Cant read the codes!!!!
I got an ABS light that came up. I went to two different shops today and they could not read of the computer. It says there is no communication. What could it be. ECM? or something else?
I took it to two different shops. I doubt that both of them dont know how to connect it correctly. Nissan wants $110 for diognastics. I dont want to pay that. have any of you guys had this problem. thank you
Originally Posted by Stardust
Only dealers can pull ABS codes.
Originally Posted by magdocjr
Oh, since they can't read your computer, why not just throw the car in the trash and buy something from the 1950-1960s with out a computer. Take the car to the dealer and have it fixed.
The CEL light is NOT on
The first thing I did was i checked all the fuses. Also I already checked the connector.
Actually I checked all the ABS fuses. Should i check any others?
they cannot connect to the computer. They are just random shops that will do free diagnostics. I watched them all and all of them say "cannot connect to computer" or something like that.
You need a Consult to read OUR ABS codes.
^^ unfortunately....
any way to check for damaged sensor using a volt meter? I've had the ABS/TCS/Slip lights on for quite a while now and would like to fix it - just can't be arsed to pay the diagnostic fees... =/
As stated previously, you CANNOT read ABS codes without a "CON"sult tool. Nissan wasn't mandated by the feds to make the ABS system universally readable so they gave the stealerships a bone and made it unreadable by anything but the ConsultII tool.
That said, check your ABS lines. I've rubbed through one and through a code that way. If you've messed with your suspension or brakes lately, it might be loose and the rim could have rubbed through it. You have two routes at that point: replace the line to the tune of $150-$350 OR you can do what I did, splice the wires inside back together for $.50 worth of of crimp connections.
sctludwig
Sep 1, 2022 01:32 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
jchronis2552
Sep 21, 2015 05:52 AM
