p1130??????
p1130??????
has anyone had this code?i know its the swirl valve control inside the manifold
im on my 3rd manifold and my damn ses light keeps popping back on has anyone dealt with this problem if so let me know i mean its a brand new manifold everything is installed properly and about 35 miles after having it installed the light is back on......help
The On-Board Diagnostic system detects a malfunction when:
Malfunction A An improper voltage signal is sent to ECM through swirl control valve control solenoid valve
Malfunction B The vacuum signal is not sent to swirl control valve under specified driving conditions, even though swirl control
valve control solenoid valve is ON
Malfunction C The vacuum signal is sent to swirl control valve even though swirl control valve control solenoid valve is OFF.
Possible Causes
MALFUNCTION A
Harness or connectors
(The swirl control valve control solenoid valve circuit is open or
shorted.)
Swirl control valve control solenoid valve
MALFUNCTION B
(The swirl control valve control solenoid valve circuit is open.)
Intake system (Intake air leaks)
Hoses and tubes between intake manifold, vacuum tank and swirl control valve actuator
Swirl control valve actuator
Swirl control valve control vacuum check switch
Mass air flow sensor
Crankshaft position sensor (REF)
Throttle position sensor
MALFUNCTION C
shorted.)
Hoses and tubes between air cleaner and swirl control valve
vacuum check switch
Possible Causes
MALFUNCTION A
shorted.)
MALFUNCTION B
MALFUNCTION C
shorted.)
vacuum check switch
blinghurst
May 24, 2022 06:00 PM
Miroslav klose
May 22, 2013 01:08 AM
