View Poll Results: Which battery?
Voters: 168. You may not vote on this poll
Battery Replacement
Optima yellow here. Never again. Too much money for only a mid-perfomer of a battery. They do look good but I think they should last longer than 3 years. Probably going to go Duralast as they have worked well in my motorhome.
Originally Posted by CaTalyst.X
Interstate battery would be the best choice if you dont have a system. They last forever, start everytime.
Interstates have served me best over the years through Chicagoland winters, reasonable sound systems, occasional deep cycles, and even a roll-over accident./serious
Originally Posted by bwinter7
Originally Posted by CannaBis
12-twenty packs of Duracell AA's.
Try NIMH instead.
___
JLD
Battery finally died today
Of course the battery dies when I need to get to work this morning. So after some more research (ConsumerReports.org) I was thinking of going with the EverStart Maxx (Wal-Mart Brand) which has a 36/108 warranty and 700CCA.
Does anyone have any experience with this brand?
Originally Posted by mtl-maximus
The original battery on my 2k Max lasted for 7 yrs.
Last winter had some issues starting the car at -25C so I went and changed at the stealership. I'll see how good the new one is...
I picked up an Everstart from Wal-Mart last July for my 97 grand prix, The dual connector one and its been great so far as it should be. Fresh too, Was made a month earlier.
Bought one of those for my truck a few years back. Very good for the price.
Originally Posted by JimmyH
7 years 166000 miles on my oem non-maintenence free battery. Keep filling them with water and lube the terminals and they will outlast 20 "maintenence-free" batteries.
Originally Posted by Torgus
at full tilt i'm running 2000w RMS of a possible 2400. i dim alot. sucks...any suggestions are welcome. i have hifonics diamond and kicker for amps which are all decent brands. as i stated above i'll do the big 3 and throw a redtop in my bay and move my current batt to the trunk. if that doesn't fix it yellowtop in the trunk + my current batt.
In my max the dealer stuck in a Honda Battery, seriously that's what it says on the side. But in my Bronco I have a red top. I've had it for I think a little under 2.5 years and it just works. Even when it is low it will still start the 351 under the hood. I also put it through it's paces, when I got it I only had a 95 amp alt. Even with only that it powered a set of 2nd gen max fans for cooling, a 1500 watt amp that powered 2 12s, a 200 watt head unit, 2 Hella 500s, fogs and of course the standard headlights. If that doesn't put a load on the battey I don't know what will. Oh and never a drainage issue. Since then I have upgraded to a 130 amp alt, bigger charge wire, removed the fogs (one of them is grounding internally) and changed the fan to that of a lincon mark VIII (Single fan). I can leave the truck sitting for more than a week and that battery will still hit the starter as hard as ever.
Oh and I voted yellow top, that way if or when you decide to upgrade your electronics you will have a battery that will allow them to run long after the engine is off.
Oh and the great thing about the optimas, they don't get post corosion. I used to have to clean the posts of my lead-acid batterys once every month or so, since installing the red I never have had to clean it. In fact the only time I even look at the battery is when I'm jumping other vehicles with it.
Originally Posted by charr82
This is the battery I went with recently. My OEM lasted about 4 years and 186,000 miles. The EverStart Maxx has an excellent warranty, cheap price, and is made by Johnson Controls. I had them test mine before I bought it and it tested at 780CCA even though it is rated for 700CCA. It should be good for a long time.
Originally Posted by machinehead131
186k holy cow, thats a lot. Curious to see how long it lasts. Are you auto or 6 speed? Same clutch if 6 speed?
Anyway...we should probably let this thread get back on topic.
Originally Posted by MillionBlades
My local nissan shop told me that its $100 for a new OEM battery. Should I go with Interstate or Gold/Platinum Start?
$100 for a battery made by "some company" who can at least manage to make a battery to Nissan's standards.....
OR...
$60-80 for an Interstate battery; you know the manufacturer, and it's less.
ALTHOUGH...
I'm an Interstate guy, I'll always trust 'em; but it's still cheaper.
That's the info from me; What info do you have to offer? Big stereo or other high drain devies? If you have them, do you run them for long without the car running?... etc. What's your needs?
___
JLD
doobadoo
Aug 15, 2015 06:43 PM
