Knock Noise from back right wheel when I slow down!
Please help - everytime when I appraoch a stop sign or a red light I hear a knocking noise when I am at like 20 miles and hour or less. Could it be the strut?
When I slow down on the highway from like 70 to 20 its perfectly fine , it only happens at low speed. Please help.
here's one: check to make sure the brake caliper bolts are tight on the rear. I once had one of the two bolts come out and teh caliper was actually swinging out a bit until the inside of the wheel stopped it....
Well - I think im going to take it to the mechanic because its really annoying everytime I slow down I hear this knocking noise. If anyone else has any idea what it can be - please advise. I will keep you posted.
just came back from a friend-mechanic....
the knocking noise was caused by..... (drum roll) brake bads... they were a little bit smaller than they were supposed to be by few millimeters, and every time i was braking they would move up and down hitting the caliper.
what's worse.. that hitting caused all 4 pads to crack...some cracks were small some were huge... i just installed set of new pads... knocking's gone. yey.. these fit perfectly and don't move up and down.
i hope your problem is as simple as mine and it won't cost you a lot to fix.
CorollaULEV
30
08-09-2021 08:11 PM
Rage Maximus
09-03-2015 12:26 PM
