OSCAI Version 2.0
Old Jul 15, 2001 | 03:57 PM
Paul6speed's Avatar
I've updated my OSCAI installation page to reflect the lastest modifications. My previous installation had the air inlet going underneath the air silencer, resting on the splash guard. After seeing UMD_MaxSE's car on Friday, I got motivated to route the air inlet through the splash guard. My version adds an air scoop as well.
http://paulwendy.com/maxima/svcai.htm
Old Jul 15, 2001 | 04:04 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
wanna test it out?? I'll meetcha down at the south end of GSHW
(plus the guys here are curious how our cars will run )
Old Jul 15, 2001 | 04:14 PM
Paul6speed's Avatar
Yeah! We should run. I'm a little nervous though. I keep seeing posts in the main forum about major fines for street racing. We could keep it low key. Or we could just go to the drag strip on Friday night.
Old Jul 15, 2001 | 04:42 PM
UMD_MaxSE's Avatar
Got Bent?
hehehe....cool man
So what does the butt dyno say?
Old Jul 15, 2001 | 05:02 PM
marky3320's Avatar
Too Lazy...
I was too lazy to unscrew the air inlet and install the Shop Vac tubing, so I just pulled out the elbow joint that connects from the air inlet to the silencer. Just my little half-a**ed version of an OSCAI!!!
Old Jul 15, 2001 | 05:31 PM
Ironlord's Avatar
Aren't you worried about crap getting in there (debris/water)? And how hard was it to cut through the splash guard? And what do people use to cut the cap off the air inlet tube (I don't have the elbow and silencer...)
Thanks...
Old Jul 15, 2001 | 05:43 PM
UMD_MaxSE's Avatar
Got Bent?
Thanks...
you really don't pick up a lot of extra crap.. clean the K&N filter more often and that should take care of it. The splash guard is not all that thick. I cut through it with a utility blade. I have a 2k, so my scoop had the L-tube....
Old Jul 15, 2001 | 06:09 PM
PhatGuy
Awesome work man! I have a stillen Intake and have routed a big 4" diameter tube from below the splash guard. It has a lip to induce air flow (which blows right onto the intake) but I think I might redo it with a scoop like yours. Best part about it is that it is easy to take out at anytime. Thanks for the innovations!
Paul6speed's Avatar
I was surprised how easily I cut through the splash guard. So far I haven't picked up a lot of junk in my filter with the old setup. I'll keep on eye on it. It's easy enough to push the hose back in, if it rains. In the winter, I'll probably through the elbow joint back in.
3 way race. UMD_MaxSE, vs. VTECboy, vs Paul. Let's do it!
Originally posted by UMD_MaxSE
you really don't pick up a lot of extra crap.. more often and that should take care of it. The splash guard is not all that thick. I cut through it with a utility blade. I have a 2k, so my scoop had the L-tube....
Old Jul 15, 2001 | 06:14 PM
UMD_MaxSE's Avatar
Got Bent?
hehehe....on I-370...... its on
Paul6speed's Avatar
Just copying Nauman. I added the scoop though. I actually bought the scoop for the hose when I first bought the setup, but I was too lazy to install it. Now that Maxus is coming up, I need every trick to stay in the running.
Old Jul 15, 2001 | 06:15 PM
Paul6speed's Avatar
My butt dyno has be down to 15.5 again. It feels more responsive. I can't wait to test it on the track.
hehehe....cool man
Old Jul 15, 2001 | 07:45 PM
SteVTEC's Avatar
Originally quoted by UMD_MaxSEhehehe....on I-370...... its on
oooh cool - Nauman has the place, now all we need is a time
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
QueensMAX
Sep 15, 2015 04:14 AM
maximusrising
Sep 2, 2015 09:55 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
