1, 2007 | 10:26 AM
MAXSE5SPD's Avatar
im dumping my pos xtd flywheel and getting an actual maxima one, but im not sure which. i know about the ring gear problems with fidanza, but how are the spec and jwt ones? im assuming all 3 have bolt on timing rings?
Old May 1, 2007 | 10:35 AM
Kevlo911's Avatar
Kevlo for President
I would only get JWT for the FWD ones.
Old May 2, 2007 | 04:58 PM
MAXSE5SPD's Avatar
any other inputs? does anyone know the weight of a spec flywheel?
Old May 2, 2007 | 06:50 PM
Derrick2k2SE's Avatar
I'm really happy with the Fidanza after getting the ring gear issue worked out. Their customer service is awesome. Weight is 15.5 pounds
Old May 3, 2007 | 08:40 AM
brusk's Avatar
What's he weight of stock? I heard somebody using a 350Z flywheel what's the weight of that and i think i remember something about having to change starters if you do that cause of a mismatch of tooth count.
Old May 3, 2007 | 06:43 PM
Stock weight is 30 pounds. The 350Z flywheel is not a direct replacement with the Max.
Old May 3, 2007 | 10:03 PM
brusk's Avatar
ok since its not a stock replacement. Holy sh did you say 30 lbs. GD that's like a camaro. ok so back to the 350z if it's not a direct replacement what is required for that one. How much does it weigh?
Old May 4, 2007 | 04:56 AM
MAXSE5SPD's Avatar
dual mass flywheel ftl. the one i had was 13lbs. you would need a 350z starter gear to avoid the starter noise and gear clash. i dont know if any other fwd starter has a similar tooth pattern to the 350z.
Fbana41
Aug 29, 2016 12:18 PM
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
