Check This OUT!!!
Old Jul 12, 2001 | 06:18 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Ok it's not a performance mod, but it's still cool.
The "OTTO SCAN" software can use your OBD-II port ALL '96+ cars have, to tell your ECU sensor values and codes. Sort of like the TECHTOM MD-100, but instead of a neat little LCD display that shows only 3-values at a time, it uses a Palm Pilot/Handspring Visor.
I emailed them to ask if it works on 5th gen Max, and Bill emailed me back and said YES. However, he also stated, "OTTOSCAN works great on the Maxima as I rented one about two weeks ago for testing!" It sounds a little convienent and I don't see a Return Policy on their website. Anyways, he sent me a PDF file with the info, so I'll attach it below.
Anybody interested in trying this? Maybe, we could go in together, since it is $350. I only need the software, since I have a Palm IIIxe and I can make the cable at work. You would have to also have a Palm III though.
Old Jul 12, 2001 | 06:22 PM
IceY2K1's Avatar
Well the attachment didn't work so here is the website:
www.baumtools.com/
Old Jul 12, 2001 | 06:30 PM
IceY2K1's Avatar
Here is the zip file of the feature this thing has.
Old Jul 12, 2001 | 06:36 PM
IceY2K1's Avatar
Damn!! I can't get it to work. I'll try later(hungry now).
Just email me if your SERIOUS on trying this, PLEASE.
Old Jul 12, 2001 | 07:47 PM
ispeed's Avatar
I understand that you may want it for the palm, but if you will settle for use on a laptop you can get a similar program for alot less. I got mine throught a group deal for $73.
www.obd-2.com
You can get the ISO plug that plugs directly into the OBDII output under the dash. I have used to take the readings of my CAI and to diagnose check engine light codes. I am planning for the install of the y-pipe and I want this tool to scan for codes and to get my general data. It was interesting to say the least from my first several scans. It was able to pinpoint my exact high speed and my highest RPM value. It also take Air Intake Temp readins and MAF readings. I like to use the MAF and Throttle Postition Sensor on the digital dash option. You can save your scan and replay it once finished.
Old Jul 12, 2001 | 10:24 PM
IceY2K1's Avatar
www.obd-2.com
Thanks.
Old Jul 12, 2001 | 10:39 PM
unrealii's Avatar
www.obd-2.com
At www.tauruscarclub.com they are currently in a group buy for www.obd-2.com scanners. I think itz 40% off any scanner. If anyone is interested, PM me, and I'll get you more info.
maxinout93
Oct 31, 2015 02:04 AM
magiconthetire
Oct 26, 2015 09:03 PM
salty318
Sep 29, 2015 01:21 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
