Issues with p0430, pre cats.. does this look alright?
Old May 29, 2007 | 06:32 PM
mrnock's Avatar
I've been having the p0430 code on my CALI SPEC 5sp 2k max with 125k miles. Ive had the o2 sensors checked and they are within voltage, very close however. I've already replaced my main cat (no change), and now I've been informed that the problem may lie in the pre-cats.
The twist is this: I was involved in an accident in my car a while ago, pretty bad actually, rear ended someone and when I saw the engine after the accident, the o2 plugs were pushed very close to the block and it seems that there is some physical damage on the exhaust. The pipe that the o2s plug into, pictured below seems bent and maybe the headers are damaged as well? Or maybe im just being paranoid... Could anyone offer some input? I'm thinking of buying a Y-pipe and maybe some o2's or simulators in hopes of fixing this for good.
Old May 29, 2007 | 09:57 PM
tedo007's Avatar
faster than you think
you need a few lesson on how to post pictures in thread go the test area and find out how it works
Old May 30, 2007 | 06:21 AM
NmexMAX's Avatar
dot dot dot ...
There's a couple.
Old May 30, 2007 | 08:48 AM
mrnock's Avatar
Pictures fixed!
Old May 30, 2007 | 05:05 PM
Kevon1's Avatar
The coils are not oem except for the middle one pictured that would be my first guess. Ya your o2 sensor plugs are all bent up . I would defintely check the coils.
Old May 31, 2007 | 01:25 PM
mrnock's Avatar
How would you relate non OEM coil packs to the P0430 problem?
Mar 12, 2020 12:06 AM
MannyMonroe
Sep 17, 2015 02:34 PM
BrandonCause
Sep 14, 2015 10:41 PM
MaxLife17
Sep 8, 2015 02:36 PM
