o2 simulator
Old Jun 25, 2007 | 08:21 AM
klee215's Avatar
o2 simulator
Hey guys ,
Quick question, I have p430 p420 codes and i wanted to get a o2 simulator. now do i get the universal dual output simulator? or single??
found the simulator at www02sim.com
Old Jun 25, 2007 | 08:31 AM
upstatemax's Avatar
Is your car Cali or Fed spec?
If it is Cali, you need the dual, is it Fed you only need the single.
Old Jun 25, 2007 | 08:47 AM
Bborges's Avatar
Originally Posted by klee215
Hey guys ,
same thing here: 0430 on a Cali spec.
that means I need the dual output sim, correct?
Old Jun 25, 2007 | 08:50 AM
Bborges's Avatar
hey dude, the link doesnt work even if I add the dot after www.
Can you confirm the page?
Old Jun 25, 2007 | 08:57 AM
upstatemax's Avatar
Yes.
And the web page is:
http://webstore.o2simulator.com/
Old Jun 25, 2007 | 09:57 AM
klee215's Avatar
hey thanks for the replies.. now does anybody know a person in philly that is willing to install it for me
Old Jun 25, 2007 | 10:02 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/forumdispla...aysprune=&f=15
Old Jun 25, 2007 | 10:29 AM
absoundlab
what does an o2 sim do?
Old Jun 25, 2007 | 12:38 PM
Bborges's Avatar
it simulates a working O2 sensor.
Old Jun 25, 2007 | 04:01 PM
absoundlab
to do what?
Old Jun 25, 2007 | 04:30 PM
Stardust's Avatar
F---ing Kangaroos
to do what?
to simulate a working O2 sensor
Old Jun 25, 2007 | 04:45 PM
spdfreak's Avatar
Taken Right out of the FAQ section for those too lazy to search.
"o2 simulator is a device that can be used to avoid Check Engine when catalytic converter is removed in OBDII cars. It simulates the secondary oxygen sensor signal and makes ECU 'think' that converter is present and is in working condition. This prevents ECU to set the error code and light up Check Engine indicator."
Old Jun 26, 2007 | 01:58 PM
PaulyPoTz's Avatar
a car with this 02 sim installed will pass inspection correct?
also, does a bad 02 senor hurt gas milage...if so wont an 02 sim?
Old Jun 26, 2007 | 02:30 PM
NmexMAX's Avatar
dot dot dot ...
If inspection requires you have no SES light, then yes. Probably not if they physically inspect the car in great detail.
It depends on which O2 sensor you are simulating.
Old Jun 27, 2007 | 06:41 AM
klee215's Avatar
ok another stupid question if im getting p430 and p420 codes , i need to get 2 o2 sim, right? or do i just get 1 and that will solve both codes..
Old Jun 27, 2007 | 06:44 AM
Bborges's Avatar
i think u need to get 1 dual-output or 2 single-output.
Old Jun 27, 2007 | 09:30 AM
NmexMAX's Avatar
dot dot dot ...
1 dual output would seem like the logical choice.
Old Jun 27, 2007 | 11:54 AM
ANorth's Avatar
Sorry to thread jack, but I have a similar question. I am hoping we can work together to try and figure this out. I am trying to get rid of a 0420 code using the o2 simulator as well. My o2 simulator configuration looks like this.
In addition, there is the 4th o2 simulator in the towards the rear of the engine, on the pass side near the spark plugs.
After doing some research, it appears as if the 3rd sensor from the right, in the top photo, labelled "Secondary Sensor 2, Bank 1" is one of the sensors that need to be simulated. Furthermore, I have learned that the 4th sensor, towards the rear of the motor, in the second picture labelled "H02S1-B1," is the primary bank 1 sensor. When trying to eliminate the 0420 codes, I know i need to simulate the bank 1 sensors, but do i need to do both of them? or just the primary or just the secondary.
In addition, i have looked at the wires on the harness end of the sensor, and they are not consistent throughout all 4 sensors. One of them has a pink wire, and by process of elimination, it seems to be the red/yellow wire on the other sensors, being the power wire.
Has anyone else encountered this? Finally, the 4th sensor, in the rear the "H02S1B1" only has three wires going to it. I think it may be missing the ground. Can anyone confirm this/and or provide some additional info?
Thanks in advance to the .org, i know i am still a newb, but you have all provided some great info to me in the past.
Old Jun 27, 2007 | 12:11 PM
Bborges's Avatar
Anorth,
Quite a few members are in the same spot, including myself. Your thread is completely related to the topic, so dont worry there.
time is also running for me, my deadline is july 22nd. I have to fix this crappy code soon.
coming back to your questions, I am not sure about the order of the O2 sensors but I have the laptop with OBD scanner and I plan on reading the outputs and disconnecting one by one and checking which connector is each.
you seem to also have a Cali spec, with 4 sensors. If that is the case, you should have this config:
FRONT-01
PRE-CAT INBETWEEN
FRONT-02
REAR-01
PRE-CAT INBETWEEN
REAR-02
My OBD Progam labels then as follow:
O2S11 / O2S12 / O2S21 / O2S22
The readings from the OBD are here:
You have code 0420, which is opposite cyl bank from 0430 (i always get confused which code goes with each bank).
I think best thing for 0430 & 0420 is to get O2 Sim Dual-output and connect to both 2nd feedback O2 sensors.
Let me know when you about to do ur job.
Good luck
Old Jun 27, 2007 | 12:12 PM
upstatemax's Avatar
You can't sim the primary sensors, they are needed to determine fuel maps.
Only the secondary sensors can be done.
The 420 code is only reffering to the secondary sensor, not the primary.
So all you NEED to sim is the one secondary, I would sim both secondary sensors with a dual and get it over with though.
Old Jun 27, 2007 | 12:27 PM
ANorth's Avatar
Wow thanks very much for the quick replies. So...i should try and to hook up the simulator to the secondary sensor for bank 1, the third on the right? and then, just to save myself sometime in the future, hook it up to the secondary sensor for bank 2, the second on the right?
Is the 0430 code the same as the 0420 but for the bank 2 sensors?
edit- bborges thanks for the screen shot.
Old Jun 27, 2007 | 12:35 PM
upstatemax's Avatar
Yes, to all.
The two middle sensors are the secondary sensors the two on the outside are the primary.
Old Jun 27, 2007 | 12:48 PM
ANorth's Avatar
Well Klee, that answers your question. You should use a dual output sim to simulate the two middle sensors, the secondaries for both bank 1 and bank 2.
Has anyone noticed that the color of the wires is not consistent among all 4 sensors on the harness side? Hell, as i said before, the primary on bank 1 only has 3 wires?
Old Jun 27, 2007 | 12:52 PM
upstatemax's Avatar
Just an FYI... When you install the sim, you HAVE to install it BEFORE the harness.
Do not install it after the harness on the wires that go directly to the sensor.
Old Jun 27, 2007 | 12:57 PM
ANorth's Avatar
Great thanks...have you noticed the color of the wires are inconsistent?
Old Jun 27, 2007 | 04:33 PM
huffdaddy2008's Avatar
Its because theres no heater circuit on the primaries. The 4th wire on the secondaries in the heater circuit wire.
Old Jun 28, 2007 | 08:35 AM
klee215's Avatar
thanks to all for the replies.. now anybody in philly willing to help me with the install.. =) need to do this quick my inspection expires in 2 days
Old Jun 28, 2007 | 05:15 PM
If you cant find anyone to do it, you might have luck with a shop that can do it for ya. Just point out what you want done, that was an option i had i just didnt wanna pay them to do it.
Old Jul 5, 2007 | 07:44 AM
Bborges's Avatar
Hey Anorth.
were u able to install it? did the code go away?
Later bro
Old Jul 6, 2007 | 07:49 AM
klee215's Avatar
install went good . no cel light yet and dont think it'll come back .. dont stress the install just follow instructions and its a piece of cake
MaximaDrvr
Aug 19, 2015 08:20 PM
1992maximase30
Aug 5, 2015 09:27 PM
BlackBIRDVQ
53
Jun 4, 2007 12:44 PM
NmexMAX
Jan 12, 2005 09:05 PM
