Who's got it? Megan Racing OE-RS catback!!
Old Jul 9, 2007 | 11:46 AM
  #201
huffdaddy2008's Avatar
Originally Posted by nismopc
And isn't that the same flange location where the cat-back exhaust bolts to, after the O2 bung?
I agree with you from hte picture nismopc. ive never looked from the cat back on an A33 but i assume its the same as an A33B since a catback fits both. The cat looks different. If an A33 does look like hte picture then an aftermarket catback would be too long and extend past the bumper. Just my .02.
Old Jul 9, 2007 | 04:59 PM
  #202
panda_1's Avatar
[QUOTE=huffdaddy2008]theres no bung in the b pipe...youll have to have one welded in
actually im happy there isnt one, regardless i have an o2 sim at that sensor location. ordering mine tonight if nobody has ne complaints about it
Old Jul 9, 2007 | 05:01 PM
  #203
panda_1's Avatar
well then for some reason my rear o2 sensor is after my cat.
Old Jul 9, 2007 | 05:41 PM
  #204
BlackBIRDVQ's Avatar
drag racing is for wussies
Originally Posted by The Law
Are you tuned or untuned? Cause if you havn't tuned your car that is prob why we see the black/blue smoke.
Makes no diff if hes tuned or not, the start up smoke was blue. Tuning only affects the way car operates in open loop at set throttle % if hes using a S-AFC or by RPM. Emanage is very similar, you don't tune your car for idle quality with any of these "piggy back" systems. Regardless of which, hes got oil consumption issues.
Cattman exhaust is made by Stromung, they also made exhausts for Mossy. I have one.
I don't like the way it sounds, the Megan one.
Old Jul 9, 2007 | 05:42 PM
  #205
The Law's Avatar
I R The Law
I don't like the way it sounds.
Oh I see. Then I dunno then. It was just a guess.
Old Jul 9, 2007 | 06:33 PM
  #206
Lovely...........time to do some
Old Jul 10, 2007 | 03:56 PM
  #207
nk2k2's Avatar
welcome to the club. i just did my oil change like 4 days ago and i got about 2.5 quarts to drain out and i have 75k miles on it. im using castrol gtx 10w-30 but im thinking about switching to something else next time around. its got a m1 filter on it too. i have the pcv blow by setup and it collects about 2-3 tbsp every week it seems.
edit: i changed the oil @ 21xx miles too!
Old Jul 10, 2007 | 04:01 PM
  #208
I'm not part of your club thou, 3.0L has none of this problem you speak of. 178K miles on mine.
Old Jul 11, 2007 | 07:39 PM
  #209
nk2k2's Avatar
yeah ive noticed that the 3.0 motors are solid. i wish the 3.5 was built like the 3.0 w/o any problems. i mean i know the oil consumption only pertains to a handful of guys on the .org but i guess its just one of those things you just have to live with.
Old Jul 11, 2007 | 08:37 PM
  #210
Handful will turn into majority of them soon. Most of the cars are still around 40-60K miles, and the problem just about starts at this mileage.
Old Jul 11, 2007 | 10:05 PM
  #211
The Law's Avatar
I R The Law
I'm about to hit 70k and I have no such problem *knock on wood*
Old Jul 12, 2007 | 09:23 AM
  #212
00MaxSE's Avatar
Pointy Elbows
Oh don't you worry, Lawrence. Your time will come. Be patient.
Old Jul 12, 2007 | 03:56 PM
  #213
The Law's Avatar
I R The Law
Thats really messed up Mr. Wong but then again karma is a *****.
My Car > j00 Mr. Jason Wong
Old Jul 12, 2007 | 04:03 PM
  #214
00MaxSE's Avatar
Pointy Elbows
Old Jul 13, 2007 | 03:31 PM
  #215
panda_1's Avatar
i didnt see a post about it, but did anyone feel any power or torque differences with the exhaust on?
Old Jul 16, 2007 | 01:42 PM
  #216
Not really noticeable. Just turns more heads.
Old Jul 16, 2007 | 01:46 PM
  #217
OOmaxSE's Avatar
Hey Huff, after looking at the exhaust, do you think the rear section will be interchangeable with OEM b pipe (I have Cattman but same fitment nonetheless)? I called up and they said "I don't think it will work with stock b-pipe because the piping is too small" which doesn't mean much.
Old Jul 16, 2007 | 09:35 PM
  #218
BostonA33's Avatar
Oh ok, thanks for the info. Im not tuned, waiting on some funds for piggyback and dyno time.
if it is blue smoke on start up it means that there is oil leaking from the heads and into the cylinder. what causes this is worn valve guides usually i could be wrong. if its all the time your getting that kind of smoke its probably piston rings.
Old Jul 16, 2007 | 09:41 PM
  #219
BostonA33's Avatar
Originally Posted by nismology
2000 fed-spec's have a rear o2 behind the main cat.
the 2000 maxima has 4 cats 2 in the exhaust manifold, 1 in the y-pipe which is basicly nothing cause its a tiny pre-cat, then a cat in the middle of the car. after the last cat there are no o2 sensors, there are 2 o2 sensors in the exhaust manifolds and 2 o2 sensors right after the 2 cats in the exhaust manifolds and thats it. hope that helps out.
Old Jul 16, 2007 | 11:48 PM
  #220
Ya it should bolt up w/ the OEM b pipe or cattman. I dont think youll have any fitment issues.
BostonA33 - Nismology is correct. Read up a lil bit more. In the 2000 theres cali spec and fed spec.
Old Jul 17, 2007 | 07:52 AM
  #221
BostonA33's Avatar
on my car there is no o2 sensor after the last cat, unless im missing something and i have replace almost everything on my exhaust accept the exhaust manifolds
Old Jul 17, 2007 | 10:27 AM
  #222
Pages 4 and 5 - http://maxima.theowensfamily.com/tsb/NTB02-051a.pdf
Old Jul 17, 2007 | 05:32 PM
  #223
Teufelhunden's Avatar
wheres the new vid?
Old Jul 17, 2007 | 09:57 PM
  #224
spdfreak's Avatar
As far as i'm concerned, there are 2 pre cats and 1 main cat = 3 cats. Where do you get 4?
Old Jul 18, 2007 | 03:49 PM
  #225
nk2k2's Avatar
Originally Posted by Teufelhunden
wheres the new vid?
+1 10 char
Old Jul 18, 2007 | 03:57 PM
  #226
The Law's Avatar
I R The Law
What new video are you guys talking about?
Old Jul 18, 2007 | 04:57 PM
  #227
ill make another in cabin vid under load either later tonight or tomorrow.
im gonna get this exhaust regardless of vid, but it would be nice...
Old Jul 18, 2007 | 05:38 PM
  #228
spdfreak's Avatar
C'mon, lets see it.
C'mon, lets see it.
Old Jul 18, 2007 | 06:05 PM
  #229
patience is a virtue
Old Jul 18, 2007 | 07:21 PM
  #230
nk2k2's Avatar
mannnnn its been like two months. ive been going waiting for it.
Old Jul 18, 2007 | 07:41 PM
  #231
this camera is a piece of junk. ive got another one coming. gimme a few.
http://www.youtube.com/watch?v=_rUE6MEaZ-o
Old Jul 18, 2007 | 08:03 PM
  #232
http://www.youtube.com/watch?v=DvMRMA21HPo
Old Jul 18, 2007 | 08:25 PM
  #233
AceofSpds's Avatar
wat
It seems pretty loud when you get on it, didn't seem that bad when you were decelerating in the 1st video though.
Old Jul 18, 2007 | 09:57 PM
  #234
spdfreak's Avatar
And the mic picks up the noise like crap.
Sounds good though.
Old Jul 18, 2007 | 10:22 PM
  #235
does it drone in the highway?
Old Jul 19, 2007 | 12:03 AM
  #236
Sounds good though.
My bad, I should have clarified. I meant i had another video coming, hense the second video. The sound is accurate though, it is what it is.
Do you have headers? If you dont, then I dont think you have anything to worry about. There is some drone but thats pretty much expected w/ headers. The drone is the loudest from 2000~2500 rpm. So cruising in 4th gear around 35-40 mph and 6th gear 65-75 is the loudest it gets. Theres less drone at any speed above that 2500 mark. Hope that helps.
Old Aug 1, 2007 | 10:16 AM
  #237
WMASSMAX's Avatar
Originally Posted by upstatemax
It will melt... Trust me.
I did the same with my Cattman exhaust and it melted through after a few weeks.
My little piece of high temp water hose is still intact and holding strong.
Old Sep 15, 2007 | 12:59 PM
  #238
Maximized2000's Avatar
I'm interested. I have a 2000 max with Y pipe. Any idea which place sells it the cheapest? I looked up Ebay and its going for $380 + $50 SHIPPING. I don't think there is a sound clip of a 2000 max with Y pipe and Megan catback? I might order one and be the first...hope its not crazy loud.
Old Sep 15, 2007 | 07:20 PM
  #239
Shinjiduo's Avatar
Maxima Grounding Kit Spec
Try this spot 380 free ground shipping in the continential 48. http://www.wesellcarparts.com/store/...idProduct=5078
Old Sep 17, 2007 | 02:57 PM
  #240
Triple8Sol's Avatar
I miss the .org!
Megan Racing FTMFL
