just installed struts and springs and...
Old May 26, 2007 | 02:48 AM
Black026spdLSD's Avatar
I just installed some GR-2s and the Progress springs all arround and as I was pulling out of my garrage I noticed that the rears made a clunking or almost screetching noise when I went over the bump out of my garage. I have done everything exactally as http://www.innerbean.com/housecor/su...on_noises.html
this site has said and I am not sure where it is comming from. Any help would be greatly appriciated.
Old May 26, 2007 | 02:57 AM
Looking at it further, I seem to realize that the noise is directly comming from the upper mounting points in the trunk. I can actually see the top of the top hat actually move up and down from inside the trunk if I push down and then up on the trunk a few times, making the noise louder and louder as I push harder.
Old May 26, 2007 | 09:43 AM
nismopc's Avatar
Uh, sounds like you did not tighten down the hat bolts. Recheck the bolts now that it is loaded and retorque them.
Old May 26, 2007 | 10:21 AM
I just tried it and i am getting the same result... I think I am going to redo the strut and see if there was something else I missed again. If you can think of anything else that it possibly could be please just jot something down.
Thanks Guys
Old May 26, 2007 | 11:36 AM
can anyone put up a more detailed pic of the upper strut mount with the top hat completley assembled still out of the car prefferably... if its a pic when its in the car that will work also... im just lost and frustrated.
thanks
Old May 26, 2007 | 01:26 PM
Larrio Motors's Avatar
Boss Chen Industries
You are probably spinning the shock shaft when you are trying to tighten down the top nut.
Take it out completely and torque it down properly. You may have to use a vise grip and heavy cloth to hold the shock shaft while trying to tighten the top nut. Make sure not to scratch the shock shaft.
Old May 26, 2007 | 02:59 PM
WOW, all I had to do was to move the small round dome looking "spacer" or "stopper", or whatever you call it. I just had it in the wrong spot... I dont know how but you guys def. helped with your siguestions. I got it all right. haha thanks
Alex
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
