Cost to replace control arm bushings
Old May 29, 2007 | 11:55 AM
maximo-SE's Avatar
I just came back from the dealer again, it seem like once the car hits 70K, so many things tend to creep up on you.
My control arm bushings needs to be replaced, im not 100% sure if its one side or both sides. The dealer quoted me 600 for parts and labor...
I was surprised. THATS A LOT!
Does anyone know what is the cheapest cost for the bushings (original nissan parts only, i learned that the hard way with aftermarket parts.... )
Does anyone know how much daveB charges for those bushings?
Any help is appreciated.
_john
Old May 29, 2007 | 12:28 PM
Stardust's Avatar
F---ing Kangaroos
If it has to be Nissan parts then you will have to replace the entire control arm. Cattman sells the ES control arm bushings but it doesn't sound like you want to go that route.
Old May 29, 2007 | 12:51 PM
maximadave's Avatar
detailerdaveb@gmail.com
How do you know your control arm bushings need to be replaced?
Old May 29, 2007 | 01:14 PM
maximo-SE's Avatar
the dealer told me the bushings were cracked and they "recommended" that it should be replaced soon.
well i was thinking either gettting aftermarket bushings online and head to a mechanic. Alternatively, I can just go through the nissan dealership and hurt my wallet. I just never had a good experience with regular mechanics and everytime i actually do go back to the dealership, Ive had no problems with my car.....
Old May 29, 2007 | 03:36 PM
Swisscheese's Avatar
lucky you, the stealership does more damage to my maxima than good. They spilt brake fluid on one of my wheels, peeled the chrome right off. The told me that my shock was bad, bought a new one, they replaced it then they realized that it wasn't bad.
Old May 29, 2007 | 04:14 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
I think it maybe cheapest to buy ES bushing and do it yourself. i was quoted about the same from a shop and may just end up doing it myself.
Does anyone have a how to on how to replace the control arm bushings?
Old May 29, 2007 | 04:29 PM
djfrestyl's Avatar
Suspension Yoda
ES control arm bushings >>>> OEM bushings. Pull the control arms yourself, and find a machine shop or any shop to press out the old ones for a couple bucks. The new ES ones will slide right in.
Old May 31, 2007 | 10:43 AM
maximo-SE's Avatar
are these the ones Im supposed to get?
http://cgi.ebay.com/ebaymotors/Front...spagenameZWD1V
is there a guy on the ORG that provides ES bushings?
Old May 31, 2007 | 10:51 AM
Stardust's Avatar
F---ing Kangaroos
Yes!
http://forums.maxima.org/showthread.php?t=522292
Old May 31, 2007 | 12:41 PM
maxima0001
Control arm w/new balljoint from Autozone/Advanced Auto/ect = $124
Time to do the job in = 1 hour or less
The thought of doing it yourself and saving $476 from the stealership =
PRICELESS
ps - Never ever go to the stealership, unless its just to get something checked out)
Then when they approach you with the "problem", say Thank you, and slowly back away......
Once you hit the door......you should be home free (unless captured by a salesman, of course, then you could be there for hours!!!)
Old May 31, 2007 | 01:08 PM
maximo-SE's Avatar
im super noob at under the car mechanics....... and I dont want to f**k anything up.
i might just go through the DAVEB shameless sales thread or autozone and bring it to a mechanic and hope he wont f**k it up....
i just called the dealership again today, and the guy said 850.... WOW!!
Old May 31, 2007 | 03:29 PM
djfrestyl's Avatar
Suspension Yoda
Find a local orger and spot him a couple bucks and some brewskies
Old May 31, 2007 | 03:46 PM
Maxima112's Avatar
any how tos on this?? Polo's site only has the pictures of the control arm bushings, nothing else....and the how to he has is only the rear....
i plan on doing the motor mount and front control arm bushing...any how to's out there?? where to jack up the motor, maybe some simple steps for us?? thanks! i already have a place to push out the old bushings
Old May 31, 2007 | 03:52 PM
machinehead131's Avatar
A how to on the front control arm bushings would be helpful too
Old May 31, 2007 | 04:47 PM
djfrestyl's Avatar
Suspension Yoda
I remember reading a text write up for bushings that Matt Blehm did at some point.
Old May 31, 2007 | 04:56 PM
Hmm, If you can find it that'd be great.
Old May 31, 2007 | 05:08 PM
Love_00_Max's Avatar
Is is a must to replace the entire control arm with the balljoint, can the balljoint be replaces using the same control arm? Now the bushings themselves go around the four bolts on each of the control arms, right.
How many have replaced them by doing it in their garages with power tools, or is a forte of the dealership?
Old May 31, 2007 | 05:16 PM
djfrestyl's Avatar
Suspension Yoda
I've done it in my garage.
Old May 31, 2007 | 06:07 PM
carsarecool's Avatar
I got the ES bushings from Cattman and a set of sway bar bracket bushings, with shipping it came to 110 and I think I got overnight too...these are polyurethane and the front end feels a lot tighter however it takes bumps slightly harder too. I thought it was causing a rattle from under the car but it wasnt, the bushings wernt actually bad. The labor to do all that was $200 but that was a deal with a mechanic I knew through working at autozone. So maybe 210-260 in labor if you dont feel comfortable doing it yourself
Old Jun 4, 2007 | 08:12 AM
maximo-SE's Avatar
i just bought two front control arm bushings from DAVEB. im taking it to another mechanic and have him replace them for me. im not going back to the dealership. too expensive even if they do warrant their work.
Jeffesernia11
Aug 23, 2015 06:09 PM
maxocar
Aug 21, 2015 12:57 AM
soon2ownmax
Aug 13, 2015 02:19 PM
laparka66
Aug 6, 2015 09:36 AM
00 Max
Aug 4, 2015 07:09 PM
