Which ES motor mounts
Old May 24, 2007 | 06:01 PM
brusk's Avatar
I've been searching and unfortunately just come up with a bunch of stuff i didn't need to see like traction bars and stuff. I see ES has two motor mounts listed 7.1116 (57)-Motor Subframe Bushing Set- front lower
and 7.1114 (57)-Motor Mount Replacements (two torque mount positions only) what is the difference between the two. Which would do I want just to stiffen the engine mounts a little. I don't want any harsh vibrations or anything.
Old May 24, 2007 | 06:03 PM
absoundlab
cattman sells them. just get front and rear motor mounts
Old May 24, 2007 | 06:07 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
is there a how to on how to install this w/pics? how hard is it?? a shop wanted to charge a few hundred just for the motor mounts to be installed.....
Old May 24, 2007 | 06:39 PM
Puppetmaster's Avatar
The lower subframe bushings 7.1116 replace the four bushings that go on the center member.
The motor mount inserts 7.1114 replace your stock motor mount inserts; they are solid inserts vs. the stock liquid filled inserts.
IMO, the motor mount inserts make a bigger difference in terms of throttle response, but the lower subframe bushings are cheap and easy to do.
Old May 24, 2007 | 06:42 PM
MyBlue02's Avatar
this is my next mod...are hte subframes worth it...sounds like hte motors make the biggest diff (planning on doing "A" arms too when i need suspension work)
Old May 24, 2007 | 06:44 PM
The best (cheapest) way to get these installed is to:
1. Remove the center member yourself
2. Remove the front and rear motor mounts (which contain the inserts) from the center member
3. Take those to a shop with a press, have the shop press the old inserts out and the new ones in
4. Go home and reinstall the motor mounts and center member
Do a search for Polo's thread on ES products or my posts on motor mounts for more information.
Old May 24, 2007 | 07:04 PM
absoundlab
A + + thats the best way to do it
Old May 24, 2007 | 07:23 PM
PoLo's Avatar
2-Wheelin it...
everything ES related....
http://www.digitalpolo.com/Cars/2002...rgySuspension/
Old May 24, 2007 | 08:05 PM
Maxima112's Avatar
Originally Posted by PoLo
OMGGGGG thanks! i went to the how to link and it is dead....
i plan on doing the motor mount for sure, do you guys think the front and rear control arm is worth the extra 120ish?? when i make a left or right turn at normal speeds running over a bump in the road the car seems to slip to one side (almost feels like loosing control). Im thinking the control arm bushings are dead....but i dont know much about it, so any advice would be great. thanks again polo for the link.
Old May 24, 2007 | 10:41 PM
zero2sixtyZ's Avatar
You embarrass me.
Best price I could find them for:
http://www.energysuspensionparts.com...E1114&cat=4208
Old May 25, 2007 | 06:47 AM
OOmaxSE's Avatar
I hear that the Place Racing motor mounts are way stiffer than these ES. You should look further into that, although I'm not even sure where you would start!
I'm searching now...
Old May 25, 2007 | 09:58 AM
nismopc's Avatar
Good luck on the research....
404 error: company not found
Old May 25, 2007 | 10:06 AM
VIP Maxima
why dont u just fill them in?
Old May 26, 2007 | 08:18 AM
joebangaa's Avatar
Fill them with what??
Old May 26, 2007 | 08:33 AM
VIP Maxima
most people fill them in, im not quiet sure what they use, last i heard it was window sealer. i dont have search or id searh. maybe start a thread and ask
Old May 26, 2007 | 09:16 AM
phatmax95's Avatar
I just did this a while back.
http://forums.maxima.org/showthread.php?t=516635
Old May 26, 2007 | 09:38 AM
nismopc's Avatar
3M WindowWeld is what I used on my G20 a few years back. Comes in a tube and is easily applied with a caulking gun.
http://www.mcmaster-carr.com McMaster Polyurethane is another highly recognized product for this. It's a bit messier but supposedly holds up really well and comes in different strengths
PL Polyurethane roofing comes in tubes and is available at home hardware stores. Usually brown in color. Almost identical to 3M WindowWeld, but cheaper.
Old May 26, 2007 | 10:09 AM
VIP Maxima
yup but i dont think 3M windowweld is something that would withstand the torque of a VQ, specially since i am going to be boosted soon. my mounts are shot as well and im thinkin if imma like the stiffness of the ES or i should just refill them and see how long they last.
u have the direct link to the mcmaster
Old May 26, 2007 | 02:29 PM
http://forums.maxima.org/showpost.ph...2&postcount=15
From: http://forums.maxima.org/showthread....t=polyurethane
Old May 26, 2007 | 02:38 PM
joebangaa's Avatar
thank you almighty mod
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
