Help! P1440
Old May 8, 2007 | 06:45 PM
Coby099's Avatar
Help! P1440
P1440 came out on my check engine light. Is this a serious and what nnheds to be done to fix the problem.. The gys in autozone said that the computer read that it was a little leak - but im not sure about that, please help and how much will it cost to fix.
Thanks!
Old May 8, 2007 | 07:21 PM
magdocjr's Avatar
Free search? Read the stickies?
Old May 9, 2007 | 12:50 AM
sooner02r1's Avatar
http://forums.maxima.org/showpost.ph...&postcount=100
That's all the help I can offer
Old May 9, 2007 | 12:57 PM
Coby099's Avatar
Can anyone help me with this - please!!!!!!!!!!
what is a EVAP control system Small Leak.?
Old May 9, 2007 | 01:49 PM
magdocjr's Avatar
What does that mean?
This indicates a fuel vapor leak in the EVAP control system. It means a very small leak has been detected. In fact, the leak can be from a hole as small as 0.04" in diameter. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
Symptoms
You likely won't notice any drivability problems.
Causes
A code P1440 most likely means one or more of the following has happened:
* A loose or improperly affixed gas cap
* A non-conforming gas cap (i.e. not factory/original brand)
* A small leak/hole in a fuel vapor hose/tube
* Other small leak in EVAP system
* Faulty vent o-ring seal
Possible Solutions
the most common repair is to:
* Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
* Otherwise, replace the gas cap, or
* Inspect the EVAP system for cuts/holes in tubes/hoses
It is not that hard to find answers
Old May 10, 2007 | 09:07 AM
jkayca's Avatar
One other thing to add to maqdocjr's excellent post. Clean the hole where the gas cap threads into. If yours is anthing like mine its probably corroded which can cause fitment problems. Put a piece of paper towel in to prevent crap from falling in the tank. Not so far you can't take it out again!. Then take a piece of sandpaper and clean the area. You'll want to vacuum out the debris or use a blast of compressed air to cleanup. Do this before buying a new cap.
Old May 10, 2007 | 09:20 AM
Skier's Avatar
I got that code. Gas cap replace failed, evap canister and vent control valve replace worked. Just buy both ($205 thru everything Nissan.com). Trying to remove vent control valve from canister will just break the screws 99% of the time.
Old May 10, 2007 | 12:49 PM
Coby099's Avatar
i will keep u posted. thanks guy - excellent replies.
Old May 10, 2007 | 01:15 PM
MaxDom03's Avatar
Was that a tough fix to do it yourself? Or did you have a shop do it? I thought I remember reading that it was a total pain to replace the evap canister
IlyaK
23
Mar 1, 2016 09:15 AM
Ray Kirschner
Oct 4, 2013 09:12 AM
scottie99
Aug 6, 2013 01:54 PM
defiance
Sep 10, 2012 01:17 PM
Lateapexit
Jul 6, 2003 09:59 AM
