Am I wrong or is this a steal??
Old May 25, 2007 | 09:43 PM
iyzmi's Avatar
http://cgi.ebay.com/ebaymotors/2000-...QQcmdZViewItem
I live in Milwaukee so I can go take a look at it but I just wanted to make sure this is what I want. Does this car have every available option for 5th gens? I don't have a list of available options so I'm asking you guys. Thoughts on this car? The price looks unbelievable, most 4th gens go for around $7k!
Old May 25, 2007 | 09:52 PM
absoundlab
it looks good i'd jump on it if I were you. and its got carfax buyback on it.
Old May 25, 2007 | 09:58 PM
d00df00d's Avatar
Old enuf to pick his own gears
It does say the AC doesn't blow cold, which is "most likely a compressor issue" a.k.a. the guy has no idea why. A shop could easily charge several hundred dollars or more to fix that problem, so that money needs to come out of the price of the car.
I also noticed the seller mentioned nothing about the condition of the suspension. That may or may not have been intentional...
iyzmi's Avatar
But I don't think the AC is worth not buying the car over, eh? What should I look for in the suspension to diagnose any problems?
I think I'm gonna give the guy a call and see if I can arrange a meeting... $6.5k for a 5th gen with 100k sounds MORE than fair to me...
Old May 25, 2007 | 10:19 PM
Torgus's Avatar
look.
it's WAY under book value.
there is someting wrong with it.
i used to sell cars. there is no way ANYONE would sell it for that price unless it had issues. it would go at an auction for around that price...i wouldn't buy it unless you can see it in person and bring it to a mechanic whom you KNOW. BUYER BEWARE.
if you ask me the compressor is blown some struts are bad and the clutch is on it's way out(any car over 100k you have to expect to replace the stock clutch). around 2k in repairs at a shop.
oh and the front grill is painted which means it's been modified aka driven by a kid.
oh and the tires look close to bald. add another 500 in new rubber M+B.
and why the hell is the guy pointing at the roof in the pic...?
Old May 26, 2007 | 12:13 AM
Mr. Blue Sky's Avatar
I agree that a car for that price usually has some gremlins. A little while after I bought my 2000 GLE for ($5500, clean title), I have replaced the brakes, passenger side axle(boot broke about a week after I bought it), repainted front end (rock chips went all the way to the sheet metal and lowest layer of the bumper), and am going to be replacing an O2 sensor, doing the timing belt(just in case), and repairing the VIAS. So far it has cost me about $400 with me and my father doing the labor (friend is painting front end), with another couple of hundred for the other things I need to do.
Its best to check it out mechanically before you buy to see if it is worth it, you always get what ya pay for.
Old May 26, 2007 | 05:50 AM
Nomad's Avatar
Originally Posted by Torgus
look.
his pointing at the dent on the roof
Old May 26, 2007 | 06:18 AM
Squirrel82's Avatar
The grille could be black because its had bumper work done and they were just lazy to 2 tone it.
Old May 26, 2007 | 06:21 AM
Torgus's Avatar
timing chain. we don't have belts. only chains and on that model they are not known to go bad. unless i had the cover open for some other reason i wouldn't change it...and even then i might not change it... certainly i wouldn't pay to replace it. they aren't known to go bad at that mileage.
another thing to take into consideration AFTER you've had a mechanic check it out is that any vehicle with 100k+ is you should give it a full tune up:
6 ngk plat plugs
300zx fuel filter
oem pcv valve
K&N drop in airfilter(lifetime warranty FTW)
seafoam if you belive in it, and then an oil change.
FLUSH and refill ALL fluids
belts unless they are in good shape
etc...
you can do more but that should be enough imo.
which is going to run you around 500 at a shop or 200 to do it yourself.
Old May 26, 2007 | 06:26 AM
Torgus's Avatar
umm if his grill was damaged they would have had to get a new one from Nissan. you don't bondo and then paint a grill...also afaik there are no unpainted replacements available from any other company that a body shop would have gone with. so to be it looks like he painted it either himself(the previous owner) or by a shop. which then leads you to believe there has been a front end collision as the average person who does nothing else to his car(unless eh returned it to stock form) would not pay a shop to paint a grill on a whim. now if the car fax doesn't have a report of a front end collision then again i would be skeptical...
edit: they say the carfax is clean. so why is the front grill painted and no other mods cosmetic or otherwise done...?
Old May 26, 2007 | 08:13 AM
iyzmi's Avatar
What to you guys think of the AC problem... It sounds to me like a freon leak and that would mean replacing the entire AC system which is over $1k if I'm not mistaken.
Old May 26, 2007 | 08:29 AM
Torgus's Avatar
if your really interested in the car pay 100 for a tow to and from a reputable mechanic in the area and pay him 50 bucks to look ALL over it. best advice i can say...as for the AC who knows.
Old May 26, 2007 | 08:58 AM
Woo Cho's Avatar
My max is 2k GLE with 90k miles on it. My AC is not blowing cold air so I took it to mechanic thinking that I just need some freon, after refilling it we found the leak and checked where the leak was coming from, my mechanic told me that AC condensitor or something (I'm not sure if I spelled it wrong) and it's costing me $427 for that to be replaced.
Old May 26, 2007 | 09:09 AM
NiSmOVQ35's Avatar
What bothers me about the car is the front end is VERY clean, theres no way it could be that rock chip free unless its been repainted, take a mechanic with you make sure all parts are oem. I have a feeling its been hit.
Old May 26, 2007 | 09:18 AM
nismopc's Avatar
I bought my '02 SE with 59k and the delaer repainted the hood, front and rear bumpers due to normal wear and tear, rock chips, parallel parking, etc. It looked almost new. After driving it 1 year and 35k later, the front end looks like hell. I see no issues with the front of the car being as clean as it is for this specific reason.
If you are interested, as you stated, just contact the seller. Ask him all important questions, if you feel confident in his responses, buy it. That is a hell of a price, it is used and will never be in NEW condition.
Old May 26, 2007 | 09:22 AM
nismopc's Avatar
What reason would you have to say that a kid drove the car because the front grill had been repainted. Illogical and stereotyping.
I have very rarely ever bought a used car that had more than 50% tread on the tires. Most people, including dealers do not replace tires that still have some meat on them to sell the car. It's an overhead expense they don't want to deal with. That seems normal to me.
As stated, DENT in hood.
Old May 26, 2007 | 09:31 AM
nismopc's Avatar
iyzmi, just based on this picture alone, there appears to have been NO frontal impact damage to the car. The factory OEM stickers are located in the exact position they should be and the radiator support appears to be in straight and perfact condition.
I'll take a stab that the front hood, fenders, and bumper could have been repainted due to the fabulous and infamous OEM Nissan paint chipping off. Very common practice for dealers to do this before selling a car. Ask the seller about it and see what they say...
Old May 26, 2007 | 11:28 AM
Torgus's Avatar
the dent was explained to me above. way to read the thread.
i mention the tires because the PURCHASER and THREAD STARTER might not have noticed that, and i feel he needs to know about the extra money he is going to have to put into the car. new tires, tune up, etc.
i sold cars i know how the game is played better then most.
KIDS generally paint parts of their car. the MAJORITY of modified cars are owned by kids not adults. that is a fact. it is NOT stereotyping it is a generalization. i guarantee the average age on the org is under 25. maybe in the eyes of the law your an adult but most 20 something yr olds are in between the teen/adult stage.
if you have a problem with me finish it in PMs. this person's thread is not the place.
thanks,
--jon
edit: also going with the whole stealerships hate to spend $ fixing a car. they would not spend the time and money respraying it. as you obviously know...
Old May 26, 2007 | 11:33 AM
Kevlo911's Avatar
Kevlo for President
And the rust
Old May 26, 2007 | 11:52 AM
nismopc's Avatar
As stated, I stated the same stated statement. So there. It was suppose to be humerous. Guess not.
maybe in the eyes of the law your an adult but most 20 something yr olds are in between the teen/adult stage...
You obviously have no idea of my age, as it is not posted anywhere, but I am quite past the 20 somethings.
if you have a problem with me finish it in PMs. this person's thread is not the place. ..
My thread was in no way meant to be taken negatively so I will not continue this in a PM nor will I respond to your defensive tackets.
Unfortunately, I saw more negative responses to iyzmi's initial post basically telling him to not even take interest in the car. He might have actually found a great car to purchase, but might shy away because of these posts. He needs to know the positives and negatives with buying a vehicle.
I personally see nothing shady about this eBay Buy It Now vehicle. I would, as should any interested buyer, contact the buyer and ask questions. It's not that hard to tell if the seller is attempting to hide something AND if purchased he has a CarFax buy back guarantee. That pretty much seals the deal for me.
Old May 26, 2007 | 11:53 AM
Gennady7's Avatar
Um I have a 00 max and trying to sell it on Craigslist and other sources for 6500 and there no demand for Maximas. I hate to say it but that price is the average selling price for a Maxima that is 7 years old and has 100k miles.
Old May 26, 2007 | 11:57 AM
nismopc's Avatar
Tires that are 50% tread are cosmetically fine when a potential buyer looks as a used car. Paint chips, faded paint, cracked windshields, etc. are cosmetically bad when attempting to sell a car.
Yes, I am quite aware of the marketing and selling of used (and new) vehicles. I know what sells and what does not.
Obviously...
Old May 26, 2007 | 11:58 AM
nismopc's Avatar
I agree!
Old May 26, 2007 | 02:17 PM
Bluesbrekr's Avatar
Doctorate in Detailing
Well, the seller ended the auction early.
The front end has been repainted.....you can see buffer trails on the hood, and as mentioned there are no rock chips/marks on the front end.
Old May 26, 2007 | 05:36 PM
iyzmi's Avatar
Doesn't matter anymore. I just spontaniously (sp) bought a brand new Impreza 2.5i. It's been fun here on the maxima boards even though it only lasted like a month. Thanks for all the help!
Old May 26, 2007 | 05:38 PM
Squirrel82's Avatar
Post picture
Old May 26, 2007 | 06:41 PM
Whiggy's Avatar
Just ran the Autocheck on it - it has frame damage.
Old May 26, 2007 | 06:48 PM
AceofSpds's Avatar
wat
+2 on that one
That car does have allot of options though, hell i was gonna take 6,000 for mine about half a year ago and it was at 108k mi.
Old May 26, 2007 | 07:29 PM
Torgus's Avatar
w00t i called it 1st i said it was in an accident and said it was a BAD buy!
torgus ftw.
frame damage means it isn't worth ****.
you should be GLAD you did not buy it.
nismopc: i guess it's good i was so negative huh? if he went and bought it and found out his car was worth aroudn 2-3k instead of 6-8k he wouldn't have been happy...
edit: the resale value of a car is really affected by it's miles. 100k+ is hard to get a loan for unless you have decent credit(i know i sold cars and we hated having vehicals over 100k because you need either good credit or a big downpayment or both which 75% of americans don't have) credit unions are generally better to go for when you want to purchase a car above 100k for what it's worth...the way i look at it is sell it when it has 80k or plan on driving it untill 150k+. otherwise your losing money on it generally.
Old May 26, 2007 | 08:27 PM
1phtmax's Avatar
i see to much rust
Old May 26, 2007 | 08:33 PM
iyzmi's Avatar
That makes me glad I bought a brand new Impreza.
I'm picking it up Thurs so no pics till then. It's black w/ spoiler.
Old May 26, 2007 | 09:04 PM
Torgus's Avatar
j/k
grants on the new ride. sorry to see it isn't a maxima but i think you'll enjoy the car. make sure to show us some pics of what you got!
edit: tell me you got the wrx...please.
Old May 26, 2007 | 10:29 PM
iyzmi's Avatar
I'm sorry to disappoint you but the monthly payments on the WRX were out of my range. Will post pics sometime next week if I have the time.
I'm actually still double guessing myself, I'm going to be paying $7,500 for a car I'll use for 3.5yrs whereas I can get a Maxima for that price and have it for forever.... I have 3 days to cancel my contract, I don't think I'm going to but my realistic side is telling me the Max is a better choice. But the Subaru has the new car smell. lol
Old May 26, 2007 | 10:51 PM
AnDyMaN's Avatar
i had a 2000 maxima, 5 speed, fully loaded except heated seats. i sold the car with 2003 headlights, stillen kit, kyb shocks, s tech suspension for 6400 cash. car had 105,000 miles on it
it had a dent on the door, clutch line needed replacing (connecting to slave cylinder?) and thats about it. clean title, no frame damage..
you can find good condition cars for cheap... its not always a bad buy... but i guess in this case it happened to be..
Old May 27, 2007 | 04:32 AM
nismopc's Avatar
Did you actually pay for that or do you have unlimited access?
Would you please post the results. I am interested to see how seller could state it had a clean CarFax but Autocheck actually reported differently.
Old May 27, 2007 | 06:46 AM
Torgus's Avatar
dealership lie all the time. lots of people believe what they say and would NEVER check. sucks but it's the truth.
Old May 27, 2007 | 06:50 AM
02Maximan's Avatar
Would you please post the results. I am interested to see how seller could state it had a clean CarFax but Autocheck actually reported differently.[/QUOTE]
Yeah what he said. So just because the car checks out ok on carfax, doesn't mean that it's fine or what?
Old May 27, 2007 | 07:35 AM
Torgus's Avatar
you don't have to report any accident to an insurance company afaik. you can pay out of pocket to get it fixed. thus noone knows it was ever in a crash saving your resale value of the car.
Old May 27, 2007 | 07:42 AM
Whiggy's Avatar
Your AutoCheck Vehicle History Report
WARNING! This vehicle does NOT qualify as AutoCheck Assured
The vehicle identification number you submitted has been analyzed and summary information on your car is shown below.
Report Run Date: 05/27/2007
Vehicle Description: JN1CA31A8YT006788
Title Check: No record Reported to AutoCheck
Problem Check: Record(s) Reported to AutoCheck
Odometer Check: Record(s) Reported to AutoCheck
Vehicle Information: Record(s) Reported to AutoCheck
Full History: Record(s) Reported to AutoCheck
Vehicle Description | TitleCheck | ProblemCheck | OdometerCheck | Vehicle Information | Full History
Vehicle Description
VIN: JN1CA31A8YT006788
Year: 2000
Make: Nissan
Model: Maxima GLE /GXE /SE
Style/Body: Sedan 4D
Engine: 3.0L V6 EFI
Country of Assembly: Japan
TitleCheck
Your Vehicle Checks Out! AutoCheck's database for this 2000 Nissan Maxima GLE /GXE /SE (JN1CA31A8YT006788) show no significant Title events. When found, events often indicate past automotive damage or warnings associated with the vehicle title.
Problems Checked Results Found
Abandoned No Abandoned Record Reported to AutoCheck
Damaged No Damaged Record Reported to AutoCheck
Fire Damage No Fire Damage Record Reported to AutoCheck
Grey Market No Grey Market Record Reported to AutoCheck
Hail Damage No Hail Damage Record Reported to AutoCheck
Insurance Loss No Insurance Loss Record Reported to AutoCheck
Junk No Junk Record Reported to AutoCheck
Rebuilt/Rebuildable No Rebuilt/Rebuildable Record Reported to AutoCheck
Salvage No Salvage Record Reported to AutoCheck
ProblemCheck
Problem Found! AutoCheck's database for this 2000 Nissan Maxima GLE /GXE /SE (JN1CA31A8YT006788) found history events that indicate a significant automotive problem. These problems can indicate previous car damage, theft or other significant problems.
NHTSA Crash Test Vehicle No NHTSA Crash Test Vehicle Record Reported to AutoCheck
Frame Damage Frame Damage Record(s) Reported to AutoCheck
Major Damage Incident No Major Damage Incident Record Reported to AutoCheck
Manufacturer Buyback/Lemon No Manufacturer Buyback/Lemon Record Reported to AutoCheck
Odometer Problem No Odometer Problem Record Reported to AutoCheck
Recycled No Recycled Record Reported to AutoCheck
Salvage Auction No Salvage Auction Record Reported to AutoCheck
Water Damage No Water Damage Record Reported to AutoCheck
OdometerCheck
Your Vehicle Checks Out! For this 2000 Nissan Maxima GLE /GXE /SE (JN1CA31A8YT006788) no indication of an odometer rollback or tampering was found. We calculate odometer rollbacks by using AutoCheck business rules to determine reported odometer readings are less than a previously reported value. Other odometer events can report events of tampering, or possible odometer breakage. AutoCheck's business rules have been created and refined to help identify potential rollbacks from the reported odometer readings. Not all odometer readings are used to determine rollbacks.
Date Reported Odometer Reading
09/27/1999 32
08/25/2004 55,000
11/02/2005 63,753
02/10/2006 76,078
02/05/2007 99,534
02/08/2007 99,534
04/16/2007 99,559
04/17/2007 99,559
Vehicle Information
Information Found! AutoCheck found additional information on this vehicle. These records will provide you with more past history for this 2000 Nissan Maxima GLE /GXE /SE (JN1CA31A8YT006788)
Accident Data No Accidents Reported Through State Agencies Or Independent Sources
Corrected Title Corrected Title Record(s) Reported to AutoCheck
Driver Education No Driver Education Record Reported to AutoCheck
Duplicate Title No Duplicate Title Record Reported to AutoCheck
Emission/Safety Inspection Emission/Safety Inspection Record(s) Reported to AutoCheck
Fire Damage Incident No Fire Damage Incident Record Reported to AutoCheck
Lease No Lease Record Reported to AutoCheck
Lien Lien Record(s) Reported to AutoCheck
Livery Use No Livery Use Record Reported to AutoCheck
Government Use No Government Use Record Reported to AutoCheck
Police Use No Police Use Record Reported to AutoCheck
Fleet No Fleet Record Reported to AutoCheck
Fleet and/or Rental No Fleet and/or Rental Record Reported to AutoCheck
Rental No Rental Record Reported to AutoCheck
Fleet and/or Lease Fleet and/or Lease Record(s) Reported to AutoCheck
Repossessed No Repossessed Record Reported to AutoCheck
Storm Area Registration/Title No Storm Area Registration/Title Record Reported to AutoCheck
Taxi Use No Taxi Use Record Reported to AutoCheck
Theft No Theft Record Reported to AutoCheck
Full History
Below are the historical events for this vehicle listed in chronological order. Any discrepancies will be in bold text.
Vehicle: 2000 Nissan Maxima GLE /GXE /SE (JN1CA31A8YT006788)
Event Date Event Location Odometer Reading Data Source Event Detail
08/30/1999 LEMONT, IL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
09/27/1999 LEMONT, IL 32 Motor Vehicle Dept. TITLE (Title #:T9270461004)
08/16/2000 LEMONT, IL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
07/27/2001 LEMONT, IL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
08/07/2002 LEMONT, IL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
06/27/2003 LEMONT, IL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
07/15/2004 LEMONT, IL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
08/25/2004 CHICAGO, IL 55,000 Independent Emission Source PASSED EMISSION INSPECTION
07/27/2005 WILLOWBROOK, IL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
10/26/2005 WILLOWBROOK, IL Motor Vehicle Dept. REGISTRATION EVENT/RENEWAL
11/02/2005 WILLOWBROOK, IL 63,753 Motor Vehicle Dept. TITLE (Title #:X5306175017)
02/10/2006 WESTMONT, IL 76,078 Motor Vehicle Dept. TITLE (Title #:X6041214047)(Lien Reported)
CORRECTED TITLE
02/05/2007 IL 99,534 Auto Auction REPORTED AT AUTO AUCTION
02/08/2007 IL 99,534 Auto Auction AUCTION ANNOUNCED AS FLEET/LEASE
02/09/2007 IL Auto Auction AUCTION ANNOUNCED AS UNIBODY DAMAGE
04/16/2007 IL 99,559 Auto Auction REPORTED AT AUTO AUCTION
04/17/2007 IL 99,559 Auto Auction REPORTED AT AUTO AUCTION AS DEALER VEHICLE
AutoCheck vehicle history report Terms and Conditions
This report, and any reliance upon it, is subject to AutoCheck Terms and Conditions. If you obtained the report from a dealer, the dealer has been provided with these Terms & Conditions and can share them with you. These AutoCheck Terms and Conditions are also available at any time at www.autocheck.com/terms or by writing to Experian: Experian Automotive C/O AutoCheck Customer Service 955 American Lane Schaumburg IL 60173
AutoCheck Buyback Protection Terms and Conditions
This vehicle (JN1CA31A8YT006788) does not quailify for AutoCheck Buyback Protection.
About AutoCheck
AutoCheck vehicle history reports by Experian Automotive is the leading vehicle history reporting service. With expert data handling, the Experian Automotive database houses over 4 billion records on a half a billion vehicles. Every AutoCheck vehicle history report will give you confidence when buying or selling your next used vehicle, with superior customer service every step of the way.
Old May 27, 2007 | 08:48 AM
nismopc's Avatar
Thanks Whiggy!
