Fog light bulb replacement
Old Jul 16, 2001 | 02:10 PM
predator
OK OK what is the trick. I bought some new bulbs thanks to this site!!!!!! I removed the lower fender protector and I can't understand how to change the bulb. I don't want to pull and damage but there must be some trick. Can anyone help. I removed LFP according to the link below (thanks paul.
http://www.paulwendy.com/maxima/fogl...derprotect.jpg
How do I remove the assembly to change the bulb. There was one screw on the bottom of the assembly accessed from behind but the lamp assy would not come out. I also saw two other screws on the sides of the assembly but you can't get at them.
I changed the head light bulbs (very cool) and now I want to make the fog bulbs match. The current fogs look dirty. The original is probably better than the blue but hey image is everything!!!
I bought:
ASTRA ULTRAWHITE XENON for both the headlamps and fogs
$25 & $20/pr
First of many posts (great site)
Ralph
Almost forgot:
2000 Maxima SE
Sterling Mist
light Gray int
5 spd
Old Jul 16, 2001 | 02:29 PM
Dustyroads's Avatar
Check out this page. I thinkn Russ gives a pretty good explanation on how to change out the bulbs. Incidently the screw at the bottom does need to be removed and then there is a clip that you have to undo and then you just have to push the whole fixture out the front. Check out the page for more help.
http://www.5thgenmaximas.com/foginstall.html
Old Jul 16, 2001 | 04:54 PM
UMD_MaxSE's Avatar
Got Bent?
Pushing the fog assembly out takes a bit of force. Keep trying, it will come out....but be careful....
Old Jul 17, 2001 | 09:05 AM
predator
WOW
Thanks guys (esp. Russ),
I'm impressed!!!!! I knew there was some clip or snap but didn't want to break anything. I will change them out this weekend. Thanks again, I know I'm gonna like this site. I was hoping for discriptions, but pics!!
The Bal#$,
Ralph-
Old Jul 19, 2001 | 08:20 AM
predator
Done
Thanks guys,
Put them in last night and they look great. No problem took about 20 mins. It was actually the first time I drove at night with the head lights as well. It looks so cool!!!!!!
Ralph-
Old Jul 19, 2001 | 08:24 AM
UMD_MaxSE's Avatar
Got Bent?
cool
Old Jul 19, 2001 | 08:52 AM
Dustyroads's Avatar
Congrats and happy driving!!!
Old Jul 19, 2001 | 12:56 PM
ToYLeT902's Avatar
JET Speed Lab
Re: Done
Ralph-
er.... you dont usually drive at night with your headlights on?? good job changing your fogs though, i myself said screw it and brought it to a mechanic to change them
Old Jul 19, 2001 | 01:42 PM
jopa's Avatar
Russ's site is good
Does anyone wonder why headlights are so easy to replace, with easy access to the bulb, but they can't seem to invent fogs that are easy to get to. The Maxima is not the only car that this applies to.
Sorry, I'm just venting.
Old Jul 19, 2001 | 07:26 PM
DooBall's Avatar
Re: Russ's site is good
i think switching the fog lights are easy after you figure it out. i can do each bulb in 5 minutes *flex*
Old Jul 20, 2001 | 05:07 AM
predator
Hi ToYLeT902,
I guess I didn't need to change the bulbs, I just needed to turn them on!!!!
Ralph-
Old Jul 20, 2001 | 07:07 AM
jopa's Avatar
Re: Re: Russ's site is good
Well now that I've done it once I don't think it's that difficult, but compared to the headlight bulb replacement (which can done in 1 minute) it's pretty involved.
It should be designed so that you don't have to remove the entire fog light assembly. Once you pull down the splash guard you should be able to just reach up and get the light.
At least in my mind that is how it should be.
Old Dec 26, 2008 | 09:17 AM
Frnchse's Avatar
I tried to pull up the site http://www.5thgenmaximas.com/foginstall.html but got url not found. Is the site still active? I am having trouble popping out the two metal pins on the fog light housing in order to get the light to come out. I need to replace the bulb. I tried using a hammer but there isn't much room to work with. Any suggestions?
Old Dec 26, 2008 | 10:44 AM
hi-tek22's Avatar
your talking about at the point in which you try and take the bulb out of the housing? correct.........that is the easy part, compared to getting them back in
be sure the screw holding the tab down is not screwed in...
Old Dec 26, 2008 | 10:53 AM
snowman2109's Avatar
haha turn them on haha
Old Dec 26, 2008 | 11:07 AM
Frnchse's Avatar
No. I removed the bottom screw on the fog light housing. The next step was to remove the two metal pins in order to push the fog light (not the bulb) out in order to remove the bulb. I can't remove the metal pins. I've read a couple of reviews that say there is a tab that needs to be released in order to remove the fog light housing. Are you aware of that?
Old Dec 26, 2008 | 02:05 PM
02PatMax's Avatar
so where can i buy a replacement bulb for the foglight located in the bumper? i have the assembly and teh burnt light bulb already out...
Old Dec 28, 2008 | 04:00 AM
CMax03's Avatar
your local auto parts store....advance, o'rielly, autozone, pepboys, it's a H-3 bulb have fun.....
Old Dec 28, 2008 | 05:58 AM
Maxgig's Avatar
The instructions with pics helped me alot too. I had to replace my whole passenger side assembly and it took alot of force to push it back thru but I didn't break anything in the process. Good luck.
Old Dec 28, 2008 | 11:27 AM
blackmax42's Avatar
Is there an "active" link to instructions? As Frnchse said above, they all seem dead. Seems like a bit of an ordeal (outside in the snow, under the car) the first time and it would be great to have proper instructions to follow! Thnks
Old Dec 28, 2008 | 11:43 AM
nismology's Avatar
http://www.shiftice.com/piaa_fogs.html
Old Dec 28, 2008 | 08:55 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Wow, this got bumped from 7 years ago? Why?
Old Dec 29, 2008 | 07:06 AM
Frnchse's Avatar
There are three sites that have directions.
http://www.cardomain.com/ride/2076435/2
http://shiftice.com/piaa_fogs.html
and there is another nissan forum site which I bookmarked the url on another computer. I'll post later. The instructions on shiftice.com said to take a hammer and pop out the metal pins in order to get the fog light assembly to come out. That didn't work for me. Another site said to take a 10mm socket to unscrew those metalpins. I have not tried that approach but willl give it a try this weekend.
Old Dec 29, 2008 | 07:11 AM
SoonerFan's Avatar
Cletus
changing fogs is so hard
Old Dec 29, 2008 | 09:16 AM
ShippedOut's Avatar
I so need to change my OEM dog bulbs to the Eurolite H3 Lexus style bulbs I picked up. No time prob just take it to a mechanic..... The screws are a PITA to get out
Old Dec 29, 2008 | 10:23 AM
SoonerFan's Avatar
Cletus
you are really going to pay a mechanic to change bulbs
Old Dec 29, 2008 | 10:41 AM
ShippedOut's Avatar
Lol luckly my mechanic will do if for free. I get fustrated easily plus I stripped the screws so 30mins under my car in a cold garage is to harsh. Bare with me I just started changing my brakes myself lol
Old Dec 29, 2008 | 07:35 PM
Frnchse's Avatar
Here is the other site. It has picture diagrams. Says the instructions apply only to 2002-2003 Maxima's.
http://forums.nicoclub.com/zerothread?id=157915
Old Dec 29, 2008 | 09:14 PM
Ricer Chronicles's Avatar
dude theres no screws you need to remove. just punch the harness from behind and it pops out.
Old Dec 29, 2008 | 09:15 PM
SEmy2K2go's Avatar
Go BUCKS!!!
WRONG. There are two 10mm screws.
I'm closing this thread now because it's 7 years old and this has been covered 100's of times.
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
MikesChevelle
Aug 6, 2015 11:36 AM
