Camber Kit
Old May 16, 2007 | 05:29 AM
callkiss's Avatar
Camber Kit
Guys this is crazy does anyone have information of where I could find a camber kit for the 03 maxima SE front and rear? I am not looking for the silly bolts that you can find for the front suspension. If there are none available COTS then does anyone know who will custom make them for Maxima owners?
Old May 16, 2007 | 05:33 AM
SoonerFan's Avatar
Cletus
stillen sells one
Old May 16, 2007 | 05:37 AM
ManUtd18's Avatar
I know this is a nub question, but what do Camber Kits do?
Old May 16, 2007 | 05:42 AM
callkiss's Avatar
Originally Posted by soonerfan
stillen sells one
Hmm... thats funny they never advertise that they sell them, I will check this out when there open today. Thanks!
Old May 16, 2007 | 05:45 AM
callkiss's Avatar
What is camber?
Camber is the inward or outward tilt of the tire/wheel assembly. This angle is measured from a true vertical line, i.e. perpendicular to the ground. A tire/wheel assembly that is tilted outward at the top is considered to have Positive camber. While a tire/wheel assembly tilted inward at the top, displays Negative camber. For a zero setting, the tire/wheel assembly is in the exact vertical position or perpendicular to the ground.
How far can I lower my car before I need to adjust camber?
ANY amount of ride height change will cause camber and toe to change. It might not always be visible but having your camber out of adjustment will cause the tire to run on the inside edge only. The lower you go the more negative camber you will get and the faster the tire will wear. Toe will also be affected. Having your toe out of specifications will wear tires and make the car handle unfavorably.
Reference: http://www.ingallseng.com/faq.htm
Old May 16, 2007 | 05:51 AM
ManUtd18's Avatar
Originally Posted by callkiss
What is camber?
So when you lower your car, you should get a camber kit?
I just lowered my max.
Old May 16, 2007 | 05:55 AM
callkiss's Avatar
I guess to answer your question, "yes." Opinions might differ, but I am going to drop my car another inch (its already dropped 1.5 inches) eventually and I would rather have these cambers installed before I go that far.
Old May 16, 2007 | 06:08 AM
JaKillz2's Avatar
You never answered what camber kits actually DO lol. A camber kit corrects usually negative camber by extending the length of the upper control arm, allowing the ball joint which holds the control arm in place to be adjusted, in turn resetting the wheel to 0. Also, get an allignment!
Old May 16, 2007 | 06:10 AM
callkiss's Avatar
Why thank you
ManUtd18's Avatar
Where can you get camber kits and how much are they?
Old May 16, 2007 | 06:16 AM
SoonerFan's Avatar
Cletus
thats what this thread is about...give it time.
and you dont always need a kit if you are lowered. it depends on the drop. i have H&R and a normal alignment got the camber within specs. you only need the kit if the car is lowered past the point that an alignment can fix it.
Old May 16, 2007 | 06:18 AM
callkiss's Avatar
Sooner said you can find them at Stillen.com, not sure how much yet.
Old May 16, 2007 | 06:19 AM
callkiss's Avatar
Come on Sooner he said he was a newbie Oops not a newbie, but obviously doesn’t know much about this subject.
Old May 16, 2007 | 06:27 AM
SoonerFan's Avatar
Cletus
but he doesnt need to "jack the tread" and act like he is starting the question
Old May 16, 2007 | 06:34 AM
callkiss's Avatar
Oops I see
Old May 16, 2007 | 06:35 AM
SoonerFan's Avatar
Cletus
Oops I see
and i just remembered that i dont like you...i dont remember why...but i still do
Old May 16, 2007 | 06:38 AM
callkiss's Avatar
That cool, your are allow to feel what you feel, this is America.
Old May 16, 2007 | 06:55 AM
ManUtd18's Avatar
Sorry Soonerfan, I didn't mean to "jack the thread".
Old May 16, 2007 | 06:57 AM
MaximumPower01's Avatar
lol
Some people should seriously remove the wad still stuck in their panties......
Old May 16, 2007 | 07:18 AM
SoonerFan's Avatar
Cletus
did people ignore the smilie implying it was a joke?
proof that it was a joke...i answered the question
and way to quote me and take the time to remove the smilie to make it seem like i was serious
Old May 16, 2007 | 07:23 AM
callkiss's Avatar
Ok, Ok Sooner, it really isn't a big deal I am cool with you.
Old May 16, 2007 | 07:24 AM
SoonerFan's Avatar
Cletus
go back to the DC forum
Old May 17, 2007 | 02:23 AM
callkiss's Avatar
stillen sells one
I called Stillen and they no longer carry the camber plates . I asked could it be custom made being that they once sold it? Stillen said, "No." All they have is that Frackin camber bolt which I heard is hard to adjust during your inlinement process.
Old May 17, 2007 | 07:12 AM
irish44j's Avatar
retired moderator
Stillen hasn't made them in about 2 years. When they did make them, they ran about $400 for the set. I used to have them, but took them off because frankly, I didn't need them, and the upper mount made alot of freakin' noise.
Old May 17, 2007 | 09:23 AM
myktek's Avatar
eibach makes them, there is a group deal on it, i posted in the thread on how to use them b/c they look really weird
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
