HUGE rotors on MAX ???
Old Jun 29, 2007 | 11:02 AM
kramarz99
I know this subject has been over and over, but need some advise...Will 300zx 30mm calipers work with huge 340mm, 1.25" thick rotors. I have done a lot of research and you guys sell brackets, 13" rotos and so on. I got all that. I camed across huge rotos, 340mm & 32mm thick. They are two piece rotors. Just wondered if they will fit. Please advise...
Old Jun 29, 2007 | 12:34 PM
DasYears
the calipers are made for 30mm rotors, but if you can get them to fit and make your own brackets, i dont see why not
Old Jun 29, 2007 | 12:39 PM
kramarz99
so I would have to redesign those brackets that people sell on org...any other sugesstions, anyone
Old Jun 29, 2007 | 02:41 PM
kramarz99
looks like nobody tryied that...that is cool, cause I will be first...hahaha
Old Jun 29, 2007 | 02:49 PM
Kevlo911's Avatar
Kevlo for President
Need more specs on the rotor, specifically, what car are they from...
Old Jun 29, 2007 | 02:53 PM
Jeff92se's Avatar
I'm needing a caw
Won't work. ESPECIALLY if they have a nissan offset. Please don't try to mix and match stuff if you don't know what you are doing. Just use my bracket/rings, Automax's rotors/pads/lines and either the 1pc or 2pc COBRA rotors. You will be fine.
Old Jun 29, 2007 | 03:37 PM
Maxim(a)SerjVQ's Avatar
Nightmare = Reality
actually, on the subject. does anyone know about how large the K-sport kit is? I haven't seen specifics and/or whether they will fit under the stock 17s.
Old Jun 29, 2007 | 03:57 PM
SoonerFan's Avatar
Cletus
kramarz99 ,
your sig clearly violates the org sig rules. please read and heed.
http://forums.maxima.org/showthread.php?t=512019
Old Jun 29, 2007 | 07:40 PM
irish44j's Avatar
retired moderator
why would you need rotors bigger than 12.6 or 13" anyhow? The z32 pads don't sweep the entire 6th gen rotors in the first place.
Old Jun 30, 2007 | 04:14 PM
kramarz99
BBK on MAX 340mm / 32mm
see, that is what I wanted to hear "they don`t sweep the entire..." I was affraid of that. I know this is pointless to put 13" or bigger rotors on slmost stock maxima, but I want to do it. I`m in the process of getting 340mm rotors, which are a bit bigger that 13". I`m sick of replacing my rotors evey year so I want to put bigger ones so they will stay in good shape for longer time.
irish44j, what about thicknes. the Z32 calipers are 30mm. is that mean, that they will fit only rotors 30mm thick ??? I found rotors 32mm thick and I`m affraid that they will not fit...can you advise...?
Old Jun 30, 2007 | 04:24 PM
soundmike's Avatar
Very sound, Mike
Why would you? It doesn't have to do that to be effective.
Here's a simple test for you. Stretch your left pointer finger out. Now, with your right pointer, index and thumb, squeeze on the base of your left finger. Pull it down while moving your left finger up.
Notice how easy it is to move the left finger up even with three fingers holding it down?
Now with the same set-up, move your right pointer and thumb to the tip of your left finger. Use both to pull your left finger down, while pushing your left finger up. See how much harder that was?
The first scenario is working similar to the smaller brake set-up.
The second scenario is working similar to a BBK.
It is a bit oversimplifying, but it follows the same theories.
Old Jun 30, 2007 | 05:03 PM
irish44j's Avatar
retired moderator
the size of the rotor has nothing to do with how long they will last....that depends on how you drive and what pads you use.
32mm rotors would be a tight fit. Besides, you'll have to have custom relocation brackets made as well.
An also...what size, width, and offset are your wheels?
Old Jun 30, 2007 | 05:54 PM
kramarz99
wheels are from 350z....18", 30mm offset
Old Jun 30, 2007 | 05:56 PM
kramarz99
your comments please keep for others, not me...thanks
Old Jun 30, 2007 | 06:34 PM
irish44j's Avatar
retired moderator
by the way, you do realize that a 340mm rotor is not really much bigger than a 13" rotor (13"=330mm), right?
So what is the point of doing all this custom work just to get a rotor that is only 1cm bigger than the cobra rotors?????
Old Jun 30, 2007 | 06:35 PM
irish44j's Avatar
retired moderator
maybe you should read what he wrote. It's a valid comparison.
Old Jun 30, 2007 | 07:12 PM
SuperStasiu's Avatar
True dont get mad bro lol hehe told u you over doin this shish
Old Jun 30, 2007 | 08:15 PM
kramarz99
okey...never mind...
Old Jun 30, 2007 | 08:43 PM
Jeff92se's Avatar
I'm needing a caw
Not that my opinion would be valid or anything
Old Jun 30, 2007 | 10:31 PM
kramarz99
so bbk will not work on 350z wheels?
Old Jul 1, 2007 | 05:42 AM
Kevlo911's Avatar
Kevlo for President
Huh? Did you bother reading ANYTHING posted in this thread?
Someone needs to revoke your posting powers and just have you do research and read.
Old Jul 1, 2007 | 06:05 AM
MetaOrbit's Avatar
Got Projectors?
But it's soooo much easier to post wild, unfounded conjecture without even beginning to understand the problem at hand!
Old Jul 1, 2007 | 08:51 AM
Jeff92se's Avatar
I'm needing a caw
Old Jul 1, 2007 | 08:53 AM
machinehead131's Avatar
Learn to read.
Old Jul 1, 2007 | 07:36 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
This is all you really need....
Old Jul 4, 2007 | 11:27 AM
jesse1020's Avatar
my front breaks are from an 04 max
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
Quickywd01
Sep 21, 2016 09:36 PM
maxima297
Sep 30, 2015 03:32 PM
Socalstillen
Sep 26, 2015 12:01 PM
