Slow Windows
Old May 29, 2007 | 09:27 AM
steves01max's Avatar
Slow Windows
My passenger side window works from both front switches. My problem is that it rises SLOW from about the bottom to half-way up and then shoots up normally after it is closed halfway. The motor is fine, the problem is the window itself. Is there any type of grease or lubrication that I can apply to the window to get it to rise normally? Thanks.
Old May 29, 2007 | 11:38 AM
BLUEMAX01SE's Avatar
I have had this problem for the longest and only on the front passenger window, rolls down fine, takes forever to roll back up, tried seafoam but it was only temporary and not long until it was back to it slow self again! Still looking for a cure, until then I have just learned to deal with it! Good luck!
Old May 29, 2007 | 11:44 AM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
its a common problem with the 5th gens....best thing to do it clean our the tracks, and use lithium sp? grease. it come in a spray can and regrease the tracks once in a while. also if you use rain-x on the exterior of the window it helps a little. and regreasing the metal wire inside the door.
if it annoys you like crazy, change out the motor (i know you're works fine) BUT i changed one of mine out when it broke and compared to the rest that one rolls up and down like a champ. costs like 50 bucks on ebay and about 1 hour of work. good luck!
Old May 29, 2007 | 11:55 AM
DrunkieTheBear's Avatar
Turbo'd Saab
when i put my grounding kit in it seemed to help, along with regreasing...
i noticed when its hot out that its rolls up fast but cold moist weather makes it roll up slow
Old May 29, 2007 | 12:44 PM
Turbo'd Saab
internet at work glitched i thought i didn't post but it posted twice sorry about that
you lose track of a lot things when you are working on about 20 different computers all in the same room at the same time
Old May 29, 2007 | 12:53 PM
SoonerFan's Avatar
Cletus
you need to clean the tracks then spray them with silicon spray (use that because its water based. something oil based like WD40 will attract dirt and make the problem worse).
Old May 29, 2007 | 12:58 PM
Sorry if this is a stupid question but would I need to remove the door panel to get to the tracks or just shoot it down the window jam?
Old May 29, 2007 | 12:59 PM
SoonerFan's Avatar
Cletus
you dont need to remove anything.
roll down the window and clean the up and down tracks. then spray with silicon spray in the track and roll the window up and down to spread it.
Old May 29, 2007 | 01:01 PM
SoonerFan's Avatar
Cletus
from my cardomain
How to fix problem of windows rolling up slow and squeaking.
RED - Run a wet rag in the window track then spray whole thing with silicon spray.
BLUE - Wipe inside both rubber pieces with wet rag.
Old May 29, 2007 | 07:49 PM
wyche89's Avatar
thank God this thread got started because i have the same problem, but didnt consider it serious enough to post about.. i thought it was a weak motor or something like that.. i can get silicon spray at auto zone right?
Old May 30, 2007 | 04:40 PM
Ok great... and yea autozone should sell silicone spray if not any hardware store should. Gettin this done soon when I have an hour or so.
Old May 30, 2007 | 07:18 PM
Rock On!'s Avatar
Puniverse
I have found that cleaning the tracks and all, is only a temporary fix. It wasnt long before it was back to going slow again. I eventually just got used to it
Old May 30, 2007 | 08:40 PM
alpinestars™'s Avatar
THIS IS...
My Max is still under warranty, I was experiencing the exact same problem. I took it to the dealer and my window regulator/motor assembly was replaced. 6 months later same crap. I put some lithitum grease in there and they work great now.
Old May 30, 2007 | 10:46 PM
SilverGLE's Avatar
I'm watching you, boy...
Hell yeah for this thread.... I'll do this this weekend! My damn passenger window goes up semi-slowly, but goes down at normal speed.
Old Jun 2, 2007 | 01:36 PM
wyche89's Avatar
same thing in my car.. and my back left window squeaks sometimes.. all windows are kinda noisy
Old Jun 2, 2007 | 06:11 PM
AL55ES's Avatar
thought i was the only person with this problem
Old Jun 2, 2007 | 09:27 PM
inspiredbykev's Avatar
You should thank my D***
if anyone needs a front passenger side regulator w/motor pm me.
Old Jul 16, 2007 | 09:45 PM
Trurida18's Avatar
so sooner, which silicon spray would u suggest?
Old Jul 16, 2007 | 11:22 PM
SoonerFan's Avatar
Cletus
they all do the same thing
Old Jul 17, 2007 | 02:28 AM
nlmaxima's Avatar
With the window in the down position you should shot the silicon spray down and up the window tracks. This is an excellent thing to do at least a couple times a year. Caution: if you use a petroleum bases spray it can cause the rubber to rot, get sticky or even swell out of shape. Only use the silicon spray and if it is real bad you can use a silicon lube/grease.
Old Jul 17, 2007 | 03:27 AM
SoonerFan's Avatar
Cletus
thanks for the informative post with info that hadnt been covered
from my cardomain
Old Jul 17, 2007 | 09:02 AM
Trurida18's Avatar
any one know of any good sites i can go to and get some water based silicone spray.....Ive stopped at autozone, and advance auto parts, AND THEY ARE ALL DUMB AS HELL. one guy had the nerve to ask me, WHY i wanted water based silicone spray.....
Old Jul 17, 2007 | 12:00 PM
wyche89's Avatar
i just siliconed my windows and theres a slight improvement... the passenger side window rolls up a little faster, but still slower than the drivers side
i always think of it as if the windows are racing... the day that both windows reach the top at the same time... thats when i have achieved success
Old Jul 17, 2007 | 12:57 PM
yycools's Avatar
Sorry to be off-topic, but I just have a general question about the 5.5 gen rear pass. windows. Does it only go down halfway into the door? I just bought a 2002 SE and it seems a little weird that both the rear windows only go down half way. Thanks!
Old Jul 17, 2007 | 01:29 PM
Trurida18's Avatar
^^yes all the 5th gen rear windows ONLY GO HALF WAY DOWN .. the 6th gen maxima's go all the way down however
Old Jul 17, 2007 | 02:05 PM
Maxima112's Avatar
i wonder if anyone has ever tried to change the motors to another kind....what would someone need to determine this? length of the window? wiring? bolting?
Old Jul 17, 2007 | 02:24 PM
DasYears
they only go halfway, this is because the design of the door can only allow that much before it would be hitting the door frame. nothing you can do about it. unfortunately
Old Jul 17, 2007 | 02:25 PM
DasYears
why would you want to do this? the motors are fine, they just need grease sometimes. mine are fine after 5 years and never being greased, but i live in pretty relaxed conditions
Old Jul 17, 2007 | 03:50 PM
stocked out max's Avatar
I cleaned the tracks yesterday and used a lithium cream/paste called "white lube"
i ran the windows up and down about 10 times a piece and windows moved more smoothly, and with no noise.
checked again today and same results
Old Jul 23, 2007 | 09:07 AM
tucker's Avatar
I've lubed all the window channels and it made a little improvement. Has anyone taken the door panel off and lubed the mechanisim itself? I'd like to hear comments about that before I cuss the panel off.
Old Jul 23, 2007 | 09:20 AM
ryant35's Avatar
from my cardomain
Mine are slow too, I'll try this.
But mine don't squeak, they scream like a rodent being smashed.
Old Jul 23, 2007 | 01:10 PM
Trurida18's Avatar
lol.....I also found the silocone spray that might be adequate. Im gonna order a 12 oz can that Amsoil has to offer
Fbana41
Aug 29, 2016 12:18 PM
D Mason
Jun 21, 2016 04:43 AM
Andy29
Sep 29, 2015 05:32 AM
