torque specs
Old May 20, 2007 | 01:28 PM
absoundlab
torque specs
does anyone know what the torque specs are for the flywheel bolts?
Old May 20, 2007 | 03:00 PM
SEmy2K2go's Avatar
Go BUCKS!!!
The search function is a great feature.
http://forums.maxima.org/showthread.php?t=440195
Old May 21, 2007 | 10:08 AM
absoundlab
It doesn't say
Old May 21, 2007 | 03:34 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Was there anything else on that doco other than what you posted?
Old May 21, 2007 | 03:53 PM
Bufflomike's Avatar
Sexier Than Simpson
The specs for these bolts were there when I checked.
Old May 21, 2007 | 05:55 PM
DOHCtorJT's Avatar
61-69 ft/lbs
Old May 21, 2007 | 07:13 PM
absoundlab
thanx alot guys
Old Jul 24, 2008 | 11:52 PM
strudel's Avatar
I going to do a flywheel and clutch install on the weekend on my 98 Maxima SE. It seems that we have a 2 piece flywheel. I have a flywheel replacement but it is the inner part that attaches to the section of the flywheel that has the ring gear on it. I was wondering if anyone could provide the torque specs on that piece. I have the flywheel to crank specs and for the clutch.
The section I am referring to is between #15 and the ring gear section. It has 9 bolts to attach it and I require the specs for that. My manual I got online seems to not have that information in it. Thanks. JS
Old Jul 25, 2008 | 12:14 AM
CMax03's Avatar
If you don't find the torque for the ring gear bolts just use standard torque as per bolt size and thread pitch
Old Jul 25, 2008 | 06:40 AM
hi-tek22's Avatar
this bit of info will help me out on future projects
Old Jul 25, 2008 | 10:33 PM
strudel's Avatar
I went to a shop that resurfaces flywheels today for information as the dealer was fruitless for help. They did some research for me and got hold of the part supplier tech service. Answer was that they just use some locktite and a wrench to do them up. I will use approx 35 ft lb as that seems logical in comparison to the actual clutch bolts from all the manual information I could get. JS
James92SE
142
Jan 2, 2024 09:23 AM
jmlee44
Oct 2, 2022 02:13 PM
Quickywd01
Sep 21, 2016 09:36 PM
The Wizard
24
Oct 1, 2015 08:47 PM
